Question about Sewing Machines
I need the threading diagram for a Micro Serger II baby over lock model fn3/4. Thank you.
Hi, how can use 4 thread in serger baby lock vintage?thanks
It would probably help if you had an owner's manual. That should have the information you need for threading and using your machine. Search for:
Make Model manual
although I've frequently found that manuals for Baby Lock are not free.
Nov 12, 2017 | Baby Lock Sewing Machines
I have never used a serger before and a friend is letting me use hers. There is string on the machine, but how do I put the colors I want on and get it to the needle? The machine is a Baby Lock BL3-417. ...
here's a tip I learned for sewing machine or serger
do one thread cone at a time-the cone or spool that's on the serger--cut the thread close to the cone-then remove the cone from the serger ,,don't remove the thread that you just cut from the serger,,now put your thread on the spindle & tie your thread to the thread that you just cut (make sure it's a small knot) now the thread that's in the needle pull until the thread that in the needle is your & then cut off the other thread & make sure to cut of the knot part & leave a thread tail of 4 to 6 inches
do each spindle this way
Dec 09, 2010 | Baby Lock Sewing Machines
Need basic settings for Baby Lock BL450 Serger. Any idea where I can get it?? My book was lost. The threads don't wrap around the edge of the fabric. I've re-loaded 3 times following the diagram on...
Hi GailKelley,
I have the same model serger. I will make a copy of the stitches and figure out how to get it to you. I recently took my serger out of storage to start some projects. I always struggle threading it but love the look of the stitches when it is set up correctly. Be in touch. MnFriend
Oct 25, 2010 | Baby Lock Eclipse Serger
Serger is not stitching at all. It has something to do with how the thread is installed. Needing a diagram
The diagram is on the inside of the serger door;
Raise the antenna to it's highest position.
Turn the handwheel until the loopers are at their highest position.
Set tensions to zero and raise the presser foot.
Begin threading from right to left, beginning with the upper looper.
Set the tensions back to mid-range.
Lower the presser foot and stitch a chain and if it is formed as it should be you are ready to serge.
There are manuals available for downloading at the Babylock website for the models DX and SX.
May 07, 2010 | Baby Lock Eclipse Serger
I don't have a manual for my Baby lock Pro line model # BL4-738 NS. It was given to me and I have threaded it accordingly to the diagram on the machine but it won't pick up the stitch.
You will have to order the manual from a Baby Lock dealer.
This model may have to be threaded in a certain order.
Try raising the presser foot and setting the tensions to zero.
Turn the handwheel so the upper looper (the curved one) is at it's highest position - there may be a mark on the side of the serger where you align the handwheel for this.
Thread the upper looper and then the lower looper and then the needles.
Pull the threads under the presser foot and toward the side of the serger.
Set the tensions back to 4 - 6, lower the presser foot.
Hold onto the thread tails and gently press the power pedal to begin a thread chain before serging fabric.
Feb 16, 2010 | Baby Lock Eclipse Serger
I have a Baby Lock BL4-736D serger. I need the
orange-(5-7)
yellow-(4-6)
green-(2-4)
blue-(2-4)
medium weight, 4 thread
Dec 06, 2009 | Baby Lock BL1556
Babylock Serger Question
You might take a look on eBay item # 150373367524
Thank you for the question
Aug 29, 2009 | Baby Lock Eclipse Serger
Threading illustrations too small
You might take a look on ebay item 160362974035
May 29, 2009 | Baby Lock Eclipse Serger
Sewing Machines Logo
22 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
