Question about Ovens
The oven temperature keeps resetting to 160 - Ovens
  • 4 Answers
Please provide me your model number.
Posted on Nov 26, 2014
Testimonial: "Sorry, Whirlpool G2P90F electric double oven."
Frigidaire Oven doesn't turn off at set temperature
Hello - From what you have described it sounds like the electric range could possibly be experiencing a communication issue with the EOC, wiring harness or faulty element. Try resetting the unit by unplugging it or flipping the breaker off. Wait approximately ten minutes and turn on oven. If proves to be ineffective, contact a professional to move forward accurately.
Nov 01, 2012 | Ovens
Stove wont turn on
Could be a bad burner or a bad mechanism on the temp control. The burner can be removed usually by pulling straight away from the direction it plugs in to. Keep it horizontal while pulling. There will be a little resistance. You can take the burner in to an appliance shop to have it checked. If that isn't the problem, then it's probably the temp control mechanism. If it's really the oven that doesn't work and it is a digital type, try pushing the bake touch pad, then adjust the temperature, then push the bake touch pad
again to engage the oven.
Jun 05, 2012 | Ovens
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
Oven heat varies
When you say it goes up and down by itself, what is the neon doing on the front panel. Is this switching off and on in relation to the oven heating and cooling? If it is, then it could be the thermostat sensor is dirty/covered in grease etc and giving false readings and will need a carful clean. With a fan oven, the fan should keep running, it is the element that the thermostat controls. If the neon stays on but the temperature varies, it could be a fault with the wiring. Does the fan keep running?
Jan 07, 2012 | Stoves Ovens
When #9 program for Bagels is running , the temp drops 130 degrees before cycle is complete. also having to reset breaker several times
It's normal for the oven to drop temperature during the first 4 minutes of a bagel cycle, although the temperature should recover to 525 before the end of the bake. If your breaker keeps tripping you could have a blown heating element and should call your local authorized service provider, I wouldn't recommend attempting to repair this one on your own.
Sep 28, 2010 | Baxter OV300E Stainless Steel Electric...
OVEN DOOR WILL NOT UNLOCK PUT ON THE SELF CLEANER AND THE DOOR LOCKED AND WILL NOW NOT UNLOCK IT IS A KITCHEN AID AND A CODE KEEPS SHOWING UP
Hi, well i have seen this many many times, and what happens is that when the auto clean function is invoked, well it heats up the inside to a very very high temperature, in excess of 700'C. Often this destroys the temperature, thermistor that controls the oven, unless that is repair the doors stay locked.
http://www.retrevo.com/support/KitchenAid-KEBC107K-Ovens-manual/id/6716bh531/t/2/
Above is your user manual, below is your service and repair manuals, about 1.2 way down the page of posts.. there are two of them. Use the manuals to troubleshoot and repair your unit.
http://appliancejunk.com/forums/index.php?topic=417.0
Jul 21, 2010 | KitchenAid KEBC107 Electric Single Oven
Oven control lock beeping along with F3:E4 flashing on the display
Hi-- The code described; F3 E4  indicates an open circuit- oven sensor.  As far as oven problems go this one is easy to fix. -------Unplug sensor and check resistance. Normal is around 1100ohms. ---If open, then replace with new part.  <This will solve the problem>.  You did not provide any other information besides 'beeping' and 'F3:E4'.  A simple Model # from the tag on unit is required for any service or information.  However, since this is a specific fault code, the oven temperature sensor is the most likely suspect. Please acknowledge this post. Solution is to replace the oven temperature sensor.  Thanks-  Ed
Mar 30, 2010 | KitchenAid Ovens
I want to re-set high temperature limit control, but don't know where it's located
Hello- The reset is located inside the oven at the top. Remove the screws and pull cover. Use a flashlight to find the little red button and push it in with a little screwdriver until it clicks. Should solve this problem. Wish all ovens had this button.     Please acknowledge this post if helpful.  Thanks- Ed
Mar 23, 2010 | Dacor ECS130 Epicure Electric Single Oven
Oven doesn't maintain temperature
When an oven doesn't maintain the set temperature, first make sure no one is allowing the heat to escape by opening its door. If not, the oven control either needs to be re-calibrated or replaced. To have the control replaced, call an appliance service person.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
56 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
