How to plug speakers to get stereo sound - Audio Players & Recorders
  • John Simms Nov 24, 2014
    If the subwoofer is designed for a computer (multimedia) it has to have power. A cassette player does not have any. It has to be connected to a computer.
    New Friend:
  • 32 Answers
What type of connections are on the speakers? What are you trying to connect them to?
Posted on Nov 24, 2014
  • erick sharko
    erick sharko Nov 24, 2014
    Well the i connected them direct cause they had no box and connected behind cassette player wich has 2 wire output
I have a 2000 oldsmobile alero and I can't get sound out of my rear speakers good speakers and connection just no sound
OLDSMOBILE ALERO 2000 speakers - Sonic Electronix
www.sonicelectronix.com/oldsmobile-alero-2000-car-speakers.html
OLDSMOBILE ALERO 2000 speakers - find speakers that fit your ... sound. This size is capable of delivering exceptional mid-bass that can't be found in smaller ...
2001 Oldsmobile Alero Car Radio Stereo Audio Wiring ...
www.modifiedlife.com/2001-oldsmobile-alero-car-radio-stereo-audio-wi...
Easy Plug and Play Wiring Adapter. ... 2001 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram ... If you can't find your car audio wire diagram, car stereo wire diagram or car radio ... Right Rear Speaker Positive Wire (+): Dark Blue ... olds alero and I have replace the stock stereo and have found that the sound out put ...
Request a Oldsmobile Car Radio Stereo Wiring Diagram
Jan 21, 2016 | Oldsmobile Cars & Trucks
Lost sound in left channel?
I presume you are playing a stereo cd. Plug some other device, like headphones in to see if the computer is putting out stereo. Use the same plug as the speaker system is plugged into.
I presume you have swapped the speakers to test them.
If the speakers work, and the headphones work, it's the amp.
Nov 26, 2013 | Klipsch Promedia 2.1 Thx Computer Speaker...
I have creative 5 CE MMS 4250 speakers with woofer. I have a new computer with windows 7 and only able hear sound from the front speakers
To get all 5 speakers, you will probably have to get a new sound card, one that is 5.1 compatible. Most computers with on-board sound will ship with only support stereo sound. If you look at where you plug in your speakers, if there are only 3 slots, you have only stereo sound. If there are more, you may have to plug into different spots on the sound card.
Good Luck,
Rodrick
Apr 23, 2011 | Creative Labs Inspire 5300 Computer...
Where do I connect the speakers to the monitor. I have a Flatron L1922P monitor. I ordered 2.0 USB Multimedia speakers that come with a 3.5mm stereo plug and USB plug. I must not being doing something...
Your speakers do not plug into your monitor. Your speakers should be connected to a USB slot on your PC tower and the 3.5mm stereo plug should be put into the green stereo jack on your PC tower. If your audio jacks on your PC are not colour coded, then you should look for the jack which has a picture of a set of earphones over them.
Depending on your speakers, you may or may not be required to keep the stereo plug connected in order to get sound. Some models transmit model over the USB connection and others just use the USB connection as a way to supply power to the speakers and need the stereo plug to be connected in order to have sound. I suggest trying both.
Mar 25, 2011 | LG L1922P 19" LCD Monitor
Plugged in a Kenwood stereo in a 2000 tahoe. Have all power but no sound. Radio is not defective. When plugging the same stereo into a 99 express van, it works just fine. My question... What is the wiring...
Hi, your factory wire colors are below. Please let me know if you have more questions.
2000 Chevrolet Tahoe Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Doors
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Negative Wire (-): Light Blue
Feb 10, 2011 | 2000 Chevrolet Tahoe
Hello...I have an issue with my speakers. My husband ran our speaker wires from our computer to our stereo and I can't get it to produce sound please help!!!
Be sure you plugged the plugs into the right ports on the back of the stereo.
From the computer: ensure you plugged the cables into the Auxilary Out, or Out jacks of the sound card.
On the stereo: ensure you plugged the cables into any open set of Auxilary In jacks.
Once you verify your cables are plugged in correctly, verify the input on the stereo is set properly. Set your stereo's source or input to "Auxilary" or "Auxilary 1 or 2." This allows the stereo to pull input from the cables running into the appropriately selected Auxilary source.
That should help hopefully.
If you still can't get sound, double check your computer's sound card settings and be sure the sound card is working properly.
Jan 10, 2011 | YouTube Videos
My speakers are plugged in, the error messae sounds are coming through the speakers but the sounds and audio devices say there is nothing plugged in and any media players say the same. I can't find any...
look in the control panel for sounds and audio devices, if the error sounds are coming through, then the speakers are working, leave them plugged into that port, check your speaker configuration setting try setting it to stereo speakers. It also sounds like you may have it set to 5.1 and are only hearing the rear audio channel. problem being your two speakers connected to a 5 - 6 speaker configuration. Again, solved by setting the speaker configuration to 2 speakers (stereo) . Let me know the outcome. Thanks
Aug 27, 2010 | Computers & Internet
How do i hook up the speaker to my computer
if you have stereo speakers, connect it to the green audio port on your computer. if you have digital surround, you have green, yellow and black. insert the speaker connectors accordingly.
Mar 14, 2010 | Acer Aspire T310 PC Desktop
How do i connect to laptop? i can only hear 2 of 4!
If your laptop hasn't a 5.1 surround card you can't connect them in a true 5.1 surround system way. But if you have a stereo sound card and if you don't care about true multichannel and want just to hear sound from all the speakers you neet to connect the adapter that came along with your speaker set-just plug and match the colors from the speaker plugs with the adapter and buy a jack stereo to 2 rca cable and plug the rca connectors to the adapter and plug the stereo jack to you laptop.
Oct 17, 2009 | Logitech X-530 Computer Speakers
Wiring diagram 1996 ford explorer premium sound radio f57f-19b165-ag
Here it is.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Sep 29, 2008 | 1996 Ford Explorer
48 people viewed this question
 Grubhead
Grubhead
