Question about Canon Office Equipment & Supplies
I have downloaded the installation software for the Canon MP110 for use with XP, the files are complete except for setup.ini. Where can I get that file from, Canon are not very helpful.
  • Canon Master
  • 11,800 Answers
The install files that you downloaded got corrupted somehow.
Select another server (or country) when downloading them. Like
Posted on Nov 24, 2014
  • Albert Ratcliffe Nov 25, 2014
    Thank you, will try that
How to download softwareto download software for canon mx310
You can download the software for your printer from this Canon Support site.Considering you have not indicated your Operating system[e.g Windows 7,Windows Xp,Windows Vista],you will have to choose it to download the corresponding drivers.
After the downloads,double click on the setup exe.to start the installations.
Follow the instructions untill setup completes/finishes installing.
Hope this helps.Thanks!
Please rate this answer.
Nov 02, 2011 | Canon PIXMA MX310 All-In-One Printer
I dont have a pc that takes a disc for printer setup...so how do i set up without a disc?
You can go to the manufacturer website:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp480#DriversAndSoftware
Select drivers and software and then select your OS (Windows XP, Vista, 7) and download your driver.
After the download is complete double click the file downloaded to start installation.
Feel free to let me know if this information was useful!
Regards
Nov 30, 2010 | Canon Pixma MP480 All-In-One InkJet...
Canon mp 270 drivers wont install
http://software.canon-europe.com/products/0010753.asp
used this link and download your driver and follow these basic steps while installing printer.
1) you need a printer driver cd or driver setup file.
2) run your setup file and follow the steps
3) while your setup is running connect your printer with your computer and give them power.
4) after installation is complete restart your system.
5) done.
u r ready for give print
Apr 17, 2010 | Office Equipment & Supplies
What is *.ini files ? how can i create it ? what is the use of it ?
.INI files are plain-text files that contain configuration information. These files are used by Windows and Windows-based applications to save information about your preferences and operating environment. "INI" stands for initialization.
Format of .INI Files.INI files contain one or more sections. Each section begins with a section name, which is followed by zero or more entries. An entry associates a keyname with a value. The general format is:
[section]
keyname=value
Comments can also be included in the file by prefacing the comment with a semicolon (;).
Windows and Windows for Workgroups use several standard .INI files for storing configuration information. These files are WIN.INI, SYSTEM.INI, PROTOCOL.INI, PROGMAN.INI, CONTROL.INI, WINFILE.INI, MSMAIL.INI, SHARED.INI, and SCHDPLUS.INI. Windows-based programs may also add sections and entries to WIN.INI, and they may add .INI files in the Windows directory.
Editing .INI FilesBecause .INI files use only plain text, they can be edited using any text editor or word processor. .INI Master also has a built-in text editor for making corrections in the .INI files you are diagnosing.
To create a custom Setup.ini file:
  1. Start the Setup INI Customization Wizard.
  2. Type the path to your Office XP administrative installation point, and then click Next. The wizard searches the specified network share for a Setup.ini file.
  3. From the administrative installation point, select an INI file on which to base your custom INI file. Or, click Browse to go to a different location and select a file. Click Next.
  4. Under Logging, select a logging mode, and then type a name for the log file or template. Click Default to use the logging mode that is specified in the INI file. Click Verbose to use all logging options. Note that verbose logging creates very large log files.
  5. Under Display, select a default display setting, and then click Next. The wizard searches the administrative installation point for additional packages (MSI files) that you can chain to the Office installation.
  6. Select the check boxes next to the packages that you want to include in your custom INI file, add packages or programs (EXE files) that are stored in another location, and then click Next.
  7. Use the arrow keys to determine the order in which you want Setup.exe to install the chained packages. The System Files Update package is always installed first (if required), followed by the Office XP package. You can change the order in which subsequent chained packages are installed.
  8. Select each package, specify the options that you want for that package, and then click Next. For each package, you can specify an MST file and a unique display setting, as well as additional property values.
  9. To add additional property-value pairs to your custom INI file, select a package, click Advanced Properties, type the properties and values that you want, and then click Next. The wizard displays a summary of the changes to save in the custom INI file.
  10. Click Save As, and then type a name and path for your INI file. The wizard supplies a sample Setup command line that specifies your custom INI file with the /settings option.
  11. Click Finish to quit the wizard.
May 12, 2009 | Microsoft Windows XP Professional
Canon mp240
Go to the canon site and download the xp drivers, remove the driver
and software, clean your registry, and reinstall the software and driver.
http://www.usa.canon.com/home
Pretty good registry cleaner for free,,
http://www.ccleaner.com/download
Apr 08, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Winodws xp can not compatible driver from installation CD
The latest xp driver for your printer can be downloaded here;
http://software.canon-europe.com/files/soft32111/software/LBP2900_R112_EN.exe
Apr 02, 2009 | Canon LASER SHOT LBP-2900 Printer
VGA driver can't complete due to missing system information
double click on the .exe file and install it.
go to strat>>control panel>> system>>device manager.
deleted the VGA and restart the computer.
let the cmputer find the .ini file.
Feb 09, 2009 | E-Machines eMachines Desktop PC
Problem in office 2007 setup
HI Deb,
You will need to update windows to service pack3 first. Then once completed click "start" and open "control panel" and then "Add Remove programs-software" Scroll through list of installed software and identify all and only the office related components "select" each component individually then click "remove/uninstall" Remove all previous installed office components, starting with the smallest sized file to the largest, once completed restart your machine and try the office install disk again. See below for service pack three download info and links:
Download the service pack manually You can use Windows Update or the Microsoft Download Center to obtain Windows XP SP3 online. Check for updates on Windows Update loadTOCNode(4, 'moreinformation'); To check for updates on Windows Update, follow these steps:
  1. Visit the following Microsoft Web site: http://windowsupdate.microsoft.com (http://windowsupdate.microsoft.com)
  2. Click Express (Recommended).
  3. If your computer is up to date, Windows XP SP3 will be one of the updates that is automatically selected. Click Install. If your computer is not up to date, Windows Update will offer some other updates that you have to install first. Install those, and then repeat steps 1 and 2 to obtain Windows XP SP3.
  4. For Windows XP SP3, review and accept the Microsoft Software License Terms.
Windows XP SP3 will be downloaded to your computer, and the Windows XP Service Pack 3 Setup Wizard will help you install it.
Download the latest Windows XP service pack from the Microsoft Download CenterIf you have problems obtaining the service pack from Windows Update, you can download the stand-alone update package from the Download Center. This page will say that this installation package is intended for IT professionals and developers. However, you can safely download this file. The following file is available for download from the Microsoft Download Center:
Download the Windows XP Service Pack 3 package now. (http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4)
Jan 23, 2009 | Microsoft Office Professional 2007 Full...
Bootup failure
Cause:
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows.
Solution:Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
  1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
  2. In the setup menu, type R to start the repair.
  3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
Dec 05, 2008 | Acer Aspire 3624WXCi Notebook
MP110/130 drivers for vista
You can download the drivers from Canon. Click on driver downloads and pick the Vista driver.
MP110
MP130
Jan 24, 2008 | Canon PIXMA MP130 All-In-One InkJet...
82 people viewed this question
old marine
old marine
