Door for AWM 1008 not opening - Washing Machines
  • 693 Answers
Hold the start button for at least 15 seconds after switching on...it may be child locked.
Posted on Nov 27, 2014
The door of my AWM 1008 washing machine is block,so how can I open it
Machine needs to drain to unlock door - verify that water has drained.
Nov 24, 2014 | Washing Machines
Hi. I have a Whirlpool 6th sense front loader 11kg washing machine (AWM 1008). After some very cold weather I now have an error code of FA. Do you know what this means and what I need to do? Thanks
Solution from a previous post i found for you.
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Most of the solutions i found for this same error were very similar. If all else fails read the manual or get a new washer when possible.
Feb 17, 2012 | Whirlpool Washing Machines
I can't open the door of my whirlpool AWM 5080. I attempted to open it too early and now it won't open at all.
attempting to open it early wont do anything to it, your problem will be your door lock is faulty and the coil inside that heats up to lock the door isnt contracting after cooling meaning your door stays locked, try unplugging it from the wall for 5 mins then plug it back in u may get lucky and it will open but its not likely this will work but sometimes does, other than that u need to find a new door lock
May 04, 2011 | Washing Machines
Sanyo stereo AWM-2700U, cd player says'' door'' just blinking.
Press Eject button while tapping on the top. It should open
Dec 28, 2010 | Sanyo AWM-2800 CD Shelf System
Whirlpool model AWM 6101 door wont open after washing has finished
the door can take anything up to 2 and a half minutes to open anyway but if it takes any longer than this, or will simply not open at all then you will need to get a replacement door interlock switch
May 29, 2010 | Whirlpool LHW0050PQ Front Load Washer
Changing brushes on whirlpool awm 8145/3. Washing machine stopped working and ''door open'' light keeps coming on and cycle stops. Cannot locate brushes to see if changing would help.
this door open light has nothing to do with the motor brushes its the door switch/s there are two of them try pushing your knee on the door if it starts working again change the switches and the brushes go into the motor?
Mar 10, 2010 | Whirlpool Washing Machines
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Hi, do you know where on a Bernina 1008 I can undo the top cover to clean the inside and get a ball thread out? I have worked out out to clean the bobbin area now I would like to clean the top...
Open the front door and, looking at the insides with the door hinge on the left, up inside, slightly to the left is a small shiny knob. If you press the knob, it releases a catch in the middle of the top arm and the whole cover will just come off. Replacing is just a question of pressing it back in place and the spring-loaded pin will retain the cover in place. There are no retaining screws.
Jan 11, 2010 | Bernina 1008
Whirlpool awm 6141 wont start any cycle as the door open light comes on. the door appears to be latching ok
when my washer is switched on it sounds like the motor is strugeling to spin to the right.
Jan 07, 2010 | Whirlpool AWM6141/1 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
