How do I locate the Exhaust fan on FP7115 Copier
  • 637 Answers
Please leave this to the trained technici
Posted on Nov 24, 2014
E805
Hello Peter; E805 is cooling fan problem;
0002& 0003is fuser fan, 0004 to 0006 is laser fan 0007 is exhaust fan, 0008 system fan, 0010 & 0011 low voltage fan, 0012 & 0013 reader fan, 0014 to 0016 drum fan, 0017 is controller fan, 0018 scanner fan.
Oct 06, 2012 | OCE 3140 Copier
Canon ImageRunner 330s Error E805, Can't Enter Service Mode
FM1 Heat discharge fan Cools fixing unit.E805 0000 Fan failure
only one in this copier>
The fan is faulty. -
Check the fan connector.
- Replace the fan.
- Replace the DC controller PCB.
Switching between full-speed rotation and half-speed rotation is controlled as described below.
1) Full-speed control
When the CPU on the DC controller outputs a fan full speed signal (FAN_FULL), the fan drive voltage switching circuit supplies a +24 V fan drive voltage to turn
the heat exhaust fan at the full speed.
2) Half-speed control
When the CPU on the engine controller outputs a fan half speed signal (FAN_HALF), the fan drive voltage switching circuit supplies a +16 V fan drive voltage to
turn the heat exhaust fan at the half speed.
E805-0000 (Main body fan error)
When the cooling fan of the main body starts, the fan lock detection signal (FAN_LOCK) has been held at the "H" level for longer than the prescribed time.
also check your low-voltage power supply
Apr 22, 2012 | Office Equipment & Supplies
My copier is having a system error E-805
- Replace the fan.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 31, 2011 | Canon iR 2016i Black and White Copier
Please, I need help with Richo MP7500 with error
SC534 D Fan error 5: duplex exhaust fan
The lock signal remained HIGH for 5 sec.
while the fan that draws air out of the duplex
unit was operating.
• Motor overload due to
obstacle interfering with
operation of the fan
• Fan harness loose,
disconnected, defective
• Fan defective
Jul 28, 2010 | Ricoh Aficio 1013F Copier
My imagerunner 1023iF is displaying error message E805
Check if the exhaust fan near the fixing unit is working,this error indicate problem on exhaust fan,could be stuck up or dirty
Jul 01, 2009 | Canon imageRUNNER 1023iF Black and White...
Noisy Fan on Copier CS-3035
actually fan really works even at sleep mode to exhaust heat, the problem is one of the three fan located at the left side if your facing the machine, is deffective a broken blade causes it to sound bad try to remove its connector, afer all you have two more working
Nov 01, 2008 | Copystar - CS-3035 Printer
Error code sc 490 and sc360
Did you try to rest the error? Do you know how too?
Feb 09, 2008 | Ricoh Aficio 450 Copier
26 people viewed this question
jasbo
jasbo
