Question about Neff Ovens
Have a neff t1213xo, what does black grey and brown wires stand for?
  • 1 more comment
  • Alna Katinaite
    Alna Katinaite Nov 24, 2014
    I am having a problem of not knowing which wire (grey brown and black) to connect to what cables as the other end has these: green and yellow, black and brown, white and blue.
  • Alna Katinaite
    we are in UK,
  • Alna Katinaite
    its electric hob
    Problem Solver:
  • 4 Answers
You have an hob with European three phase at 220volt mains wire connected.
You need to to disconnect from mains connection box on hob and fit conventional British brown, blue and green/yellow.
Inside the connection box you will see three live terminals,(L1,L2 & L3) there are usually some brass links to join them all up and then attach brown core to one of them. If the links are not there then you will need to fit 2.5mm links from a piece of wire.
Posted on Dec 01, 2014
2 Suggested Answers
  • 2509 Answers
SOURCE: need to know what color
Please detail your equipment, problem and your country as the answer depends on all those things.
Posted on Mar 06, 2011
Hi, Looking for a wiring/electrical diagram for Neff D39F56S0GB Extractor hood. Or could you Kindly point me in the right direction. Thank you
You can find the manual here:
D39F56S0GB/01
and here:
D39F56S0GB/02
It should come with a cable attached which should conform to standard wiring colour codes.
Red/Brown = Live/Feed
Black/Blue = Neutral/Return
Green/Green & Yellow = Earth
If the standard cable has been cut off there is a good chance it was for a reason and you shouldn't try to connect it without knowing how to determine which contact is for which (an electrician/electronics tech will know within seconds what should be connected where.)
Mar 07, 2015 | Neff Ovens
Belling cooker d841 top oven
The US National Electrical Code only mandates white (or grey) for the neutral power conductor and bare copper, green, or green with yellow stripes for the protective ground. Power will generally be black or red. 3 phase power will have three colored lines, the first is generally black or brown, the second red or orange, and the third blue or yellow..
i,e,
Yellow/Green is Earth so 'E'. Brown is live so 'L', and Blue is neutral so 'N'.
May 08, 2012 | Belling XOU174 Electric Single Oven
Our 10 year old neff U1421 has just gone bang and has blown the fuse and left a white/grey film covering the complete inside of the oven. Is this repairable and if so, what part/s do I need?
sounds like the element has burned a hole through itself,, check with a local dealer for the element,, be sure to replace the contacts at the wires when replacing
May 22, 2011 | Neff U1421 Double circotherm Electric Oven
Need to know what color wires mean green yellow blue brown grey black which color correspondes to L1,L2, L3, earth terminal,and safety wire terminal.
Mar 06, 2011 | Ovens
We are having a neff oven U15M62NOGB fitted. The wires in the booklet are earth on the left, live in the middle and neutral on the right. Is this correct as the neutral and live are the other way round on...
Yes, the installation instructions are correct. The wiring from your old oven isn't relevant.
Your query is a little confusing though. The new oven should have a power cable attached to it for connection to the mains supply. This should be on a separate circuit from your sockets and connected to an isolator switch. The wires in the power cable are colour coded to ensure that they are correctly polarised when connecting to the mains supply. I'm assuming you're in the UK as you list a GB model number, therefore, it should have a BROWN wire for LIVE, BLUE for NEUTRAL and GREEN/YELLOW for EARTH.
If your house wiring uses the old red (live) and black (neutral) colour coding, then you just need to ensure that the brown (live) wire from the oven lead is connected where the red wire from the supply is terminated. The blue (neutral) wire should be connected where the black wire is terminated and the green/yellow (earth) wire should be connected where the green wire is terminated.
Internally, the oven probably uses red cable for live and black for neutal, but you really shouldn't need to be doing anything with the internal wiring to install the oven.
You say you are having it fitted. Any competent installer would know (or check) the correct wiring order even if the instructions were missing. If you are installing it yourself, be sure are certain you understand what to do before attempting this and double-check the power for the oven circuit is off before you start.
Please rate this solution if you find it helpful. Thanks.
Oct 16, 2010 | Neff B1421 Electric Single Oven
Neff oven internal wiring colours
red is positive and black is neutral normally on these ovens, dont recall seeing blue and lilac.
Apr 15, 2009 | Neff B1421 Electric Single Oven
Neff fan oven heater element
hi there the solution is simple neff have done away with the earth connection on the element it's now earthed through the screws which hold it in place to the cavity just tape the earth with insulating tape and secure out of the way of the fan, hope this is of some help
Mar 30, 2008 | Neff U1721 Double circotherm Electric Oven
Neff Fan Oven Element _U1661
hi there green and yellow is allways the earth connection which is usually the middle tag, what are the colours of the remaining wires and how many are there???
Feb 08, 2008 | Neff U1661 Double circotherm super...
Ovens Logo
109 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
