Question about Roland Boss RC-30 Loop Station Twin Compact Pedal with USB
Hey my boss RC-30 loop station is freezing on me and none of the buttons will function, it resets when I turn it off and turn it on again, but this is not ideal as I'm a solo musician doing gi
Turning on and off, this works but not ideal, I shouldnt have to worry about this issue while I'm on stage. The pedal is brand new
My RC 30 was doing exactly this. I visited the Boss Support site and followed the procedure to display the version of firmware, mine had Ver 1.50. The latest is 1.60. I followed the procedure to update the firmware to 1.60 and I don't have this problem anymore. I suspect this is an inherent issue with the factory release vers 1.50
Posted on Jul 01, 2016
    Problem Solver:
  • 16 Answers
Send it back. .. it's faulty. Seriously
Posted on Nov 26, 2014
When i press the record button for overdub, the light doesn't turn on. how can i fix the light?
It's doubtful that the LED itself is burnt out, so it's most likely a problem in the circuit. I doubt it will be user-servicable, so take it into the repair shop.
Apr 23, 2016 | Roland Boss RC-20XL Loop Station Twin...
When i plug the cable in my boss rc-20 it turns on and instantly it turns off, how can i fix that?
I would suggest cleaning the input jack, and if that doesn't fix it, replacing the jack.
Apr 22, 2016 | Roland Boss RC-20XL Loop Station Twin...
Boss troubleshooting
if your using it from the battery ck that the wires are tight connected and the battery clips are tight (both ) if the electronics senses a very quick power interruption then yes it will reset the loop back
Jul 31, 2014 | Boss RC-3 Loop Station Pedal
My RC-50 suddenly won't power on.
Has the unit ever had another ac adapter plugged into it?
Mar 04, 2013 | Boss Rc 50
Hello - I have a Boss RC-2 Loop Station. While I enjoy the pedal's capabilities, it almost always creates an unwanted hum and sometimes an electronic pulse in every amp I use it with. (I typically keep...
Make sure the power supply for this is powered from the SAME receptacle as your amplifier is powered. Keep the cable from this to the amp fairly short and high quality cable. Keep guitar away from magnetic field sources... the wall wart adapters are notorious for generating magnetic fields.
Jul 20, 2011 | Roland Boss RC-2 Loop Station Stompbox...
I have the Roland Boss Rc-20xl Loop Station, and I'm running off of batteries I have been since I got the pedal. In the middle of recording a phrase the pedal shut off and started resetting itself...
Hello!
I am not positive on this but I would try to clear all of the loops. Try holding the right pedal for about 5 seconds.
If that does not work, hold the right pedal for about seconds while you turn off the unit. Release the right pedal then turn the unit back on.
Hope that helps!
May 11, 2011 | Roland Boss RC20XL Phrase Recorder Pedal
When I turn on my BOSS RC-20XL Loop Station the reverse, tap tempo, write, exit and one shot phase start to blink rapidly and I cannot get them back to normal. Therefore, I am unable to use my loop...
Hi. I had the same problem and fixed it by clearing all the phrases. An explanation of how to do this is below (written by someone else, not me) But, expect your guide beat to now sound like a fuzz instead of a drum. This really sucks and there is apparantly no fix for the guide sound except to send it back to Boss. Good luck.
1. Start by selecting Phrase 1.
(if the 'REVERSE' or 'AUTO START' are lit press them off.)
2. Select 'INST & MIC' by pressing 'MODE'
3. Hold down 'EXIT' and 'AUTO START' together - at the same time, this should light up the green LED for 'LOOP PHASE'
4. Hold down 'WRITE' and 'EXIT' together
then hold 'WRITE' on its own
then 'WRITE' and 'EXIT' together again...as if you were clearing a phrase.
they should light up in red and flash, if not try a combo of section 4.
5. Repeat on all Phrases 1 - 11.
Mar 24, 2011 | Roland BOSS RC-20XL Loop Station Phrase...
How To Turn Drum Beat Off
From what I remember from my recent tinkering you press the guide select button. Then either use the patch/value know and parameter buttons, OR it may be the guide level knob to switch the volume down until it is off. I believe I then saved the patch to preserve the setting and keep that irritating guide at bay! It really should be more intuitive, ideally knod turned to zero = OFF. But no. Ah well, hope you get it sorted. I have a problem too, maybe you have same one? It may be the unit itself. Search - Beggining of loop missing on FIRST playback - if you get a chance. Let me know if yours does it too?
Mar 06, 2009 | Boss Rc 50
Roland Boss RC-30 Loop Station Twin Compact Pedal with USB Logo
970 people viewed this question
Top Roland Computers & Internet Experts
Stu Morris K
Gil Shultz
Tom Chichester
Are you a Roland Computer and Internet Expert? Answer questions, earn points and help others
