Question about Fisher and Paykel Dishwashers
F&P two drawer dishwasher 2012 shows error message E7 for top drawer only and when start/stop button pressed shows 02 on LCD display. Help!
Followed reset as described in manual - doesn't do anything
  • 21 Answers
From the service manual:
E7 = Detergent diverter fault
• Check harness connections
• Coil is open circuit
• Coil is short circuit
• The electronic controller has failed
The 02 part means:
Under current
• Wiring to detergent diverter valve
• Open circuit coil
If you are not happy testing electrical circuits and replacing parts yourself then you will need to contact an engineer.
Otherwise, I have a copy of the service manual if it is need, just need to find a link where I got it from.
Posted on Nov 26, 2014
  • 641 Answers
SOURCE: error code AO1
Error message A01 means -Acqua stop operated due to a leak or overfill. Check if there is still water in the machine after it stop pumping. In case you still have water - your problem is with the pump or with a blockage drain line. If there is no water in the machin, it might be a water level sensor issue - stuck physically in the high level position or become defective. Try to reduced the water presure and leveled it up by the water entrance tap to the machine, it might solve your problem. Goog luck !!
Posted on Jun 27, 2006
stephanos18
  • 144 Answers
SOURCE: f3 error showing
F3 means the Dishwasher thinks it's water temperature in the tub is over 80oC. So when the unit stops see how hot the water is. The unit has a temp sensor which is part of the element which maybe faulty, the element maybe faulty or the Motor controller module is faulty. I'd try the Motor Controller module first as replacing the element can be a tricky job if you haven't done one before. If you have a double dishdrawer you can swap over the Motor Controller modules (main computers in the front of each drawer) as the top and bottom are the same part, inturn you will prove 100% if this is the fault or not without buying a new controller. Cheers
Posted on May 31, 2009
  • 3247 Answers
SOURCE: we have a 23" Fisher&Paykel dishwasher and got
The F1 error coming on top drawer when operating bottom drawer is due to the thermal fuse blowing up on the bottom drawer and shutting controller power.
The thermal fuse could have blown either as a normal component failure or heater over heated due to thermostat failure. In any case this can be repaired by replacing the whole heater assembly as all the parts are integrated.
This is at the underside of the drawer and will need a technician to replace unless you are very familiar with repairing electronic dishwashers. The part look like this.
The way you have described the onset of the F1 error is not due to flood switch. You can confirm that the lights on the bottom drawer are out even though the top drawer is showing F1 and beeping.
If problem was flood switch then both drawers would show F1.
Posted on Nov 28, 2010
Macmarkus
  • 2605 Answers
SOURCE: Re: Model # 665-17039401. Clean light
Hello, Welcome to FixYa.
Based on your description, "clean light stays on" this is actually an error code as you may or may not know associated with the heating process. What typically happens is poor water circulation preventing the water from heating properly.
To resolve this, I'd start with the following...the wash pump area. You`ll need to follow these steps to clean it.
1 ) Remove the turbo wash tube if applicable to your model, it pulls off, i.e.
2 ) Spray arm removal. hold the center nut and spin the arm.
3 ) Now you can remove the upper spray arm supply tub or referred to sometimes as "rear feed cap".
a ) lift to depress the rear tab, i.e.
b ) Then twist the feeder to the right ( clockwise ), i.e.
4 ) Now you can remove the center nut...
Then remove the four # 20 torx head screws holding the filter in place, and lift the filter out.
Below the filter you`ll find food debris, undissolved detergent etc, but also a cover with a single #10 torx head screw to remove and the cover will pull straight up and out. the arrows from left to right in the image indicate...
1) screw location
2) tab to pull up on
3) the latch you may need to twist to the left to remove the cover
i.e.
Now you should see the chopper and screen assembly, it too can be clogged up pretty bad, clean it best you can...you don`t really want to remove this part.
If my explanation is not clear enough, here`s a link which provides a pretty good video of how to do this, these guys aren`t pro`s but the "how to" video is pretty thorough nonetheless.
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
Once these actions have been performed you'll need to clear the error code. to do so is as follows.
Press the following buttons in this sequence...
HEATED DRY - NORMAL, HEATED DRY - NORMAL, HEATED DRY - NORMAL
This diagnostic cycle may take approx. 15-20 minutes to complete. Let it proceed through to completion and you should be good to go...unless the heater itself is at fault or a wire has vibrated loose from the heater...those are steps to follow if OR when necessary.
Let me know how you make out, please keep me informed if you need further assistance or anything is unclear. Please take a moment to rate me assistance and a short testimony is appreciated as well.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on May 10, 2011
  • 552 Answers
SOURCE: I have a two drawer
This is a flood error code. The bottom drawer needs to be removed to dry up the water. The video below explains how to do this. It's actually pretty easy.
Posted on May 25, 2011
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems Posted on Aug 16, 2016 -2017
Jul 29, 2016 | Sharp Ar 5316
I have a Singer 7285Q sewing machine that comes up with a "E-7" message and the machine won't work. It only happens when I use "back stitch" button. My instruction manual has no mention of an
E7 means
The start/stop button, reverse/reinforcement stitch button
or the thread cutter button was pressed while no thread
cassette was installed. If the start/stop button is pressed before the sewing machine is correctly set up or if an operation is performed
incorrectly, an error message appears in the stitch indicator. Follow the instructions that appear.
If you press (Stitch selection key) or do the operation correctly while the error message is displayed, the
message disappears
Oct 30, 2014 | Singer Sewing Machines
I have a Fisher Paykel 605 double DD. I have an F2 error message. There was a frozen rotor, likely from disuse over the winter. I replaced the rotor and it still stops and shows the F2 display. There
Not sure if you have fixed the F2 problem yet. The rotor cavity may look clean but sometimes there is a piece of bone or seed stuck inside the channel connecting rotor cavity with pump sump. Take the rotor out and the drain filter out. Take a rigid thin wire and run it inside the channel connecting the two.
Also get some white vinegar and with a tooth brush rub it inside the rotor cavity to ensure all dirt is removed. The rotor speed sensing is done by the hall sensor sitting underneath the cavity. It is not visible from top. The sensor could be reading incorrectly. IF still no luck then Run in diagnostic mode - (but make sure you do not try any other function than what is mentioned here otherwise you could damage dishwasher).
DishDrawer Diagnostics can
only be entered in Power Off mode, ie. When there is no display on the LCD or the
badge LED's are off. Diagnostics is entered by holding the
Keylock and Start/Pause buttons simultaneously for 5
seconds. Ensure that
Keylock is pushed first.
All LED's and LCD segments (except keylock) are illuminated. Press Power button and display shows HO in red background. Press Start/ Pause. You are now in hardware diagnostic mode. Open drawer so that you can see inside. Press Start/ Pause a few times until FU shows on display. At this point press Keylock and water should flow in. Press Keylock to turn inlet valve off after water is collected under the wash arm (don't cover wash arm). Press Start/ Pause again and P1 will display. Press Keylock to turn rotor motor on and water will swish around. Press Keylock to turn motor off within a few seconds otherwise flooding could occur. Next press Start/ Pause once so P2 displays. Press Keylock to run rotor again but this time it will pump out. Let it run until the water is pumped out. Press Keylock to stop pump. This should test the rotor in both forward and reverse direction.
PRESS POWER BUTTON ANYTIME TO EXIT DIAGNOSTIC
If the hardware test worked ok then turn mains power to dishwasher off and on and start normal wash cycle. If there is still an F2 problem then hall sensor is faulty and needs replacement. Not easy to do and best left to technicians. By the way each dishdrawer has separate controller - so one drawer could be working fine and the other not.
May 10, 2014 | Fisher and Paykel Dishwashers
E7 error message Singer Patchwork
I used can air and blew out the reverse button area. Worked immediately after turning off and back on.
Mar 23, 2014 | Singer 7258 Sewing Machine
Fisher & Paykel dishdrawers - no power at all to the top drawer
Try and do a power reset to the dishwasher. This means turn the mains power off to the dishwasher and back on again. If there is no mains socket under the kitchen bench then maybe do this from the mains contactor switch in the meter box. If there is no difference to the behaviour of the top drawer then the controller has most likely packed up. You can test things out by taking controller from bottom drawer and putting in top drawer. But this requires some experience with taking out the front covers of the drawers, taking out the connectors and putting back. If you mix the connector connections etc you can cause more damage. Take photos as you go along. Make sure the dishwasher is disconnected from mains power when you are working on it.
Feb 16, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
We have a 23" Fisher&Paykel dishwasher and got
Nov 25, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Haveing a u3 code on my top draw of my fisher & paykel any help on this
First have the unit turned off. Then open up the drawer that,s giving you trouble.
The badge ought to be lit.
Now simultaneously press the static touch pads on each end of the led status lites (the ones on the drawer top?) (Cycle Select, and Eco-sensor pads)
Hold them for about 5 seconds.Now If you have a metal front machine, the badge display will either show HP or LP. Assuming you have normal water pressure about 50 - 70 psi you want to select the HP setting.
Do that by pressing the start button till you get what you want, then press power off to lock the setting in.
Mar 06, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hi We have a problem with our Fisher &
First is to make sure there is no leak. Pull out the lower tube, access from the left side only this side you can put your hand in with a small tower to dry out the wetness if there is. If it is wet dry out really good then unplug the power cord for 24 hr. After that plug power cord back. Hold the lock button while press the Start button until you see a display appears. Press the Power button to see a clear display. Then hit Start button one by one until you see Ld ( it stands for Lid down) If you miss it, keep going until it comes back in a loop. When at Ld hit the lock button. Wait until the noise is stopping. Hit the lock button again. Wait until the noise is stopping. Now you can pull out the top drawer and press the power button to get out this manual mode. Good luck.
Dec 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water will not drain out of top drawer
To determine if your pump work, before attempting access from the bottom of the top drawer: You can manually pump the water out by doing the following:
1- Press the Power button to turn off the display.
2- Press the Lock button and then the start button the same tim. Hold them until the display showing up.
3- If the display is not clear with all the characters, press power button to see clear the display.
4- The first display is bL, then Er,Ld..dd, FU, P1, P2...by pressing the Start button to go by the sequence until P2 (drain). If you miss, be patient to continue press and release the start button to get back to P2.
5 When is is at P2, press Lock button to tun on the drain. When you hear the water flowing to the drain, you could pull the top drain to see how the water is draining.
6- When the water is out, press the lock button again to stop it.
7-When it is done, press the Power button to get out of manual mode.
If this is working, then your water is there because you are running the bottom and your air gap allow back flow to the top drawer.
Please let me know if this is not the case.
Jun 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water won't drain
To determine if your pump works, before attempting access from the bottom of the top drawer or from the bottom of lower drawer: You can manually pump the water out by doing the following:
If this is working, then your water is there because you are running the bottom and your air gap allow back flow to the top drawer and or you are running the top and your air gap allows a back flow to the bottom drawer.
Dishwashers Logo
85 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
