Question about Kyocera Mita KM 1530/ 2030 Copier Machines Compatible KP23153 Black Toner Cartridge 106153
<!-- from fixya rte -->Call for Service ...... C710 - Kyocera Mita KM 1530/ 2030 Copier Machines Compatible KP23153 Black Toner Cartridge 106153
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kyocera Master
  • 884 Answers
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Nov 24, 2014
C710 Code on Copystar 2030
C710 Interrupted Communication at the Destination. If you're the sender, it's happening outside your machine. Most likely, phone line.
Feb 20, 2008 | Copystar CS-2030 Copier
Manual for acer c710 chrome book
Go to http://us.acer.com/ac/en/US/content/drivers. Input your model C710 and click on the documents tab. Or, go here https://docs.google.com/viewer?url=http://static.highspeedbackbone.net/pdf/Acer%2520C710-2055%2520Chromebook%2520Manual.pdf&chrome=true
Mar 07, 2014 | Acer Aspire C710 11.6" LED Chromebook...
What does C710 stand for?
GO ON LINE AND TYPE
KYOCERA COPYSTAR CS-1820 ERROR FLASHES C710
ENTER
GO ONLINE AND TYPE THE FOLLOWING INFORMATION
MANUFACTURE NAME,MAKE,MODEL SERVICE GUIDE AND DRIVERS
ROD
Feb 09, 2009 | Kyocera Copystar CS-1820 Black and White...
Royal copier service code
Royal copiers are kind of old... But I believe that a C710 means that a charge corona wire is arching out or it could be broken. The fix I use to do is to clean the Primary & the Transfer corona wires carefully and pree the reset botton and see what happen. It could be a problem wit the HVTDC, but you may fix it with just cleaning the corona wires.. Good Luck
Nov 07, 2008 | Office Equipment & Supplies
Error c710
Your problem could be one of several things:
1) The Carrier (iron filings) inside the imaging unit is deteriorated and needs to be replaced.
2) The Toner sensor inside the imaging unit may be giving an incoorect reading, due to be faulty or because of old toner/carrier mix blockage close to sensor. Give the imaging unit a good service and replace the carrier.
3) The wires behind the black cover of the imaging unit have been picnhed and is shorting on the metal plate
4) The main PCB of the machine could be faulty
May 27, 2008 | Office Equipment & Supplies
C710 Toner sensor problem
Try removing and refitting drum and toner.
if this does not help you may have damaged your toner cartridge or the sensor
Error appearing on screen C710
Did you disconnect telephone line?
C710: Interrupted Communication at the Destination.
Feb 15, 2008 | Copystar CS-2030 Copier
Kyocera Mita KM 1530/ 2030 Copier Machines Compatible KP23153 Black Toner Cartridge 106153 Logo
237 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
