Instalion new casste
End ribben and new casste
  • Grand Canyon Tech
    Grand Canyon Tech Nov 26, 2014
    Hi Hemant saini, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Need to install a starter on a tractor,have a new one to put oni woulr like a detaited diagram of the instalion
need to install a starter on a tractor,have a new one to put oni woulr like a detaited diagram of the instalion; tefal actifry manual replacing the element tefal actifry ..
Sep 17, 2011 | Computers & Internet
Tip
Samsung phones
Hello there Samsung slider phones LCD or screen problem. Always you have seen that samsung phone get problem like some phone doesnt have light in LCD and some times they does not turn on. Samsung slider phones like G 600 , U 600 . J 700, E250 ,D800 and D900.Slider phones always has Ribben ( slidr belt ). And this ribben always connect phone upper part ( screen ) to the mother board.when the ribben (slider belt) got damage then it gives you that problem.it happens when you use your phone roughly or when you dropped your phone on concrete or any different floor.Mostly Samsung phone model U600 , G600 AND J700 has this problem.whenever your phone gets this problem firstly check. And Do not try any flashing or any kind of software tools. it easy to change ribben (slider belt ). Just get ribben belt or some tiny screw driver and some slider opener. this tools are easy to get from any tools shop. then mostly phone has screw. firstly open the battery cover and take it out and see two hole under the battery and when you slide up your phone then you can see two screw just under your phone top keypad just hold the slider for while and open those screw and slide up then see two rubber things are both side on camera. Use any flicker type things and take out that rubber top then you can see two screw just under the screw open those screw then use the slider opener if the opener is tight if slider is loose the do not use opener just take it out so softly and remove the one side of the ribben which you can see connected of mother board just take out ribben and put new one ribben the put all things back as a normal then tight the screws and put battery then turn it on your phone will turn on.some phone like U600 ,j600,has touch panel. this type of model slider belt or ribben always comes with touch panel and its quite difficult and quite expensive to change.Samsung U600 has this problem mostly because they are very thin and then slider belt is as well thin and they get this problem so quickly.
thanks
on Jan 08, 2010 | Cell Phones
My ribbion isnt printing
may be ribben is not right position or INK may be evoprated by long time of use ,plz check ribben position ,if its correct try to replace with new one
Jun 24, 2010 | Brother EM-630 Typewriter
I have a samsung SGH - J600 and the touch sensitive buttons were working untill half an hour ago. Is there anyway to fix the problem
j600 samsung has slider belt called ribben problem when ribben got damage then it stop working the ribben ( slider belt ) connect the internal connection. try to contact nearest service provider.
Mar 31, 2010 | Samsung SGH-J600 Cellular Phone
MY SAMSUNG PHONE TURNS OFF AND TURNS BACK ON BUT NOT ALL THE WAY. I NEED HELP!!!! WHAT WRONG WITH IT??
it happens with samsung sliders phone. because sliders phone always connected via only thinn ribben. which is connect the screen and mother board. when the ribben gone damage then samsung phone do thins things that turn on and turn off itself. if your phone is slider samsung G600,U600,J600 and j700 then it could be the ribben problem.
Dec 30, 2009 | Cell Phones
The keys on the slider don't work properly. I press them but nothing happens. So the arrow keys and two side buttons (call and hangup) don't work. Also, when I slide the phone shut, the white lights on the...
it is the slider problem which is called ribben problem. u 600 phone is so thinn and samsung they putted so thinn ribben in that it goas damage so quickly. try to change slider or ribben.
Dec 30, 2009 | Samsung SGH-U600 Cellular Phone
My screen went blurry and now even though the phone works, it is totally unuseable because I cant make out anything on the screen
samsung s 8300 showes this thing when it has ribben problem ( the ribben thing which connect slider to phone mother board ) please send your phone any samsung service cetre o any phone repair shope
Dec 23, 2009 | Samsung S8300 Ultra Touch platinium-red...
Printronix 5005.ribben not install
Please contact me, I need more information.
Thanks
Rory Cardenas
Midrange Repair and Parts
3821 W. 127th Place
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Jun 11, 2009 | Brother DCP-7020 All-In-One Laser Printer
Were
hi i have a ribben for clarion vrx755vd if you want to buy it email me at davisralph53@yahoo.com
Apr 10, 2008 | Clarion VRX755VD Car DVD Player
k24674
jasbo
jasbo
