Question about Dishwashers
I have just fitted a 2nd hand Blanco BFDWC61SS that has had little use but sat idle for a long time, everything looks like new but after you start it it runs for a few mins then the RCD in the house f
So far I have turned it off and gone to the fridge and cracked a beer.
The internal heating element is gubbed and needs replaced or a seal has failed and water is somewhere it shouldnt be it could be a pump housing that has an issue but my bet is the heating element
Posted on Nov 24, 2014
  • 108 Answers
SOURCE: problem with hotpoint aquarius fdw60 diswasher
My mother has a neighbour who has a new hotpoint dishwasher which caught fire inside (Plastic on door front melted!).
Please contact Hotpoint - if yours is new, check to see if they can replace immediately otherwise its worth booking the engineer to sort £90 - free parts on machines less than 5 years old.
Posted on Feb 27, 2008
osborne382
  • 306 Answers
SOURCE: Blanco Dishwasher BIDW605 does not
I would check the hose/water filters. make sure that you have proper flow from the hoses
Posted on Apr 04, 2008
mattozan
  • 555 Answers
SOURCE: motor runs but
Do you have a print manual for this unit?
Posted on Aug 05, 2008
mmoorree
SOURCE: KitchenAid Dishwasher Door Pops open during cycle
The problem seems to be the loosening of the screws that hold the interior stainless steel skin to the door frame--not the latch.
With the door in the open position you should find a total of twelve screws (5 on each side and 2 on top at each side of the latch). The screws have a particular type of head which may require a trip to the hardware (its a $1,000 dishwasher take the time to get the right screwdriver). They are called TORX screws the size on my dishwasher was a T 15. These type of screw heads were designed to fit automated torque drivers at the factory that set the screws to the proper tension. So some care should be given when you retighten them. Turn until the screw is snug and there no movement of the inner door skin but don't over tighten. Giving it that extra 1/4 turn can be enough to strip the screw out and create a bigger problem.
Yes--you shouldn't have to be doing this to a KitchenAid appliance that cost this much--but I suspect that this will become a feature of periodic maintenance. The heating and cooling generates enough movement that overtime these screws work themselves out. My wife who was the once to make the right diagnosis noticed that the screws at the bottom were almost entirely out.
Posted on May 07, 2009
tbirdfan1
  • 3051 Answers
SOURCE: water leaks between motor and pump can't get motor off
hello there this may help you out ok
best regards michael
Leaking Pump in a Whirlpool DU810DWGQ1 Dishwasher by Samurai Appliance Repair Man
function ReferThisPage779b7841ed943a9e880964fef6da376b(){var rtp;rtp = window.open('http://www.tellafriendking.com/refer/?URL='+escape(document.URL)+'&CODE=779b7841ed943a9e880964fef6da376b&JS=1','_blank','width=350,height=530, resizable=yes, status=yes, scrollbars=yes');if((null==rtp)||'undefined'==typeof(rtp) ){alert( 'The \'tell a friend\' window was prevented from opening.\n\nPlease temporarily disable your popup blocker.');}rtp.focus();}document.write(""); rn-spa-g.gif document.write(""); 3548679745_8c188ff0d2_m.jpgLeaking Pump in a Whirlpool DU810DWGQ1 Dishwasher
These are cheesy, inexpensive dishwashers that are prone to leaky pumps, as shown here (click the pic for the larger, annotated view).
3548734637_17f81a0e1b_m.jpgWhirlpool DU810DWGQ1 Dishwasher Pump and Motor Diagram
The problem is usually a leaky shaft seal kit, shown here as Items 7 and 8 (click the pic for the larger, annotated view).
Fortunately, the shaft seal kit is inexpensive; but it can be a ****** to install, depending on how much rust you’re dealing with. May require a destructive removal of the impeller, too, but ain’t no thang ‘cuz the shaft seal kit comes with a new impeller. Here’s a nice, purdy picture of a brand new shaft seal kit. And just to help motivate you a little more, the money you save from replacing just the shaft seal vs. replacing the entire motor-pump assembly is well over a Benjamin. So you go ahead and drill, cut, and chisel all you want on that old impeller!
wpl-dw-horiz-pump-shaft-seal-kit.jpg And Whirlpool just came out with a spiffy new DIY repair manual for this dishwasher, which will assist you mightily in the many repair adventures you are certain to have with this dishwasher:
whirlpool-dw-diy-manual.jpg To learn more about your dishwasher, or to order parts, click here.
Posted on Sep 15, 2009
Blanco oven bso 422w..The thermostat light "C" will not go out when everything turned off
DO YOU KNOW WHAT THE C STANDS FOR? DOES IT STAND FOR CLEAN? IF SO MAYBE YOU NEED TO CLEAN YOUR OVEN IF NOT LOOK UP ON LINE TO FIND MANUAL. TYPE IN BLANCO BSO 422W MANUAL OR MANUAL FOR BLANCO BSO 422W.
Jan 28, 2015 | Blanco Ovens
Looking ahead
To convert the sat nav you just have to replace the card
Jul 07, 2008 | 1998 Nissan Altima
Rebuilt a Stihl TS400 concrete saw, and now it wont cut, the engine dies down and has no power but revs up? Ive tried everything!
All these people are missing a basic thing: check the compression. If you did all thus work yourself, you may have reused the head gasket or not installed the new one correctly. It will run with no load, but once force in exerted, the pressure finds the leak and exploits it. There is a reason 2-cycle engines run at 130-160 psi normally.
Dec 27, 2012 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Blanco bfdwc61ss dishwasher wont finish washing in any cycle...its doesnt stop, just keeps going and going...it went all night without stopping and the dial didnt move...can you advise what to do??
please see the causes and fix it: God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer / electronic control.
Jul 21, 2012 | Dishwashers
Blanco oven door wont close properly. Grandchild sat on door while open.
the hinges are bent and the catch out of aliament ,remove hinges,straighten where bent and catch should work
Jul 07, 2010 | Blanco Classic Single Handle Faucet with...
My 97 getta GT won't start. It sat for 1 year so
if starter doesn't engage, replace the starter.
Mar 19, 2010 | 1997 Volkswagen Jetta
Dishwasher tripped our main circuit breaker.
It may be that your water pump is leaking on to the motor...
Dec 09, 2009 | KitchenAid KUDR01TJ Dishwasher
Leaky Blanco Single Lever Kitchen Faucet with separate sprayer
you can call or e-mail the company, if the faucet is the one in the picture it is a single cartdridge, turn of bith hot and cold water, take an allen wrench into the little plastic cover to remove the handle , unscrew the top cover or it might pop off, that there is either a large lock not or 3 screws holding down the cartdridge, take it out replace it put some faucet frease around all rubber gaskets then install it in the smae way it came out
May 30, 2009 | Blanco Classic Single Handle Faucet with...
Washing machine will not start
It is your central control unit...........try ing hitting the top with hand toward the back of machine sometimes there is a short in the CCU and a little shake will correct
Apr 06, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Dishwashers Logo
63 people viewed this question
Top Dishwashers Experts
