Question about Electric Tools & Hardware - Others
The locking lever of my Woolworth's electric staple and nail gun is broken: where can I buy a new one?
rowdy45176
  • 2176 Answers
SOURCE: When I load the nails, they do not sly to the
Could be couple problems, the magazine, nail carrier is slightly bent or wrong nails is there enough spring pressure on the pusher? and maybe some foreign object in the magazine. Take a look and let me know if you need more assistance
Posted on Sep 12, 2009
SOURCE: I think a staple is stuck and have lost the instruction book
I decided to leave it, as I no longer need the staple gun
Many Thaks
Posted on Oct 03, 2009
  • 288 Answers
SOURCE: How do you load nails into a stanley tre550 nail
there should be a button on the bottom rear of the gun, when you press it, it should release a bar that you pull back. the nails go in the dirction you nail them. sometimes the clips are too big for the guns and you have to break about an inch off of them
Posted on Dec 06, 2009
blueextc3221
  • 15935 Answers
SOURCE: how do you load nails?
The staples are NOT loaded on top of the pull out shaft; they are inserted directly into the slot that opens when you pull the shaft out. If the nose of the tool is not placed firmly against a surface, it will not fire.
CLICK HERE
and click the PDF icon on the right of the model # to start the download.
Here is a step by step:
Unplug the tool.
Squeeze the end of the shaft at the rear bottom of the tool and pull out the shaft.
Flip the tool over on it’s back.
Insert the staples, (points up) and then slide the shaft back in.
Plug it in, press the on button (under the the power cord in the back). Press the nose squarely against the material and press the trigger
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Mar 06, 2010
  • 1116 Answers
SOURCE: how to load brads into stanley tre 550 electric
HOW TO USE YOUR ELECTRIC STAPLER/NAILER
TO LOAD STAPLES
1. Unplug tool, (fig. 1)...(place on/off switch in "off" position, (fig. 2).)
2. Place on/off switch in "off' position.
3. Select proper staple length.
4. Use only staples identified by stock numbers on next page. Substitute staples may cause jamming.
5. Hold tool upside down. (Squeeze latch and pull, (fig.3).)
6. Drop staples in channel, legs facing upward. Push latch back in to lock in place, (fig. 4).
TO LOAD BRADS
2. Use only brads identified by stock numbers on next page. Substitute brads will cause jamming.
3. Look for the image of a brad nail on the front side of the tool (fig. 5). Load brads into this side only.
4. Hold tool upside down (Squeeze latch and pull, (fig. 3).)
5. Drop brads into the channel, tilt the tool so the brads lay against the channel wall, (fig. 5).
Push the latch back in watching that the brad strip does not fall over.
6. Use High/Low power when driving brads.
TO STAPLE OR NAIL
1. Make sure the on/off switch is in the "off" position, plug stapling tacker in.
2. Turn tool on by switching to position 1 which is the "on" position and hold firmly against work surface to
engage safety mechanism.
3. Apply adequate pressure on the top of the knob (fig. 6.) while the trigger is pulled.
You can find the figures mentioned above at the following link:
http://bdk.force.com/FAQ/servlet/fileField?retURL=%2Fapex%2FPKB_Article%3Fid%3DkA0C0000000CdtPKAS%26brand%3DStanley%26returl%3D%252Fapex%252Fpkb_search%253Fbrand%253DStanley%2526mode%253D0%2526model%253D%2526sortby%253D0%2526terms%253DTRE550&entityId=ka0C0000000CdqqIAC&field=File_1__Body__s
Posted on Jun 20, 2011
How do I load the stapler?
No you don't. We answer most things here.
If the stapler is like any of these
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Abostitch%20staple%20gun
You push the back in slightly to unlatch it and then drop it down a bit and the staple pusher comes out completely.
Jan 28, 2016 | Heavy Duty Stanley Bostich Heavy-duty...
I have a pro shot electric staple gun. Where can I buy the staples?
I have an excellent AEG staple gun. Although the AEG name still exists the nails and staples have been discontinued and the aftermarket that usually delights in producing such things haven't been interested because the nail design only fitted a limited number of machines.
In all other cases in my experience those manufacturers of nail and staple guns (that still exist) continue to produce ammunition for them and aftermarket specialist suppliers will have adequate stocks, the main problem being their information is often incomplete or out of date.
In lots of cases the required staples will have been bought in by the machine manufacturer but given a none-generic type or part number which the aftermarket supplier won't recognise.
If you don't have the generic staple type or part number then careful measuring is required to match drawings provided by specialist aftermarket suppliers of which there are a few in the UK and I expect every country will have a number.
In addition most builder's merchants or good ironmonger's will stock a supply of the most popular types.
Jan 02, 2016 | Electric Tools & Hardware - Others
How do you put staples in
There is a thumb release lever that keeps the slide bar locked down. Take your thumb and push up ******* this plastic release and it should open so that you can add staples.
Aug 27, 2011 | Stanley Tools TRE550 Electric Staple/Brad...
How do I load nails into the 5700
Here is the link but I copied the instructions here too
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000035709.pdf
Loading Staples or Nails
Make sure there are no staples or nails jammed from previous usage by checking the handle operation.
CAUTION: IF A STAPLE OR NAIL IS JAMMED, POINT THE GUN AWAY FROM
YOURSELF AND OTHERS BEFORE OPENING THE TRACK AS THE JAMMED
STAPLE OR NAIL MAY BE FIRED OUT UPON OPENING
i) Point the bottom of the gun away from you and turn gun sideways.
ii) Turn gun up, grip track release buttons and push away to release, then slide the track out, as shown (fig. 1).
iii) Insert a strip of staples in the chamber with the legs pointing up (fig.1a). If nails are required, turn gun upside
down and tilt the gun away from yourself and load on the right hand side (as indicated on graphics at the
staple and nail exit) with point facing upwards (fig.1b) THE GUN MAY JAM IF NAILS ARE INSERTED IN THE
WRONG SIDE.
*Arrow
iv) Slide staple or nail track back into closed position - a click indicates that it is locked in position.
Your staple and nail gun is now ready for use.
May 20, 2011 | Garden
Need help loading staples in my Stanley electric staple/nail gun
there should be a button / lever at the rear press it and it should open so as to insert the staples
Apr 05, 2010 | Stanley Staple/Nail Gun Elec
How do you load nails into a stanley tre550 nail staple gun?
Dec 06, 2009 | Stanley Tools TRE550 Electric Staple/Brad...
How do you load the staples
at the back of the staple gun is a clip you need to move this down from the lock position like a lever, the back will then slide out for placement of more staples, then slowly slide into place and place the clip back into lock position. hope this helps.
Nov 20, 2009 | Arrow 8000 Power Shot Pro Staple & Nail...
Broken part in Stanley Heavy duty Electric Staple/Nail gun
Bought a new one. Stanley hold no spares in this country, so it was cheaper this way! I am disappointed it broke so easily, so soon in its proper life. The part that failed seems poorly designed to me.
Nov 18, 2009 | Stanley Tools TRE550 Electric Staple/Brad...
How to insert fasteners
Already posted in response to a similair question, however repeated here to close off open query!
I bought one of these guns today and I had the same problem and it took me about 2 hours to figure it out as the instructions were very poor. Here how to load the brad nails:-
(a) Pull the slider bar all the way out
(b) Place the brad nail stick on the left side, IN FRONT OF the slider, NOT in the narrow gap in front of the two arrows where it says "LOAD BRADS"
(c) The nail heads should be facing the handle of the gun
(d) Close the slider and lock it
(e) Try it out. I tried nailing hardboard onto chipboard. The lever at low power only put the nail in about 30%. On Hi power it went in about 80%.
Good Luck
Peter
Jan 07, 2009 | Stanley TR250 H Heavy Duty Heavy Duty...
Tools & Hardware - Others Logo
Top Electric Tools & Hardware - Others Experts
eddie_brown
Level 1 Expert
Mike Carew
Jim London
Jim London
Are you an Electric Tool and Hardware - Other Expert? Answer questions, earn points and help others
