Question about Tablets & eReaders
My HP 7 tablet it mesquite won't turn on even when I leave it plugged in for several hours.
    Sergeant:
  • 320 Answers
Most tablets take a minimum of 8 hours to charge before they will turn on.
If charging for a long period of time has not fixed the issue, the battery may need replaced or the unit is defective.
Posted on Nov 24, 2014
What happens when my tablet won't even turn on?
Hi Mike, The link below is a youtube video showing you how to fix your tablet....CHEERS..
How To fix any Android Phone Tablet that won turn on
Apr 08, 2016 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
My HP 7 tablet aka mesquite won't turn in even if I have it plugged in for 4 hours And more.
change the electrical cord if you don't have one go to the store you bought it from and have them test the cord.
Nov 24, 2014 | Tablets & eReaders
How to reset a m752
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on. Support Troubleshooting Guide
Aug 01, 2014 | Kocaso 1.2GHz 4GB 7 inch Capacitive...
The Nexus 7 Tablet will not power up.
If u r confident u can open the back cover see in the net and check if battery connected etc have loosened up as even a small fall or a hard shake can dislocate the connections.
Jul 02, 2014 | ASUS Google Nexus 7 Tablet
Why wont my nookhd wont charge
If it\'s only two months old it may have a defective charging cable or adapter. If it\'s a new purchase and you can return it. To check to see if it might be the adapter and not the charging cable you have a few cheap ways to test this out.
General charging recommendations.
If you get power leave it on charge at least 3+ hours. This is the minimum time required if the battery is totally drained. If the Nook turns itself on during this process manually turn it off. The battery charges faster and more deeply if it\'s truely powered down. Charging more than 3 hours won\'t hurt it. In fact some manufacturers claim leaving thier products on charge for an additional hour after the charging light glows green is good as it leaves a slightly deeper charge on the battery. Also I believe leaving it alone for that hour allows it to cool the battery. Most manufacturers also recommend tottaly draining the battery at least once a month and then fully recharging it 1+ hours after charging light is green. They claim this helps the battery maintain a healthy charge and extends the battery life. Simply disconnect any charging cables, turn the unit on and just let it set. Don\'t touch it peroid just leave it alone until it turns off because the battery is totally drained. Then just plug it in and leave it. Only if the unit automatically turns itself on do you manually turn it back off.
Well that\'s about in in keeping the battery life and charge at its maximum.
If your AC power adapter has gone south there are only three ways to get around this. 1. Purchase a generic AC to USB adapter. 2. Purchase a genetic DC to USB adapter. Most of these can be cheaply purchased at most drug stores ect.. these days. You can even get DC to USB ones at dollar stores such as Dollar Tree. Good way to maintain your battery if your AC one goes south or you lose house current.
One other way to charge your battery is to plug the USB cable into your computer. Some manufacturers don\'t recommend this as this more often than not doesn\'t fully tank up your battery.
You can also get replacement charging cables at the same place you got the adapters. Places such as Walgreens, or CVS often have these at around five dollars a pop.
Apr 26, 2014 | NOOK HD 7 Tablet
Won't turn on
Mar 27, 2014 | Kocaso M730W 1.2GHz 4GB 7 Capacitive...
Android tablet m750b KOCASO problems loading
Turn it off completely. Either by reset or shutdown.
Leave it off.
plug in charger and leave it alone for 4 hours.
Power it back on.
Jun 03, 2013 | Kocaso MID-M750B MID-M750B 7-Inch Tablet...
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
