Question about Car Audio & Video
Where can I find the wirring diagram for 12 volt reversing camera
Nothing. I would like to connect a bihdccdw120 1319 to my existing Polaris monitor but the wires are diferrent colours (Polaris red ,black ,white n green)the camera black,white,yellown barewire
  • 1,675 Answers
I think it goes
Polaris Red-Camera Yellow Polaris Black-Camera Black Polaris white-Camera white and polaris Green-camera bare hope this helps
Posted on Nov 26, 2014
4 Suggested Answers
  • 4102 Answers
SOURCE: re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Posted on Apr 21, 2008
SOURCE: What colour are the power wires, are they green &
dove è l'uscita rgb
e ingresso touch screen
devo collegare un navigatore
KW-AVX 800 EXAD
Posted on Dec 10, 2009
SOURCE: I am looking for the wiring 97 fiesta stereo
Ford Auto WIring Diagrams, Image results for 97 Ford Fiesta Wiring Diagrams
Posted on Jan 23, 2010
Our polaris reversing camera has just stopped saying no device
ahh i got it...... didnt think ATVs needed reversing cameras
so a Polaris reversing camera system
if not the inline fuse or designated fuse blown
have to trace the power wires and check cables for loose connections at the screen first
then back to the camera
if no go a new unit may be required
Apr 16, 2017 | ATVs
Backup lights are 12 volt constantly, so how do I install my backup camera that only needs 12 volt when put in reverse. 2003 Ford Windstar SEL
All I can do is give you access to the wiring diagrams at this site and you can look up the best place to wire in the camera. http://bbbind.com/free_tsb.html
Dec 03, 2016 | 2003 Ford Windstar
Mmy daughter gave me this camera when she bought new vehicle with back up camera.I donthaveinstallationbookorinstructionscanigetthisinfooncomputertoprintout
yes you can find generic info on this. most all the systems, no matter name brand, have the same basic installation.
you will need a 12 volt power source for the monitor. the camera power will come from the reverse lights power source(tap into the power at the reverse light), then you will need to run an rca style cable from the camera mounted position to the monitor itself.
so every time you put vehicle in reverse the camera comes on.
or you can wire the camera and the monitor through a switch and it will come on anytime the switch is turned on. but if you do this, the switch need to be wired to a ignition controlled power source.
Jun 01, 2015 | PEAK Back-Up Camera with 2.4 LCD Monitor -...
How do I check if the charger for the battery is working properly
Volt ohm meter should show 12vdc. Or you may be able to connect a 12vdc lamp to the charger connection points and see if lamp lights. Or disconnect battery, plug in charger and test voltage at the two battery disconnected battery cable ends.
Apr 02, 2015 | Polaris Ranger RZR 900 12-Volt...
How to fit a g427 gator reversing camera to a vy commodore. Confused to what wire to connect for the power to the monitor,and where that wire would be located.thanks Dale
The main active / positive you can pick up direct from a connection under the dash or from the fuse box. Its easy if you have a 12volt test light, you can locate a permanent or switched 12 volt when the ignition key is on. The viewer is usually always on when the ignition is on. The camera picks up power direct from the reversing light. Use a crimp connector or solder direct to the terminal which supplies power to the reverse lights. That way the only time the camera will operate is when the reverse lights are on. The tail and reversing lights usually have a common neutral or negative wire which is connected to the body of the car. The other wire is the one you want. That's the active wire that supplies power when reverse is selected.
Jan 02, 2015 | Cars & Trucks
My Polaris 24 volt power ride on toy when put in reverse would go forward. When shifted in drive would go in reverse. Now it does nothing. Can anyone help?
remove the rear tires, then pull out the gearboxes and motors and use a multimeter and see if you are getting any power to the motors, then post back the results
Jan 26, 2013 | Toys
The battery is charged but the car will not operate. Push on the pedal and nothing happens
check the battery with a multimeter and make sure that it is showing at least 12 volts
Aug 19, 2012 | Polaris Outlaw 12-Volt Ride-On in Pink
I have a 2005 sportsman 500 when i turn key to start it nothing happens.lights still work.
remove the red and black lines for the starter motor hook up a volt meter and check and see if you get a 12 volt voltage to it or higer when you turn the key if you do then the starter is gone if not reply back to me
Aug 03, 2010 | Polaris ATV
Atv is not charging atv is a polaris 90
polaris 500 charging problem at idle 11 to 12 volts, at a reeve only 9 volts
Nov 05, 2009 | Polaris ATV
Car Audio & Video Logo
113 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
