<!-- from fixya rte -->Tub is not turning when machine is on spin - Washing Machines
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 108 Answers
The belt could be off or broken,check it out,or the dial couldbe no good,but if every other cycle works then it's probably not the dial.
Posted on Nov 24, 2014
Washing machine won't spin
Sounds like corrosion in the motherboard . Get an electronics serviceman to take a look, could just need soldering point to point connection. Hope this helps.
Jan 14, 2013 | Washing Machines
Roper washing machine makes grinding noise on spin cycle but the tub doesn't turn
It sounds like you have a motor coupling that is broken. There are videos on YouTube to show you how to repair this. Search for "motor coupling repair on direct drive".
Nov 26, 2012 | Roper RAS8445KQ Top Load Washer
Spinner on twin tub washing machine not spinning
I have had a manatee twin tub washing machine with spinner for two years. When I went to spin dry the first load this evening, it would turn on, but not spin. I read the above entry about another twin tub. I did the following... I unplugged the machine for 1 minute. Plugged it back in, then slowly and carefully turned the spin tub clockwise for 1/4 turn, then counter-clockwise for 1/4 turn. I cannot explain why it worked, but it did. So, try this trick before taking it apart. Good luck!
Jan 15, 2012 | Washing Machines
My maytag atlantis cycles but wont spin out. It spins slowly then shuts off but leaves wet clothes and water in tub.
First determine whether all the water is pumping out before it goes into spin. If not, check the pump and drain. If its not spinning fast enough with an empty tub check that there isnt any article of clothing caught between the inner and outer tubs or tub top ring. If thats ok check the clutch by turning the main drive pulley CCW. Substantial drag should be felt before the basket overcomes momentum and begins to turn. There is no repair for the clutch on this machine. The transmission must be replaced.
Jul 14, 2011 | Maytag Atlantis MAV6451 Top Load Washer
Tub does not spin. water pump works but no spin
  1. does the machine agitate? if no replace drive coupling between motor and transmission.If yes you have either a bad clutch or transmission.
  2. Remove cabinet and jump out lid switch to run with cabinet off.Put the machine in spin,look where the shaft goes up thru center of tub.Is the clutch drum turning?IF yes replace clutch.If not replace transmission.
  3. My guess bad coupling ,cost $20.
  4. Hope this helps .........Please rate my solution :)
Dec 14, 2009 | Kenmore Washing Machines
Washer won't spin makes banging sound
remove the agitator. there is a cone shaped block on the agitator shaft and locked to the tub via a large lock nut. spin tube has 2 tabs that lock into slots on top of block. these can strip out and cause the spin tube to spin inside block. watch it and turn machine on spin. tub can also drop and drag on bottom of outer tub. if this is it replace block and gently straighten tabs on spin tube.
Jun 11, 2009 | Whirlpool Washing Machines
Tub will not spin.
Replace the direct drive doupling on the motor.
This video explains how.
Mar 31, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
