Question about Kitchen Ranges
<!-- from fixya rte -->HOW DO I REPLACE THE ELEMENT FOR BAKING - Kitchen Ranges
  • Harrie Nov 24, 2014
    Hi Elbie Potgieter, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? On what? brand? model? what is wrong? thermostat? or the heater? Does it have upper and lower heat? are they both defect? does it have a grill and does that work?
    Problem Solver:
  • 19 Answers
Disconnect power, remove two screws and detach from two wires either by removing screws or by removing slide in terminals. Some elements are just pull out. Don't worr if you switch wires, it works either way. DO NOT change with power on!
Posted on Nov 26, 2014
The baking element isn't working.
You can replace the element. The element should just plug in to the oven. You might have to remove a few bolts that hold the element in place. Get the model number of your range and call your local appliance stores, or order it online. Unplug the old element and plug in the new element.
Apr 28, 2010 | Kenmore 96012 / 96014 / 96019 Electric...
Oven doesn't go on.
Hi.
If both baking and broiling element do not heath above a certain temperature instead, then the part to be replaced is the temperature probe, still located inside the oven cavity.
If the part that is not heating is only one element, then you may need to replace the element.
Before replacement the element can be tested removing it from the cavity and reading Ohms at the element terminals, with a multimeter set at Rx1. Disconnect power before removing the element.
In this case, selecting only baking or only broiling (depending on what element is faulty), the oven will work normally.
If the oven is a gas oven, then you have no element. In that case if the oven burners are working, replace the temperature sensor.
If replacing the temperature sensor does not help, then replace the oven electronic control.
Mar 04, 2010 | GE Ovens
My baking element burned into. can my oven work with just the broil element or does it need both.
I don't know if the broil element will work with the thermostat -- it's usually run full on. You could experiment and see, but the oven will not work correctly with just that element. You're used to baking with heat from the bottom and there is a difference. You might get away with it for pizza and meats -- MAYBE. But, even if it does work with the thermostat, do not try to bake with it unless you plan ahead to throw whatever you're baking away. Cakes, pies, etc. will be ruined with hea from the top. Replace the element -- they're not too expensive and they're easy to change. Just turn the power off first!
Dec 03, 2009 | Frigidaire GLEB30T8A Electric Double Oven
Bottom baking element remains on
From a consumer repair stand-point; I would inspect, test for continuity and or replace your oven bake heating element.
How to Replace an Oven Bake Heat Element: While ensuring power off when servicing; Remove (2) mounting screws and slowly back-out the element about 3" or so. Then, disconnect and remove wires located on each side of heat element; re-install new element.
Should problems still exist, contact me.
- C
Jan 27, 2009 | GE 30" Self-Cleaning Freestanding Electric...
I have a Magic Chef range. My baking element in the oven caught fire and broke in half from the heat. I am trying to replace the element but am not sure if I am supposed to disconnect the element from the...
hi!!! All you have to do is go and buy a new heating bake element..turn off the power to the oven by the home breaker..then move the oven away from the wall and remove the back panel screws and look for the baking element it has 2 wires going into it.Very easy to fix..good luck..
Jan 03, 2009 | Kitchen Ranges
Baking element
oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
Aug 29, 2008 | GE JBP90 Electric Kitchen Range
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
Apr 19, 2008 | GE Profile JTP18 Electric Single Oven
Kitchen Ranges Logo
60 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
