Question about Ricoh Aficio SP 4100N Laser Printer
<!-- from fixya rte -->Rc gate connection error with red alert - Ricoh Aficio SP 4100N Laser Printer
I have 4 wires green blue red and white my red is connected to the rh rc with jumper green connect to g blue to y1 and white is connected to w1 my new thermostat has no rc rh or a jumper
Paulette, if your new thermostat has no Rc and Rh thats fine. The Red wire should simply go to the R terminal. The Rc and Rh terminals on the old one was for the old 'two transformer' systems. The vast majority of systems now have no need for the Rc Rh terminal and jumper. The rest of your wires connect as on the old stat also.
Jul 31, 2015 | Heating & Cooling
I tried to install "Red Alert 2" on my PC. and
Hi, try installing your red alert 2 installer to another computer.If it works your computer might be the problem. Check if you have enough space for the game.Try changing the destination folder. If it does not work your installer might be the problem.
Feb 26, 2011 | West Wood Studios Command and Conquer Red...
Gate sensor keeps alerting. Have checked that
spray the switch with wd40 or similar, it may be sticking. if not replace door switch.
Apr 30, 2010 | 2002 Jeep Liberty
I am installing honywell thermostat rth111/rth221 old thermostat only has two wires red and yellow new thermostat has terminals marked Y,G,Rh and Rc with jumper,W. where do I connect red wire and also the...
The red does go to RC, but the yellow should go to the W terminal, in HVAC W=heat Y=Cool, so aslong as the same wire is on RC on the t-stat, and RC on the unit, and same wire to the W on the t-stat as to W on the unit it should work!
Jan 31, 2010 | Honeywell Programmable Thermostat Heater
Can't connect to westwood servers on red alert 2
Make sure to have you copy of windows as well as your copy of Red Alert 2 fully up-to-date
Thanks Live-Tech
http://www.mylive-tech.com
Jan 03, 2010 | West Wood Studios Command and Conquer Red...
Outside a/c unit hasnt powered on yet and I want to make sure my RH and RC wires are correct.
Connect the red to RH
Go down to the furnace and look at the circuit board and note what color's go where. Most units only use 4 wires.
Should be
RED to RH
YELLOW to Y
WHITE to W
GREEN to G
Then from there two wires go to condenser outside. And they connect to Y and C on the board. Most of the time Red and White from outside. Don't get confused with Red coming from thermostat. Let me know Ken
Apr 26, 2009 | Heating & Cooling
Replacing thermostat for central heat and air/ not humidifier
rh and rc should have a jumper between them.connect red to either.y=yellow g=green w=white and do not use the blue.your new stat will run on batteries.
May 26, 2008 | Honeywell Power Humidifier: Furnace...
Ricoh Aficio SP 4100N Laser Printer Logo
220 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
