Can you regas a celestial kfr-26gw c3 split type air com outdoor unit?
    Master:
  • 602 Answers
Yes
Posted on Nov 26, 2014
Therinnaiguy
  • 1420 Answers
SOURCE: Air Conditioner unit won't switch on outdoors
can you give us some model numbers and a make? Get both the inside and outdoor unit numbers please. Thanks.
Posted on Oct 10, 2007
jgwhomeequip
  • 1902 Answers
SOURCE: Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Posted on Jun 01, 2009
  • 441 Answers
SOURCE: Require instructions and wiring diagrams for Celestial KFR-70GW/K
If you pull the unit out of the case it should have a wireing diagram in a envelope near the compressor
Posted on Jul 17, 2009
Johnny Reb
SOURCE: Remove and relocate split air conditioner
The simplest way of explaining this is as per the following. On your outdoor compressor unit there should be two pipes, one smaller diameter [high pressure] and a larger diameter pipe [low pressure]. Turn your A/C on inside the house and then shut off the smaller diameter pipe. Run the unit for a around 3 to 4 minutes and then check if the cooling is reducing from the unit inside the house. When you feel room temperature air [not cool] being emitted from the indoor unit shut off the larger diameter pipe and turn off unit. Isolate electrics, disconnect A/C piping and immediately seal the piping with good quality tape to prevent egress of dirt. When re-installing a quick purge of gas is usually only required to clear the lines if they were sealed properly and kept clean. Ideally running a vacuum pump is recommended but if care was taken then it may not be needed, as in many of my installations.
Posted on Nov 13, 2009
shastalaker7
  • 1515 Answers
SOURCE: i dont have my celestial KFR-28GW\A remote control
Hi, the best way to tell without the manual, would to be to pick up a anolog thermometer, and insert it into the face of the a/c. This will tell you which setting will give you cooler air temperature. They are very inexpensive, and you can get them at most any hardware store or appliance parts store. This will be useful in your auto a/c, refrigerator and so forth. Best of Luck, and Happy Holidays,
Shastalaker7
Posted on Dec 21, 2009
My Celestial KFR-36GW/C3 has stopped cooling. it just blows air! Please help ASAP!
hate to tell you this... but... it's a valve problem, one that requires depressurization of the freon to replace. Then the air dryer replaced and freon needs to be recharged by a licensed contractor. The intentional venting of freon is against Federal Law IAW the Montreal Protocols on Greenhouse Gas emissions. In some cases, it could be a bad compressor in the exterior unit. A qualified service person has pressure testing equipment to diagnose the problem quickly. (A bad compressor also requires depressurization... licensed contractors have freon recycling equipment.
Jan 25, 2015 | Heating & Cooling
Chunlan kfr-700k
Check this link to see if you can find the manual you are looking for here:
http://shop.panasonic.com/shop/model/36PEF1U6?t=specs
Aug 26, 2014 | Panasonic S-36PF1U6 31,200 BTU Mini-Split...
Remote control required for airconditioner
Not too many units only work with remote control...try using Bing or Google to find your problem and solution to the answers that you seek.
May 18, 2013 | Heating & Cooling
I cannot operate my Celestial A/C with the remote
It only mean that the remote receiver of the A/C is not
working, it have to be replaced. May this info help
you.
Jan 06, 2010 | Heating & Cooling
I dont have my celestial KFR-28GW\A remote control
Shastalaker7
Dec 17, 2009 | Heating & Cooling
Jul 17, 2009 | Frigidaire FAA065M7A Air Conditioner
I have purchased 1.5 split air-conditioner of Electrolux model 18SCRDA1 from NEXT and got it installed. Till now it is working fine. suddnly we observed abnormal noise from the outdoor unit.Condenser fan...
hi there.dont touch the untit.its under warranty and if you touch the unit and try to repair it.the warranty will be non existant.im one of the serivc agent for eletrolux.
Jun 08, 2009 | Soleus KFR-18GW Split System Air...
Celestial split system air conditioner
I am a repair man and have had this problem quite a few times, check that the remote is set to heat and 30 degrees.usually a symbol like the sun,very similar to cool easy to mix up.If the a/c is set to heat the indoor fan will not start till outdoor unit has heated coil.
Jul 16, 2008 | Heating & Cooling
Heating & Cooling Logo
103 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
