Question about Dryers
Why does my tumble dryer keep beeping when I try to press start and the kg settings lights flash
Does it do the same thing when empty if so then the weight sensor cicruit has an issue and would appear to not be sending correct data too the controller could be a bad connection
sometimes the low voltage supply to the controller board develops a bad electrolytic capacitor and instead of like 5v DC then you get a bit less like 4.6 and it is not smooth as the capacitor usually removes the ripple but when the capacitor/s goes dry you get issues like this youll realise it could be nothing wrong mechanicaly but simply replace the smoothing cap/s
Posted on Nov 24, 2014
  • 209 Answers
SOURCE: Tumble Dryer won't start
assuming what you say you checked is correct and working then the next place to look is the start relay, located behind the front timer control panel, this sis more often than not a cubed shape box made of clear plastic with about 6 spade connectors on it, look for burn marks inside it, replace if looks damaged, do not attempt to bypass or short out to test, as you will blow the timer or and control circuit board and cause extensive damage
Posted on Sep 26, 2007
dididsaythat
  • 291 Answers
SOURCE: Hoover tumble dryer
I think you may have a bad relay on the motor, where power is re-applied after the push start is released
Posted on Oct 14, 2007
  • 67 Answers
SOURCE: dryer does not tumble, but heats up
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
if this helps please vote me a fix ya
Posted on Jul 15, 2008
aborcass
  • 2651 Answers
SOURCE: Won't start, beeping sounds
sounds like the door switch might be an issue,, does teh tub light go on /off as you open the door??? if not try manually pushing the switch in a few times.
Posted on Oct 26, 2008
SOURCE: Eurotech dryer. ON light flashes on and off, beeps
The problem is that you stopped a cycle before the program knob reached the "STOP" (12 o'clock on the knob). All you have to do is turn on the machine, turn the knob to STOP, and wait a couple of seconds. You'll hear a tone and the ON/OFF light will stop blinking. Turn the program knob to the cycle you want and- viola! you're good to go!
Posted on Jul 24, 2010
Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
Janet McDonald,
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
-Best Regards-
Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
Bush tdv6w tumble dryer wont start just flashes lights and beeps
All these sound like good advice but in addition - there is a re-set button on the back of this machine, push it and see if the problem continues. If you still have the same problem after re- setting your machine please call their customer service line at 0345 640 2020.
Nov 25, 2013 | Dryers
Model tcl770 tumblecdryer wont start to tumble. Power light in and beeps. Filters etc all clean. If I press any of other buttons they all flash. Any advice please.
Hello Hazel
You need to check this parts.
Check the drum belt
Check the idler pulley
Test the motor
Best Regards
Neciforo Llanto
Sep 30, 2013 | Dryers
Zanussi zdc 67550w tumble dryer stopping after 10-30 seconds of the cycle
See if it is overloaded or the clothes are excessively wet... Take out 1/2 the clothes and try again.
Jan 12, 2013 | Zanussi Dryers
Hi, we have a Siemens IQ300 Condenser Tumble Dryer which we have recently inherited. Unfortunately it worked for a wek before just stopping. The lights are on and everything looks normal but when you
Check to see if it is properly grounded and that the incoming voltage is correct (120V or 240V) for the wiring config you have.on the dryer as it sits. Also try unplugging and wait a minute or so before plugging back in. This will sometimes reset dryer electrical components to factory settings.
Dec 07, 2012 | Dryers
GLEQ2152ES the error "PF"
My dryer keeps beeping all by itself. I had to turn the breaker off. Now I tried to use it it it tumbled for a minute but kept flashing err & beeping then flashed E68 & shut off.
May 25, 2009 | Frigidaire GLEQ2152ES Electric Dryer
My dryer keeps beeping after 30seconds of turning it on. I have pressed the 'LOCK' key to unlock & even then it still does the beeping thing! Could this be the motherboard packing up?
I had the same problem. My wife was about to take an axe to the darn thing. The frustrating thing was that it was beeping 3 times and the status lights were flashing. The manual only described 4 beeps (Dryer ran too long) or 6 beeps (Push button does not function). It finally dawned on me that it was beeping two sets of three beeps (i.e 6 beeps). The corrective action was to press buttons lightly and release. I pressed on every button first lightly then heavily with no success. I pounded on the instrument panel; still no luck. Finally I pressed the Options button and the Select button simultaneously for a second and heard a click. After that, no more beeping. According to the manual this activates a "LOCK' feature if you hold them down long enough. But in my case, the lock light flashed but didn't engage and after the beeping stopped, I left well enough alone.
Hope this helps.
Jun 22, 2008 | Dryers
Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
Apr 23, 2008 | Dryers
Dryers Logo
Top Dryers Experts
