Question about HP LaserJet 1300 Printer
When I turn on my HP LasterJet 1300 printer, it stop on orange constantly blinking light.
I sort out the problem, when I put the printer on direct sunlight for 10-15 minutes facing bottom side up to the sun and when it get heated, and after plug on, it start with normal green light, but don't know how to sort out the problem whether is board problem or something else. Please help.
  • HP Master
  • 1,915 Answers
Which light is flashing? These codes all tell you something but I needs some details. A blinking light usually does not mean a fatal error but provide some details and I will try to help you.
When I turn on my HP LasterJet 1300 printer, it st - 25295454-wsm5cxqvoesohnwroqq005pf-1-0.jpg
Posted on Nov 25, 2014
Testimonial: "After plugging and completing all process of lights blinking, it ultimately stop on Orange light blinking, but when the bottom of printer is heated with hairdryer or put into sunlight for 10-15 mins, and when plug in, it stop on green light and works till i am turn off the printer. The problem seems in the board but due to non technical person, I have no idea what to do further but only heat it and work."
  • 138 Answers
SOURCE: HP 1300 LJ Fuser Film
If you didn't have the orange light to start with and were replacing the sleeve due to a torn or damaged sleeve it sounds like you haven't plugged everything back in. The Error is an electrical fault with the fuser circuit.
Verify that all wires are plugged back in. Two areas to pay specific attention to are as follows. (1.) BOTH slide clips witth wires that you removed on the upper fuser edges to mount the new sleeve. Thats the connections for the ceramic element. If you get to having to uninstall and check the fuser, put an ohm meter on both ends of the element to ensure it's not shorted. My meter when on ohms has a beep when the leads are touched together when the meter is measuring ohms. Check for the beep when touching both ends of the element and that will prove the element good.
(2) On the board in the base of the machine, there are some plug in connections on the lower board very close to the rear edge and just about centered left to right. It's a cluster of about 3 or 4. Unplug the connections and pay close attention to the height of the pins inside the connection. One of those connections has a nasty habit of the pins slidding through to the other side and not making good contact. If I remember right its the right hand connection in the cluster or the one next to the right one. You can use the connections rest to it as a visual referance for the height. If the pin or pins have pushed down, carefully pull them back up with needle nose pliers or tweezers and replug the connection back in.
Hope that helps you. Just in case, heres a free manual PDF link to use to resolve. It's a 1200 manual as the 1300 wasn't listed but the processes are identical. Most of the parts are the same but check first before ordering any parts.
http://www.feedroller.com/Store/Service%20Manual/LASERJET%201200%20Series%20Service%20Manual.pdf
Posted on Aug 04, 2008
geemarie
  • 876 Answers
SOURCE: hp 5550 printer problem
Did it eject the paper? The paper may have been crooked or became so in the printer. Check the Paper jam area first. If there is nothing there, Let's try a simple reset of your printer.
Go to Control panel>printers and faxes>click on your printer icon and under documents click cancel all documents.
Turn the printer off
Remove the paper from the tray
Unplug it from the power source
unplug it from the PC
Now open the paper jam door and gently push the paper roller forward until it clicks
Now do everything in reverse order until you get to turning the printer back on. give it a few minutes and see if it resets itself.
when you reload paper, besure that it is aligned carefully and the holders are pushed into place.
Let me know if this helps. Good Luck!
Posted on Aug 13, 2008
SOURCE: HP LaserJet 1300 is showing blinking of orange light instead of tonner is in
I am having problem in finding solution for HP Laser Jet 1300 which is not getting ready and shows orange light blinking. I have check the tonner and the sensor which are located backside but the problem is still as it.
Posted on Dec 09, 2008
nyilasrobert
  • 627 Answers
SOURCE: my hp laser jet 1300 is blinking orange and cant
The flashing orange light is a basic attention light. Check the following:
1. There is a known good toner cartridge installed
2. There is paper in the tray
3. The long tab on the top of the inside of the cartridge access door is not broken
4. Connector J210 on main board is intact, tight and all 3 pins are present
5. That the drum drive engagement is working properly and the contact is present
6. The main motor connector is seated tightly
Posted on Jul 09, 2009
SOURCE: printer makes strange grating sound, stops and
I don't know if this will work for you, but I had the same problem... grating & metally sound. Removed color ink cartridge (almost empty) shook it up alittle, & put it back in. No more blinkling orange lite, or noise.
Posted on Jan 13, 2010
My hp laserjet 1300 printer shows blinking the orange light instead of the green one and I couldn't find out what is the reason
1. Go light/button blinks twice with solid green and orange lights
2. Green light starts blinking with go light twice and then both go off
3. orange light goes off.
4. green light followed by orange light followed by go light cycle twice and a third time by the green light
5.followed by the orange light continuously blinking.
I have already tried the following trouble-shooting:
1. Put in a new cartridge
2. Made sure there is paper properly seated in the tray
3. Made sure all doors closed (I even took off left side to verify no memory cards
4. Verified all doors closed
5. Done a cold reboot by holding the Go button while turning the unit on.
6. Repeated steps 1-5 multiple times.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
Mar 06, 2014 | HP LaserJet 1300 Printer
Tip
The green light is blinking constantly and the printer won't print
When the green lamp constantly blinking this mean one or both print head are defective.Here we can find which cartridge is defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
This printer can work with only one cartridge.If you don't use color printing just remove the color cartridge.
on Oct 26, 2009 | HP Deskjet 3845 InkJet Printer
Tip
Often happens HP cartridges to overheat.In that case the printer not recognize it and the green lamp blinking constantly.In most case only one of both cartridges defective and need to be replaced.But how to know which one?
Here's how: Open cover, put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
on Oct 21, 2009 | HP DeskJet 3745 Printer
The orange light is blinking and printer will not print
Unplug and wait 10 minutes, plug back in power strip and "watch" the blinking lights they will tell you what is going on(or NOT).
Nov 19, 2010 | HP LaserJet 1300 Printer
My hp laser on and orange light blinks hp laser1300
There is a list of solutions on HP website. Go thru it:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=mx&taskId=110&prodSeriesId=238320&prodTypeId=18972&prodSeriesId=238320&objectID=c00003059
Jul 21, 2010 | HP LaserJet 1300 Printer
My Hp 1300 laserjet printer doesnt get ready after initializing but giving orange blinking light, what could be the solution because i have checked the toner is in properly .
Remove the paper and re-loaded it, if it still giving you the blinking, turn it off and hold the go key down while turning it on then release it, this should rest any errors, worse case you have a bad fuser.
Jun 15, 2010 | HP LaserJet 1300 Printer
Light constantly blinks
One or both print head are defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
Oct 20, 2009 | HP DeskJet 3520 InkJet Printer
My hp laser jet 1300 is blinking orange and cant print please get me a solution
Jul 09, 2009 | HP LaserJet 1300 Printer
932C Constant blinking ink light
problem here is the orange light blinking- has ink in the cartridge- stopped printing in the middle of the page
Jul 19, 2008 | HP DeskJet 932c InkJet Printer
Apr 11, 2008 | HP LaserJet 1300 Printer
HP LaserJet 1300 Printer Logo
132 people viewed this question
Seeker5211
Seeker5211
