Question about Air Tools & Compressors
I have Electric motor single phase 340 watts slot 24 ,rpm 2300 ,6.3u Running coil pitch 8-10-12 swg -27 Starting coil pitch 8-10-12 swg 30,30 Please send me winding diagram
  • 3,506 Answers
You will need to contact the distribitor for that
Posted on Nov 27, 2014
5 Suggested Answers
  • 5 Answers
SOURCE: I need to build a single phase to three phase
You will need a rotary converter for this, or a single phase motor. A three phase motor absolutely cannot be made to run on single phase otherwise.
Posted on Jul 18, 2009
  • 5 Answers
SOURCE: I wish to rewire a single phase electric motor
The motor itself should have a sticker which describes the wiring for 115. It is a small change involving a single wire moving from one pole to another inside the motor starter cap (the bump on the motor itself).
Posted on Aug 29, 2009
  • 6 Answers
SOURCE: converting 3 phase compressor to single phase
Start w/ a single phase motor. Or maybe your question is just confuseing me.
Posted on Sep 12, 2009
mrhappyface
  • 205 Answers
SOURCE: where can i find ac motor connection diagrams,
there is no motor that is single phase with 415 volts only 240 volt or 120volt and you cannot use a 3 phase motor on single phase it will just fail to start buzz and burn it up .single phase motors have capacitors 3 phase motors do not
Posted on Jun 15, 2011
Rpm computation
it will be the same as motor if driven directly. If you use pulleys and belts there a online calculators that will help you BTW the pulley ratio is 1.259
Dec 03, 2017 | Air Tools & Compressors
What is the motor hp?
Please see below courtesy of engineeringtoolbox.com
Electrical power is in general rated in watt (W) or horsepower (HP). A horsepower is a unit of power equal to 746 watts or 33000 lb ft per minute (or 550 lb ft per second).
A watt is equal to the power produced by a current of 1 amp across the potential difference of 1 volt. A watt is 1/746 of 1 horsepower.
Even if the watt is the base unit of electrical power, it is common to rate motor power in either horsepower or kilowatts.
Power in Watts
Direct Current Electric power supply to a direct current (DC) motor:
PkW = ?m U I / 1000 (1)
where
PkW = power (kW)
?m = motor efficiency
U = voltage (V)
I = current (A, amps)
Electric power supply to a alternating current (AC) motor:
Single Phase PkW = ?m U I PF / 1000 (1b)
where
PF = Power Factor
Two Phase Four Wire PkW = ?m 2 U I PF / 1000 (1c)
Three Phase PkW = ?m 1.73 U I PF / 1000 (1d)
Power in Horsepower
Horse power can be expressed as:
Php = PkW / 0.746 (2)
or
Php = (?m U I / 1000) / 0.746
= ?m U I / 746 (2b)
where
Php = horsepower (hp)
Feb 03, 2016 | Boating
Dewalt radial arm saw GW1- Is it single phase or 3 phase
if the plug on the cord fits any other outlet in the house it will be single phase
if the cord is cut , then it will have only 3 wires if it is single phase
( active , neutral and ground )
if it has 4 or more wires it will be 3 phase
most saws running a 200 mm blade or around that size and used for home duty will be single phase
the phase notation will be on the plate attached to the motor of the saw
It will read voltage , amperage, watts or hp, phase and cycles
Jan 02, 2016 | Dewalt Saws
I have 340watts 6.3u 220volt rpm 2300 slot 24 Running coil pitch 8-10-12 swg -27 Starting coil pitch 8-10-12 swg 30, 30 Please send winding diagram
Contact the manufacturer of whatever model you have beause no one can help without knwing what make ect you have.
Nov 24, 2014 | Cars & Trucks
Hi,I got a Ingersoll Rand type 30 model 234 compressor.It looks good but it has no motor.I'm thinking like 120v,3horses?,but not sure about rpm.any help would be nice.thanks
According to the information you provided your looking at a 10 HP motor at three phase. Do you have three phase at your location? If not I would look into getting a single phase compressor. If you do want to get it going I would notify your local IR dealer so they can get you the right Model number, RPM, Pulley and Motor Frame Size to match your unit.
Please read below....Jim...if this helped you please send me a positive response...Thanks!
Ingersoll-Rand Type-30 Electric-Driven Two Stage Horizontal Air Compressor - 120 Gallon - Fully Packaged IR 2545E10VFP
  • Designed for heavy shop or industrial use, Ingersoll-Rand Two-Stage electric air compressors provide the quality and performance that are ideal for most applications and users, including: automotive service and body shops; fleet maintenance; machine shops; production and manufacturing lines; construction; wood working shops; dry cleaners; car washes; maintenance/repair shops and farms.
  • Durable cast-iron, two-stage design offers extended pump life for years of trouble-free service 175 PSI maximum operating pressure
  • 100% continuous duty for tough applications
  • Automatic start/stop control/pressure switch operation
  • Includes motor starter, oil sight glass (10-15 HP only), manual drain and ASME tank
  • 10HP, 3 Phase 200, 230 or 460 Volts
  • 120 gal, horizontal tank
  • 35 ACFM @ 175 PSI
Feb 14, 2011 | Ingersoll Rand Type 30 Electric Driven Two...
Hi, I have an old IR Type 30, two-stage compressor, model #: V242 N3. The current motor is 3hp, 1 ph,1740 rpm and may need to be replaced. Is it safe to use a full-speed, i.e., 3450 rpm motor on this...
no you need to use a compressor duty motor same rpm using a higher rpm motor will shorten the life of the motor if you have 3 phase power even better single phase motors aren't as efficient and run much hotter and dont last very long on air compressors
Aug 22, 2010 | Ingersoll Rand Type 30 Electric Driven Two...
I have a 220 440 electric motor on my 4 post 3 ton car lift which ran on 3 phase, how can i run this motor from a single phase supply, regards dave
You need to either change the motor to a single phase or check into a single to three phase converter...I would do which ever is cheaper myself. You could go single phase, but the cost of operation would be higher depending on the duty cycle.
This link may help: http://www.phaseconverter.com/starting-load.html
HTH
Mike..
Nov 20, 2009 | Plumbing
Wiring diagram for single phase two pole 2.5 HP induction motor.
all you have to do is (a) open the connection box of the motor look for the two wires of the starting or running coil, inverse only one coil wire.(a) If there is no centrifugal switch in the rotor, try this it might help open the motor both end,change the direction of the shaft ,which i mean pulley side goes to fan side and fan side goes to pulley side and tighten all bolts.
Sep 11, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
65 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
