Question about Onkyo DX-C390 6-Disc CD Changer
What is the most likely cause of a "NO DISK" error with the Onkyo DX-C390 6-Disk changer? Would it be the laser pickup assembly?
Sometimes the unit will read and play the disc. I can hear the laser assembly as it focuses on the disc. When the unit fails to scan and play the disc, I hear 3 little clicking sounds (which I assume is the laser attempting to focus on the disc, but can't) and then it rotates the carousel to check for the next disc. On the rare occasion that it scans the disc, it plays it just fine for the most part. Every now and then it will skip a little.
    Sergeant:
  • 324 Answers
Could be dirty laser lens, dying laser, faulty component,
Due to the complexity of multi-disk changers, it may be best to have the device looked at.
You can try running a cleaning disk through it first, but from your post, it sounds like this unit may have multiple problems and need tested by a physical person.
Posted on Nov 24, 2014
  • Will Crump
    Will Crump Nov 24, 2014
    Thanks for the idea, Jeff. I have indeed used a cleaning disk. I am tending to think that it's the laser pickup assembly. Now it is a solid hard failure. I can hear 3 little clicks, which is most likely the laser trying to focus on the disk and establish a focus lock. After 3 little clicks, the carousel rotates to the next 5 slots, each of which are empty.
  • Will Crump
    I have ordered a new laser pickup assembly from e-Bay. I'm going to replace the laser. As far as the machine moving the disc around to the actual playing mechanism, there's no problem there. I've watched the mechanism with the cover off. It acts like that the initial focus lock needed to read the table of contents fails. If that initial focus lock fails, nothing else that's supposed to happen after that will be allowed to take place.
3 Suggested Answers
emissionwiz
  • 80339 Answers
SOURCE: Problem with my Onkyo DX-C380
have u taken the top off and checked to see if the drive belts are in good condition and not loose? that can cause this loading error as well as a hard fault in a component.
Posted on Sep 14, 2009
dunnbiker
  • 8546 Answers
SOURCE: my onkyo dx c200 5 disc cd changer will only play
This is a comprehensive reference for disc players...
http://www.repairfaq.org/sam/cdfaq.htm
Posted on Feb 11, 2011
Onkyo DX C330. Why is changer skipping?
The laser pickup lens could be dirty.
Mar 10, 2016 | Audio Players & Recorders
ONKYO CD DX-C390 6 CD CHANGER NOT READING
No laser, means no laser. Typical symptom of laser failure. Most CD players can have the laser replaced fairly easily and cheaply.
Contact your local technician, and he should be able to replace it quickly.
Oct 30, 2014 | Audio Players & Recorders
Changer states checking disk, error
Possible broken drive belt, that's what caused the same error on my unit. Very easy to replace, just take off the top cover and the motor and belt are readily accessible.
Feb 03, 2014 | Technics SL-MC700 110-Disc CD Changer
Cd changer cannot read cd
Its laser pickup assembly might be faulty. Click here to know more about how to clean it. Do it once, and if it do not help you, replace it with same type and number.
Sep 03, 2012 | Audio Players & Recorders
Error message (protect) cd plays then goes silent then plays again. have cleaned laser several times with cd cleaner disk.
Dirty lasers don't cause "protection" problems. Are you sure thay message is displayed on the CD player? That word is nowhere in its manual.
May 22, 2011 | Onkyo DX-C390 6-Disc CD Changer
CD sounds jumpy, missing segments of the song then the CD resumes. Cleaned CD's but it continues to happen.
The problem is in the laser pickup assembly, overtime the laser becomes weaker until it can no longer track the disc properly. The only option is replace the assembly, "very expensive" or purchase a new cd changer, "much cheaper option"
May 15, 2011 | Onkyo DX-C390 6-Disc CD Changer
Onkyo DX C330 carousel goes in and out without stopping and won't quit spinning around
Sometimes the tray ribbon goes bad causing bad connection to main board! Common
problem with alot of brands!
Apr 22, 2011 | Onkyo DX-C390 6-Disc CD Changer
With no disk loaded and the dvd player turned on, the dynex blue screen turns on then the laser jams into one position and there is loud static sound.
Unfortunately the stepper rail linkage is defective that moves the laser pickup assembly, the only solution is replace the whole laser pickup assembly which is not cost effective, cheaper to buy a new portable dvd player.
Apr 14, 2011 | Dynex DX-PDVD7 Portable DVD Player
It won't play disks and just makes a lot of mechanical noises as it goes from disk to disk trying to play one.
The mechanical parts are working but the laser pickup assembly is not reading the disc. The possible causes are, dirty laser pickup lens, bad pladder motor, or no b+ to the motor, or worn out laser assembly system. Because of the expense of buying the Bose units I highly recommend a professional service man to work on the item.
Dec 28, 2010 | Bose Acoustic Wave (32022) 5-Disc CD...
Onkyo DX-C390 6-Disc CD Changer Logo
344 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
