Question about Konica Minolta BizHub C252
My bizhub c252 keeps reading low toner for yellow, and after a few copies it reads no toner and has to be reset to continue working. What is the problem
Ive bought 2 new toners from different suppliers but the message reappears still, please help me out
    Sergeant:
  • 303 Answers
You may have to get into the printer settings on your PC and tell the printer it has a new cartridge installed. the easiest way is to open the computer folder and right click your printer and select properties. you can also go to start-control panel-hardware and sound and select view devices and printers then right click your printer and either select printer properties or troubleshoot. troubleshoot may give you an answer or idea how to correct the toner issue
Posted on Nov 24, 2014
Konica Minolta bizhub C252 cannot stabilize
Clean IDC sensors that read toner density on transfer belt.
And do Image stabilise reset.
If that doesn't help then:
If Imaging units are over life -replace them if Transfer belt is over life replace it.
Mar 27, 2017 | Konica Minolta Office Equipment & Supplies
Konica Minolta BizHub C252 - pale colors on the long side
Konica Minolta BizHub C252 Repair Questions,... - Fixya
www.fixya.com > Forum > Printers & Copiers > Konica Minolta
Konica Minolta BizHub C252 - pale colors on the long side · Konica Minolta. ... I have a Konica C250 machine which cannot print red color at all. I had changed ...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - On the right hand side of the drum (the part that has the large green handle) that easily slides out. There is a ..... I have konica minolta bizhub c252 colour printer. ... The K light came on a long time ago and is constant on now.
How to clean the drums/i units on the konica minolta number ...
? 0:28
https://www.youtube.com/watch?v=eD8HdNq0MlE
Nov 23, 2011 - Uploaded by Tennants Nottingham
How to clean the drums/i units on the konica minolta number plate printer ... Fix or repair color laser printer with fading, lightprint, or lines samsung clp 300 ... Imaging Unit Reset for Konica Minolta Bizhub C203 / C253 / C353
Dec 14, 2015 | Konica Minolta BizHub C252
When i boot my bizhub c252 it displayed in a foreiegn language not English how do i change the langauge on my Bizhub c252 from the foreign language to English
To change language:
Press "Utility/Counter"
Press number 2 key, then number 1, then number 1 again. This will get you to the language selection without having to read the screen. Once there select your language. If this does not correct the problem, you may have a board or Nav Ram problem and should contact someone for service.
Jan 15, 2015 | Konica Minolta BizHub C252
My brand new machine Bizhub 211 have paper jam problem
COF32 means the ATDC sensor has detected some unusually high or low readings.
The ATDC sensor measure the toner lever inside the developer unit.
Try swithcing on/off, open/close the front door to clear the code.
If this doesn't work, you'll need an engineer to reset the ATDC level.
Good luck
Tam
Apr 12, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Malfunction(Code 3451) of Bizhub C252
This is a fuser heat error. The fuser unit is located in the area where the paper exits the machine. It heats up and "fuses" the toner onto the paper. The error code means that it did not heat up properly. This means you will most likely need a service person to come out and diagnose the problem.
You can try to reset the error but I doubt it will help.
Turn off the MAIN power switch (not the one on the control panel)
Now hold down the utility key while turning on the main switch and continue holding the utility key for at least 10 seconds. You should see a screen come up with nothing but "trouble reset"
Touch trouble reset and you should see a small "ok" come on. Then turn off then on the main switch again.
Good Luck and Thank You for using Fixya.
Apr 01, 2010 | Office Equipment & Supplies
Where can I get instructions on how to replace the transfer unit of my Bizhub C252?
Please visit the site http://www.resetkit.eu
There you can find how to reset your fusing unit and transfer kit unit for almost all Konica Minolta MFP's and printers, Bizhub C252 included.
You don't need to replace it, you can just reset it and save a lot of money.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Oct 22, 2009 | Konica Minolta bizhub C250 All-In-One...
BizHub C252 - error Code C-2555 (Malfunction Detected)
C-2555 relates to a low toner density in the yellow imaging unit. I'm sure your daughter pressing buttons did not cause it.
I suggest you release the yellow imaging unit (the bottow row of units)
Just realease and pull it out a little way. Then switch the machine on with the door open. It won't start, but will ask you to shut the front door. Reseat the yellow imaging unit and shut the door. The machine should go in to a stabilization mode and then work.
However, if it comes back, I suspect a new yellow imaging unit will be required.
Jan 31, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta BizHub C252 Logo
63 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
