Question about Samsung SCX 3405FW - Multifunction fax / copier / - SCX-3405FW/XAA
Hi, when starting the printer the usual lights turn on, also the red one at "Status", but where there is normally a sound an somethings going on to hear in the printer, only a light click comes, when
REPLACING THE CARTRIDGE BY THE NEW ONE
    Champion:
  • 331 Answers
Check both sides of the cartridge for pins that make contact to the cartridge. Ensure they are clean and not covered with toner. Also make sure to use genuine cartridges.
Posted on Nov 24, 2014
Red lite on printer-won't print
The red light on this printer would normally indicate paper jam, a cover open or the waste toner container is full. I would recommend double checking that no small bits of paper have got themselves lodged around rollers inside the printer. Failing this I would check the status of the waste toner bottle to see how full the printer thinks it is.
This can normally be done using the printers software on the PC, but sadly I am unfamiliar with doing it for your particular machine.
Jun 05, 2012 | Samsung CLP 300 Laser Printer
Printer stays at "system initialyzing": not initializing and no sound to recognize
I have the same problem- It keeps saying SYSTEM INITIALISING. light is Green.It is a multixpress 63222DN. It was working fine until we replaced the cartridge. Now it is not even working with the old cartridge. Any one else with similar issue? Restarted, left it on all night , removed cartrifge and put back- replaced cartridge- removed drum and put back still no joy. The only thing as Ricardo mention - the fuse- how do you take it out?
Apr 14, 2012 | Samsung SCX-5530FN All-In-One Laser...
Toner light comes on and status light is red after replacing toner cartridge.
Oct 12, 2010 | Brother HL 5250DN Laser Printer
Printer stops when printing should begin with red light in status
There is a few reasons that cause the status light to turn red, paper jam, paper empty, toner cartridge empty, cover open and waste toner cartridge full. The PC Smart panel utility should give you an exact fault condition. Hope this helps.
Jul 08, 2010 | Samsung CLP 300 Laser Printer
My epson stylus C90 will not print, red light and green light bling on/off continuously
YOU NEED TO DISABLE THE INK LEVEL MONITORS AFTER RE-FILLING THE CARTRIDGES. GO TO PROPERTIES, MAINTENANCE, VIEW PRINTER STATUS, OPTION AND CLICK ENABLE STATUS MONITOR ONCE.
Jan 16, 2010 | Epson Stylus C86 InkJet Printer
What does the red status light mean.
Unplug the Printer and again Turn it back ON after few minutes. A Solid Red Light Status means that, more than often it is for Paper Jam.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 04, 2009 | Brother HL-5240 Laser Printer
My Brother HL5250DN shows toner light on (yellow) and status light on (red) even after toner cartridge replaced with new one. Already tried reset by holding down go button. Is the printer dead?
Try this..
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Oct 07, 2009 | Brother HL 5250DN Laser Printer
No lamp and a flashing red status light
The lamp has run out of its operating hours which is normally 3000 hrs. Replace the lamp and you will be alright.
May 28, 2009 | NEC VT465 Multimedia Projector
Printer suddenly stuck while starting up
eww this one can be lots of things!!!
make sure no paper jammed anywhere
make sure the print head is moving
make sure the ink cartridge is set down right
May 24, 2009 | Samsung CLP-300N Laser Printer
Will not print status page from printer.
Normally press the go button all lights will go on one by one then release and quickly press go again this usually prints a demo or status page.
Thanks J
Jan 10, 2008 | Brother HL-2040 Laser Printer
Samsung SCX 3405FW - Multifunction  fax / copier / - SCX-3405FW/XAA Logo
73 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
