Question about Uniden GPS
What is going on with my uniden IGO430? It said was out of memory so I put in a micro SD CARD. Then a question box appeared asking me if I wanted to delete my POI etc...did I want to restore to factor
I have tried the reset button. It still comes up with the same question box. So I tried the No answer, still nothing but the black square. Also tried to close out of the question box but still the same black square!
  • 2,509 Answers
Take the card out, maybe it is corrupted or requires formatting.
Posted on Nov 24, 2014
Testimonial: "I tried that just now, answering both yes and no to the question on different occasions yet still the black square appears where the question box was. Nice try though. Appreciate your time to answer!"
  • 4 Answers
SOURCE: Blank Screen
hello, replays those 2 smd ic's and the tomtom will work again!!
best regards
alex from holland
Posted on Jan 20, 2008
SOURCE: Putting maps on sd memory card
(Untried)
For C330 owners that want to have both Canada and US 2008 map update on their GPS this is what you have to do.
Must have:
1 - Street pilot C330
2 - 512mb SD card
3 - SD card reader of some form (some cameras will suffice)
4 - Garmin 2008 Map Update North America
What to DO:
1 - connect the GPS to the computer
2 - Insert the Map update disk
3 - Install the Lower 48 states, United States
(Reason - the C330 has around 1000mb of memory and the "US 48 states" map uses around 900mb" while Canada uses 400mb...which is why you will need that 512mb SD card later)
4 - Once the GPS is updated with the US map. Browse the Map update disk contents. This can be done with going to "My Computer" right click on your CD/DVD drive and click on "Explore"
5 - Open the folder called "img"
6 - Copy the file called "gmappromU.img" file is around 430mb. (This is the map file for Canada)
7 - Insert your SD card into your card reader and connect it to your computer. A window should pop up. If not you should see it on your "My Computer"
8 - Once you have navigated your way into the SD card directory. Create a folder on the SD card named "garmin" (no caps)
9 - Go into your newly created "garmin" folder right click and paste the "gmappromU.img" file. (This may take upto 20 to 30 mins)
10 - Once the process is complete, Rename the "gmappromU.img" file to --> "gmapsupp.img" (watch for spelling, no caps at all)
11 - Remove the SD card, Turn off your GPS, Insert SD card into GPS.
12 - Turn on GPS, let it load, and there you have it, the FULL North America Map.
When you are searching a state or province (depending where you are located) it will give you an option which map to use, Canada/Alaska or the lower 48 US states. Select your map and you are set to Go.
Posted on Mar 04, 2008
SOURCE: POI menu with custom POI does not appear anywhere on the C330?
For the "Custom POI's" menu to show you must have at least one Custom POI file loaded into the c330. Download and install the Garmin POI Loader, download any custom POI file and install on your c330 with the POI Loader and you will be in the Custom POI business on your unit.
Posted on Dec 12, 2008
  • 39 Answers
SOURCE: Reset
Tap "Reset factory settings" button to restore the factory settings to your TomTom XL. All your settings, including Favourites, your Home location, warnings for POIs and any Itineraries you have created are deleted.
Tap "Set Clock" button to select the type of clock that is shown and set the time.
manual download
go to tomtom website ----> support scroll down at the right hand side click Find downloads
hope this help
20/Apr/09
Posted on Apr 21, 2009
SOURCE: want to install xcsoar on a navigon 4310
Hi Mart136,
Were you able to get XCSoar to work on your Navigon 4310? I have the same problem with XCSoar and my Navigon 2100 Max. I did exactly as prescribed for installation on the XCSoar site but my 2100 Max keeps asking for the Navigon SD card .. it doesn't want to recognize a standard SD card.
Does anybody have any suggestions? Thx Much!
Posted on Nov 06, 2009
Tip
How to unlock /removed password in your memory card
hi,
most of the time we are putting a password in our memory card so that the others cannot view the important and sometimes the confidential files..but unfortunately we forget it so what we are going to do if we cannot open our memory card?if we are going to a cellphone shop we are spending much money ,if we buy a new one we also spend ...
i want to share how to unlock/ removed password in your memory card micro sd...this is applicable only for the card like MINI SD(this is bigger than micro sd and used in nokia phone like n73 ,n80 ) and for MICRO SD (used in nokia E-series ,classic nokia like 3500c ,6300 ,3110c ,7210c etc and other chinaphone )...
tools you need is high end phone like nokia 5800 ,n95 ,e63 ,e71 etc...(for phone using mini sd like n73
you need an adaptor..
here is how..
1. insert your micro sd at nokia 5800 , memory card password will appear just cancel it..
2. go to menu,applications then file manager then you will see that memory card is locked..
3.open memory card you will see memory card locked
4. press options >memory card options and format memory card will appear
5. wait until formatting is finished
6.you will now rename the memory card and the password is gone...
note: in this process all your data will be lost but but you have no choice because no other way to
removed your password than this...
i hope it will help you ,thanks for trusting fixya
on Feb 09, 2011 | Cell Phones
I can not get my pictures on my sd card
Can you describe in more detail what you are trying to do, step by step, and how the process is failing?
I have uploaded and downloaded pictures from my micro-SD card, both while it is in the phone, using a USB cable and setting the phone to "Menu | Settings & Tools | Tools | USB Mass Storage". Then the phone and the micro-SD card appear on my (Windows) computer as a removable drive, and I can just copy files in either direction.
I am also able to remove the micro-SD card, and plug it into an SD-card slot on my computer (with a micro-to-SD card adapter), and it mounts as a removable drive that way, too.
Note: if you have the micro-SD card in the phone, and you want the pictures you take to be stored on there so you can download them in one of the ways I've described above, then be sure to go into "Menu | Settings & Tools | 9. Memory | 1. Save Options | 1. Pictures" and set this option to "Card Memory", or else your pictures will get saved in the camera internal memory, and not on the card. This may be your problem if you are not seeing the pictures you expect on your memory card when you look for them. If you take Videos and/or Sounds, you might want to set those "Save Option" to the Card Memory, too.
Jan 02, 2010 | LG enV3 VX9200 Cell Phone
It doesnt work when i insert the card with my micro memory card and asks for a disk
Hi likkle_miss_,
The Micro adapter has no memory in it. It is just an adapter to use so you can plug your Micro SD memory card into a larger (SD) slot. The SD Micro memory card needs to be inserted into the adapter.
Kingston Tech Support
Apr 22, 2009 | Kingston 1GB Secure Digital Memory Card
Hi I just bought a micro SD Card for my cell phone and I have no clue how to use it and there is no instructions that comes with it at all so I was wondering if you could tell me how to put songs,photos,...
there is a slot on the phone where the sd card will go. once you install it the phone will recognise the memory card and most models will ask if you want to make the card your default storage device. select yes and everything you store from that point on will be on the sd card.
Dec 10, 2008 | Cell Phones
Password of Micro SD card
Format your SD card by connecting it to your PC using Memory card reader. Then you will never asked a password.
Sep 25, 2008 | Transcend Electronics - Others
Help
Insert the memory card in the nokia phone and change the settings to the memory card without password and then insert the memory card in your motorola phone.. it will fix the issue...
Otherwise, connect your nokia phone with your computer and transfer all the contents from the memory card to pc and insert it into motorolla, format the card and copy it from your pc... make sure your having pc suite for doing this...
Sep 10, 2008 | SanDisk 2GB microSD Memory Card
Cannot load music on Samsung sph a920
First. Take out your micro-sd card out of your phone. put it in the micro sd card reader. and then place that sd card into a card reader or printer. then go to my computer and copy your MP3's into a folder called, i THINK its called MUSIC, then take out of the computer, take the micro sd out of the sd car and place it back into ur phone. then go to menu and go to media player.then go down to Memory Card
May 22, 2008 | Samsung MM-A920 Cellular Phone
I'm having trouble with my 2GB micro SD Card
You have to format your micro SD memory card with your phone first before you can download files to it. With the micro SD memory card in your phone.
1)go to menu 2) go to settings & tools 3)go to memory 4)select card memory 5)***SELECT OPTIONS*** ---this will ask you if you want to format your card select YES, if there is a phone password it would be your last 4 digits of your number.
Now eject the memory card from you phone. Now when you put the memory card to your computer you should see the sub menus...my pics..my videos...my music...my sounds. Now all you have to do is just click and drag your music and photos to these folders.
Then when you add the memory card to your phone it will see all the music, photos, etc...
Mar 14, 2008 | Cell Phones
Problems with formating samsung e250 micro sd card
Did you try to format the card in the device thru Windows Media Player, or Rhapsody? If so, try formatting it thru My Computer instead. My Computer>Device Name>Right Click and select format. It is most likely NOT a virus if you have only put music on the device. It is most likely a corrupt file, or a database error. Best of Luck.
Sep 12, 2007 | Cell Phones
GPS Logo
93 people viewed this question
Top Uniden GPS Experts
Martin Murray
Oloyede Monsuru
ZenFire
Are you an Uniden GPS Expert? Answer questions, earn points and help others
