Question about Garden
When I start my ride able Ranch King Mower I get white smoke. I just had the oil changed & they did a Compression test - 100 psi and it is good. They did a leak down test 100 in -90 hold and it is
When I start my ride able Ranch King Mower I get white smoke. I just had the oil changed & they did a Compression test - 100 psi and it is good. They did a leak down test 100 in -90 hold and it is good. I think they used the wrong kind of oil in my tractor. They used 10W30 Synthetic oil. I was told they should have used 30W & on the internet I found out they should have used 5W30 Synthetic oil. If he used the wrong oil, would this cause the tractor to smoke white really bad? help ;(
  • Eugene Rounds Nov 24, 2014
    Hi Linda Millard, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Will need the complete make model number of the engine to look at its setup so I can give you ideas of what could be going on. The oil type and viscosity is fine.
  • 26 Answers
I only use 10w30 in my shop, and also have you checked to see if they over filled the crankcase with oil. The dipstick must pe pushed or screwed all the way in to check the oil..
Posted on Nov 26, 2014
MTD RANCH KING RIDING MOWER TURN KEY AND JUST CLICKING NOISE. DID PUT NEW SOLENOID TWO YEAR AGO. OLDER MODEL RANCH KING.RAN AT END OF GRASS YEAR BUT NOW JUST CLICKS ????
make sure all terminals are clean & tight on all + & - from battry to starter check that terminals are snug on ends of cables if still clicks put screw driver across selenoid with switch on from hot cable to hot cable both should be red you mite get a little spark thats ok should start if so cut off & try w/key sometimes switch or regulator will cause same problem sometimes they will keep starting with key
Feb 12, 2015 | Mtd Garden
I have a Briggs stratton 14 hp ohv I/c quiet model 287707. I had a guy change the oil & he put 10W30 synthetic oil in it. Now it smokes white smoke really bad. I think he put the wrong oil in
There is a very real difference between 30W and 10W30 oil. Whether it's synthetic or not probably doesn't matter. If you have the literature that came with the mower, it will tell you the recommended engine oil.
If they put in the wrong oil, they should make it right. You shouldn't have to pay twice for an oil change. It could be burning oil, since 10W30 is a lower viscosity than 30W. I would have them change it again, and see if it stops smoking.
Nov 24, 2014 | Garden
How do I find an inline fuse for a mtd ranch king 38inch 14hp riding mower
it should be under the cover right between your legs when you are sitting on the mower
Nov 15, 2014 | Garden
I want a drive belt diagram for a ranch king pro riding mower?
It's easier to find the correct information with a model number.
I have found a owners manual listed under MTD 130-390A
owners manual for a 2002 ranch king riding lawn mower.
Hopefully this is the same as yours.
https://www.google.com/webhp?sourceid=chrome-instant&rlz=1C1GGGE_enUS385US385&ion=1&espv=2&ie=UTF-8#q=ranch%20king%20riding%20mower%20manual
Pages go right and left or click on download.
Aug 28, 2014 | Garden
White smoke from the exhaust (not a gas smell), burns oil (compression test 120 on one side and the other 60)
the smoke my not smell like gas but check the oil it might the needle valves don't seat in the carb and the gas drains into the crank case and the oil being thinned out by gas can make it smoke nest to check is a blown head gasket they blow out between the cylinder and the lifter port and **** oil into the cylinder its about a $25 part no fancy tools needed just do the one with the low compression
May 29, 2012 | Garden
Ranch king riding mower will try to start but starter wont completely turn moter on then will stop and smoke starter
The starter smoking is an indication that you may have to buy a new starter because when you hold the ignition over to long it will heat up the inside and burn the coil wires inside. But I would try a battery with a higher cranking amp such as a 350 CC. It will turn the engine over faster and easier.
Apr 11, 2011 | Garden
I have a Simplicity model 1692762 with a 16hp Briggs and Stratton. The mower blew large plume of white smoke three times while cutting grass over a period of 10 minutes. Engine seemed to lose some power...
I suspect an internal engine issue such as a valve, the white smoke was oil and it could mean a bent, burned valve or damaged valve seat causing the valve stem seal to leak allowing the engine to **** some oil and burn it (the white smoke) and now you lack compression. It is less likely but possible the oil was overfilled and you "lipped" the piston which causes the compression to drop. check the compression, 100-120 is normal, less than that means bad internal parts.
May 27, 2010 | Garden
Was mowing with riding mower was running fine started missing and black smoke coming out of exhaust stopped mower immediatetly oil in carb now and when try cranking it just cranks and cranks not firing
Pull plug and check compression. When cranking see if bottom pulley turns from engine. If compression is below 90 psi it won't start and you have an internal problem. Stopped mower immediately sounds like motor blew. Also check side of motor for cracked block, Good luck.
Mar 21, 2010 | Briggs & Stratton Garden
White smoke and blade won't engage
Sounds like a low compression problem. The piston rings have most likely failed and oil is seeping past them and burning, thus the white smoke. An engine needs three things to run...Spark, Compression, and Fuel. Just take the mower back as it is still probably under warranty. Mike. Rate 100% please.
Jul 01, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
93 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
