Question about Extended Technology Systems, Inc. SalonBiz LIGHT
I have been running SalonBiz Light for years. For some reason I am now unable to run a daily summary report. The year is almost out and I need my reports. Any help?
I have backed it up daily however, I am afraid to do anything. I do not want to lose all of my data. It has happened before. :(
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
I'm drawing a blank on this one.
Posted on Nov 30, 2014
Wish to down load "Colonial First State Summary Reprorts
https://www.colonialfirststate.com.au/content/firstnet/demos/main_08.html
Mar 30, 2014 | Microsoft Windows 7 Professional Upgrade...
Knock sensor fault and VSS signal form A/T malfunction
wow another no year car post. are you kidding?? and no engine option stated, and is an engine question.
2.5L , 4.0L or bigger? im clueless.
parked or moving, flat ground or hills or both. ? it cuts.????
all fuses good?
Check engine light "CEL" out running, no ? then scan it.
report all DTC errors here. (do not interpret them, post them)
your posta forms many issues as one, they are not. (we hope?)
cuts off (is this engine stalls,misfires, bogs or hesitation only) ???????
VSS, who said vss is bad, if the PCM said it , then ITS bad or disconnected. (vss = vehical speed sensor,) location varies by year and engine and tranny options.
a/T malfunction, who or what said that? PCM? TCM? or seat of pants?
did you just pull this engine then put it back in?????history??
when was the last time this car was daily driver, last month or year?
tell more get more, lots more,and for sure year, and engine option.
Feb 11, 2014 | Jeep Cherokee Cars & Trucks
2006 chevy cobalt(85000 miles) check engine light comes on and stays on. I am getting the check engine light code p0420. Engine seems to be running smoothly.
http://www.obd-codes.com/p0420
TSB Number: 3316 NHTSA Number: 10017210 TSB Date: n/a Date Added to File: October 27, 2005 Failing Component:Electrical System Summary:Diagnostic trouble code P0420 may set on low mileage vehicles, or shortly after catalytic converter replacement
there is a service bulletin for this.
http://www-odi.nhtsa.dot.gov/cars/problems/tsb/results.cfm?start=1&SearchType=DrillDown&type=VEHICLE&year=2005&make=CHEVROLET&model=COBALT&vehtype=PC&typenum=1&component_id=0&summary=true
Aug 02, 2011 | 2006 Chevrolet Cobalt
Trying to startup SalonBiz Light program - keep getting message, "Maintenance operation being performed on database. This application will now quit. Try to restart your application in a few...
Your program file is corrupted and will have to be re-installed, first find where your database files are. Default will be C:\Program Files\SalonBiz Light\Data\sb.mdb and copy and save off your computer, for extra safety you can also save the entire Data file. Go to Add or Remove Programs and delete SalonBiz Light, then re-install SalonBiz Light and replace the default sb.mdb file with the one you saved, restart program and you are back in business.
Mar 30, 2011 | Extended Technology Systems, Inc. SalonBiz...
I haven't had any trouble following the manual to program and run this machine until today. Now it appears to be adding all the days together...I have used the Z daily function and it just continues to...
This is almost impossible. The first thing to do is make sure you are not accidentally performing an X read instead. Depending upon the brand, the top of the daily report should show 'Z' , 'Z1', or 'ZZ1' If it shows X instead of Z or the total keeps rising every day, then you are not performing a Z (reset). you are printing an X (examine only report). If you still have trouble, let me know the brand and model.
Oct 10, 2010 | Casio Parts Cash Register PC Desktop
What and where do I disconnect.
Ah Yes..good reason.
Go to your fuse panel (under your dash). Remove the fuse marked "door". It may be named something else, perhaps "locks".
Once you find and remove the fuse, give it a try at speed. Hopefully the fuse only supplies door lock power and not your windows. More than likely this will render your door locks completely manual.
However, there was a recall on this vehicle for this problem.
NHTSA Campaign ID Number: 92V135000
Component: Structure: Door Assembly: Latches And Locks
Manufacturer: Toyota Motor Co., Ltd.
Year: 1989
Make: Toyota
Year of Recall: 1992
Type of Report: Vehicle
Potential Number of Units Affected: 554,910
Defect Summary:
The electronic control unit (ECU) for the power door lock system can fail, causing the contacts to "weld", and resulting in door lock solenoid damage, with failure of the door to lock or unlock, even under manual operation.
Consequence Summary:
If the door fails to open after ECU failure, vehicle occupants would have increased difficulty exiting the vehicle in an emergency.
Corrective Summary:
Install an additional sub-circuit relay control to prevent malfunction of original relays in the ECU.
So the thing to do is contact your local Toyota dealer and have the recall performed.
I hope this helps!
Best regards,
May 06, 2010 | 1998 Toyota Camry
Machine does not complete the wsh cycle and we cannot open the do
f02 is a motor problem.
may need new brushes after 4 years use.
Jan 26, 2009 | Hotpoint  Standard Range Hood
0 THE YEAR TO DATE OUT OF THE CASIO TK-2700
Hi.
Have you had periodic reports setup on this machine? If you do daily reports, then you need to use the periodic report mode (Z2) for a yearly report. Try turning to Z2 then press 1 then CASH.
Make sure the top of the report shows 'Z2' and not 'X2'. If it shows the X then it probably hasn't been setup for periodics.
Mark
Jan 02, 2009 | Casio Parts Cash Register PC Desktop
Computers & Internet Logo
81 people viewed this question
Top Extended Technology Systems, Inc. Computers & Internet Experts
David Payne
David Payne
Are you an Extended Technology Systems, Inc. Computer and Internet Expert? Answer questions, earn points and help others
