Question about Garden
I have a Briggs stratton 14 hp ohv I/c quiet model 287707. I had a guy change the oil & he put 10W30 synthetic oil in it. Now it smokes white smoke really bad. I think he put the wrong oil in
I have a ranch kind ridable tractor mower with a Briggs stratton 14 hp ohv I/c quiet model 287707. The father retired who helped me with my mower/tractor each year. this year his son did the oil change and he put 10W30 Synthetic oil in it. It is now smoking white smoke really bad. the Compression test - 100 psi, is good. The leak down test is 100 in 90 hold and good. but it still smokes. I think he put in the wrong oil. Can you help me on what oil should be used? I was told 30W oil. I also saw on line 5W30 Synthetic oil...
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 117 Answers
There is a very real difference between 30W and 10W30 oil. Whether it's synthetic or not probably doesn't matter. If you have the literature that came with the mower, it will tell you the recommended engine oil.
If they put in the wrong oil, they should make it right. You shouldn't have to pay twice for an oil change. It could be burning oil, since 10W30 is a lower viscosity than 30W. I would have them change it again, and see if it stops smoking.
Posted on Nov 24, 2014
Testimonial: "Hello C.E.D, Thanks for your help. I have a friend who is going to change the oil for me. I don't want to take it back to people who have screwed with it once. Then I will be giving them a second time to screw me over, just because I am a lady, they think they can do this...mmmm burn me once, shame on you, burn me twice, shame on me... thanks :)"
3 Suggested Answers
  • 6468 Answers
SOURCE: Ariens 1640 Zoom Riding Mower with Briggs & Stratton engine smoking
check to see if the oil smells like gas the needle valves go bad in the carb and gas over flows into the crank case also the head gaskets go bad and **** the oil from the crank case
Posted on May 10, 2012
  • 6468 Answers
SOURCE: briggs & stratton intek 17.5hp smoking
check the oil see if it smells like gas if so the carb is not sealing over filling and draining into the oil a new carb can go bad or ts gas from the bad old one
Posted on Sep 25, 2012
Briggs & Stratton 18 hp motor oil white
White oil in any motor indicates the oil has mixed with water . Drain the oil change the filter and find out how the water got in.
Oct 01, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Need to know the weight of the motor oil
sae 30 in winter sae 40 in summer i preffer rotela
Aug 20, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Vertical OHV Engine 18 hp blowing white smoke engine run great but a lot of smoke and also have oil being spit out of the black hose that come from engine to the carb.
Check your oil.
If it is overfilled, milky, or smells like gas. Your going to need to change that ASAP. It sounds like the float has stuck in the past or is still sticking, and it has flooded the crankcase with gas, which has mixed with the oil. And because it is overfilled it comes through the breather hose into the carb. This also explains the smoke most probably because the oil is spewing in the carb through the breather and being burned.
Jul 05, 2011 | Briggs & Stratton Briggs Stratton Intek V...
What is the oil capacity. I changed oil and cant find manual how much to put back
Briggs & Stratton takes 48 ounces of SAE 30 and the Kolher would take 2 quarts of 10w30. However, it is best to always verify the level with the dip stick, if you over fill it will smoke.
Sep 19, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
What's the recommended oil for this engine. can't find my manual
You can use 10w30 weight year round. I highly recommend you use synthetic oil in this air cooled engine and change the oil/filter every 50 hours. I think you will find it holds 1.5 quarts with filter change. Do not overfill.
Apr 24, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Changing oil in Biggs and Stratton engine
Use 10W30 weight oil. The capacity is 1.5 Quarts (48 ounces) with filter change. I highly recommend you use 100% synthetic oil in an air cooled engine. Change the oil and filter every 50 hours of use.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton 22hp v twin OHV smoking badly
First thing to do is pull your dipstick and check for broken or missing O-ring also as you pull it, look to make certain that it was seated properly and all the way locked. If either condition exists, you will be leaking into the crankcase which will cause your symptoms
Jul 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
18 HP V tech B&S single is smoking only 4 years old
18HP vertical Briggs & Stratton vtech twin ohv; can't find oil leak; motor runs great; is leaking onto housing where motor is bolted to; any suggestions where leak may be coming from????????
Jul 01, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
265 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
