Question about Coffee Makers & Espresso Machines
How do I hook up relay connections?
Electrical repair
  • 21 Answers
A relay is a way of switching from a low power source to a high one. Many times a low power source is connected to a switch. When the switch is turned on, the relay turns on, allowing the high power source to run the appliance. how do I hook up relay connections? - 25295406-4xx2w15eypeymt23g3yer4mi-5-0.gif
Depending on the type of relay you have, it will have different pins that go different places. The picture above is just an example. Most relays will have a part number on them. Google the part number and look for a schematic or pin-out for your specific relay.
Posted on Nov 24, 2014
Testimonial: "Many thanks for this explanation. I have the pin out for the relay. Just missing the wiring assignments for the expresso maker (Proline KES100) to attach them to the correct relay terminations."
1999 Playmouth 4 cylinder will start after several tries. have new fuel pump, fuel filter, spark plugs and wires, checked ignition coil pack and connections and ASD and fuel pump relays. Everything checks...
I see you replaced the fuel pump , spark plugs an wires , fuel fliter an checked ignition coil pack , Connections ,ASD relay . And everything checks OK ?????? How did you check these thing's ? Testing electrical circuits with a DVOM - digital volt ohm meter ? Fuel pressure testing the fuel pump before replacing ? Does the vehicle have spark ? How about hooking up a scan tool that can view engine sensor data .A bad coolant temp sensor could cause hard starting. Did you check the dark blue with yellow trace wire at the PCM connector 2 pin 67 . This is the PCM control side of the ASD relay . Do you know how a relay works ? how to test at the relay base ? where in plugs into.
How to test computer transistor driver without scan tool
Electric Testing Techniques You Need to Know
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
VEHICLE RELAYS Testing from the relay base
VEHICLE RELAYS Operation Diagnosis
Jun 01, 2017 | Plymouth Neon Cars & Trucks
I need help hooking up new headlights, with halos and LEDs, i nned them to turn on right wen the car turns on... Not wen i turn lights on
For that you will need to be able to do some serious wiring. You will need to find a relay in the engine compartment fuse/relay box that turns on when you turn on the key, like the electric fuel pump relay, for example. Next you will need to calculate the amperage draw of all of the lights you are going to hook up. If the fuse for the relay you chose is smaller than the amperage you need to serve both the fuel pump and the lights then you will need to make a fuse connection at a spare in the fuse box to connect to the new relay output and input (see below). The fuel pump relay has control and supply wires on it. The supply wires actually supply the power to the fuel pump. The control wires simply turn on the relay when you turn on the key in the ignition. You need to hook up the control wires of the fuel pump relay to the control wires of the new lights relay. As stated earlier, the supply wires are then hooked to the relay and, in turn to the supply fuse. Make certain that you use some heavier wire for the supply circuits. Thinner wires may be substituted for the control wires. Solder at the fuse box side and use spade connectors at the lights side...good luck!
Jan 11, 2013 | Cars & Trucks
Microwave is not heating food up. It starts and runs the time but the food is still cold after the time is comlete
Often this is due to a bad door switch located inside behind the area where the door hooks go into the oven. Sometimes, the problem is due to a bad connection or a bad relay on the control board. You can send it back to GE, and it should cost from $30 to $40 dollars to repair.
Dec 07, 2010 | General Electric Microwave Oven
My fuel pump does not work while hooked up to the electrical system. Once I hook it up to an outside electrical supply it works. The fuse is OK. Where might the problem be?
check for power at the plug to the fuel pump. No power? check fuel pump relay. check for proper ground connection or make a new ground connection.
Aug 09, 2010 | 1998 Lincoln Town Car
97 jimmy wiper motor relay fuse problem hear motor running and wipers don't go. fuse or motor?
if u hear motor not elect problem -most likely linkage unbolted from motor with motor running try to move the wiper arms if move freely than need to remove cowl and check the linkage hook up to motor -if wipers dont move freely than possible motor damage/seized linkage damaged but still would have to look under cowl at connection at linkage
Jun 10, 2010 | 1997 GMC Jimmy
I just replaced a Hayward boost pump with a Polaris boost pump using the same electrical wiring which is connected through a Jandy control box. The problem is the pump will not turn on/off through the...
The Jandy Aqua Pure, PDA, or One Touch control system will absolutely turn the pump on and off . Brand and type are not relevant to the controller. Each "Relay" allows or restricts power to whatever device is connected to it. Find the relay the pump is connected to. Move the wires to a different relay (aux1, aux2) and try again. If the power is correctly hooked to the relay, it must work or there is a problem with the relay itself (possible). Rob
Mar 19, 2010 | Polaris Pb4 - 60 Booster Pump
Trips breaker and get "PF" on display even when not tripped
This error code indicates "power failure" was detected. This could be caused by a bad/loose connection at either the logic board, the relay board, or at one of the three main power connection terminals on the back of the dryer. The logic board is located inside the control panel. The relay board is located in the base of the dryer. You can unplug and reseat electrical connections at these locations and check the main power cord hook-up at the terminal block. Hope this helped and best wishes.
Sep 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
PF error on Maytag neptune gas dryer
Aug 30, 2009 | Maytag Neptune MDG5500AW Gas Dryer
I don't understand my wiring diagram.How does the positive and negative cables hook up to the starter relay and to the battery.I have one small red wire coming from my wiring harness does this wire connect...
Hi and welcome to FixYa,
If the starter relay in your version uses blue / white and red / white wires, then to my understanding, connection would be:
  • blue / white - goes to the start switch and is supplied with +12 on starting;
  • red / white - goes to the starter circuit cut-out relay. This cut-out relay controls whether the starting relay gets a ground based on neutral/gear and clutch lever conditions.
Good luck and thank you for asking FixYa.
Jul 08, 2009 | 1985 Yamaha XJ 700 X Maxim
1985 Yamaha xj700 Maxim-I am confused about my positive and negative cables.I have a red wire coming from my main harness and a cable on the positive side of the battery does the red wire and the red cable...
Pls see your other post, but basically:
  • in most, one end of the red wire is connected straight to the battery's + terminal. The other end of the red wire goes to the main fuse;
  • the black of course as you posted goes to the ground;
  • interchanging the 2 wires from the starter relay would make no difference;
  • the starter relay is not directly grounded;
  • the starter relay's + wire goes to the starter button;
  • the starter  relay's - wire goes to starter cut-off activated by safety interlocks (neutral and clutch lever).
Jul 08, 2009 | Yamaha XJ 700 S Maxim Motorcycles
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
