Question about Samsung LN46C550 TV
What can cause my samsung 46 inch smart tv to turn on and off
When I first plug my T.V in it turns on by itself. the red light blinks about 3 times then you hear the power on chime and then it actually turns on but only stay on a few seconds then blinks a couple times before actually turning off and then starts the cycle over and over again. I've checked all the capacitors there fine. i dont have the original remote but ive managed to program my verizon fios stb remote before it turns off and between the power cycles i can change the input, the other day i plugged it into my computer as a second monitor and started playing with the touch display buttons and some how i finally got it to stay on and it worked perfectly until i turned it off to see if it was fixed and of course it wasnt. it started power cycling again but a message came on the screen saying something about the main board was changed and to get into sevice mode and set the options for type front display.. im at a loss and when i plug it back into my computer it starts to load and fix that message but i cant get it to stay on long enough to finish.. to me it seems to be stuck on some kind of demo or reset mode because when i play with the display buttons the sequence of the flashing lights seems to change and i can get it to stay off without unplugging the power cord. Could it be in some sort of mode or is there a problem internally?
    Top Expert:
  • Samsung Master
  • 74,136 Answers
Sounds like main board fault. Contact any service technician. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Posted on Nov 24, 2014
Why won't my 46 inch Smart TV power on. The power on/off red light just keep blinking.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Dec 18, 2015 | Samsung 5500 Series UN46F5500AF 46" LED...
What is the cause bravia 3 blinks?
Power supply has a voltage spike caused by damaged capacitors.
Jul 19, 2014 | Sony Bravia Kdf-46e3000 46-inch 1080p 3lcd...
Tv wont power on red light continuously flashes
Hi,you need to have the capacitors in the powersupply replaced
Oct 15, 2013 | Samsung UN46D6400 46 Inch 3D 1080p Smart...
Tv goes off then red blinking light comes on
Hello it is the bulb the bulb's on the Rear projection tv are ****. Buy  new tv cause it costs alot to have these tv fixed.
Jan 10, 2009 | Sony KP-46WT500 46" Rear Projection...
Tv turns itself off after a few moments of clear viewing
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues
good luck
please mark the post with a fixya!
Feb 07, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
TURNS OFF BY ITSELF
my tv starts turning a red color and then turns off by itsself then i have to unplug it to turn it back on every 5 mintues or so.
Nov 14, 2007 | Toshiba 46H84 46" Rear Projection...
Samsung 46" DLP
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Samsung LN46C550 TV Logo
110 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
