Question about Kenmore 22422 Top Load Washer
Kenmore 70 washer
My Kenmore 70 will not agitate. It is a very old washer. From what I can tell the model is B705701, but then again I probably should have had my glasses on when I read it. I followed some direction to remove the agitator from this , yet my innards do not look the same. I pried the cap off with a screw driver and now I cannot get it back on. Nevertheless, this is what I noticed: The cap sits on a bolt of sorts that will turn right and left with the shaft it rests on, hence agitation. However, it is only the shaft and the cap that moves and not the agitator. But when I remove the bolt and then the agitator I do not see where it should fit into a groove. Can you help by telling me two things: What maybe the problem and how do I get that darn cap back on? thanks a million
  • 126 Answers
If its that old your lucky you got the agitator off! there .should be a spline on top of transmission shaft. the agitator will slide down on it. your problem will probably be the wig-wah located on top of trans.take the back off the washer you will see 2 solenoids this is the part
Posted on Nov 22, 2007
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
My Kenmore 70 series is 18 years old. It will not
Hello. Since your machine is 18 years old and the agitation/spin is costly to repair I would definitely recommend a replacement washer.
Jul 06, 2009 | Washing Machines
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
Mar 27, 2009 | Kenmore 22422 Top Load Washer
My washing machine will not spin or agitate
Does the washing machine empty as normal? I am assuming it does and think the brushes on the motor could be worn. Hope this helps.
Jan 19, 2009 | Kenmore 24932 Top Load Washer
Kenmore Washer 70 Series - sheets stuck around agitator
The transmission probably stripped the worm gear that drives the drum - you would have to crack it open and take a peek.
Nov 24, 2008 | Kenmore 15864/15862 Top Load Washer
Same problem
ck lid switch blocked pump would not prevent spin unless it was locked up then probably wouldn't agitate either
Jul 20, 2008 | Kenmore 22422 Top Load Washer
Kenmore 70 series washer
the agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
Jul 19, 2008 | Kenmore 22422 Top Load Washer
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
112 people viewed this question
Sal De
 Brian Main
Brian Main
