Where can I get a new centre spindle to stop the agitator flying into the lid?
Asked the repair people
  • 3,506 Answers
It is hard to advise without any make or model inforamtaion etc.
Posted on Nov 27, 2014
Testimonial: "Thanks for your response. It's a Kelvinator 380 de luxe model from the late 1980's."
  • jfhinton45 Nov 28, 2014
    It is getting a little old for parts but if you have a local appliance parts and service place they should be able to find out if it is still going to be available OR you might also Google it with the make and model and you may find a parts supplier that can assist you. Good Luck with it.
1992 Lincoln Mark vii speedometer not accurate
Output shaft speed sensor problem.
Lincoln Mark VII Maintenance & Repair Questions - CarGurus
www.cargurus.com > Questions > Lincoln > Mark VII
CarGurusJohnny asked a 1988 Lincoln Mark VII LSC Maintenance & Repair question about a ...nicolse7 asked a 1992 Lincoln Mark VII Maintenance & Repair question ...
Sep 08, 2015 | 1992 Lincoln Mark VII
How do I remove a stuck paper tray
Some useful adivic:
Frequently Asked Questions
Clear paper jams Brother
How do clear paper jams Brother
If you still can't remove stuck paper, it's REALLY stuck. Take it to a repair service. apart of removing all that paper, they should diagnose WHY you got a mega-stuck.
Forced removal might damage your printer
Aug 27, 2015 | Brother MFC 3360 INKJET MULTIFUNCTION...
How do I remove spindle from washing bowl Model AWM270JW3062?
To remove the agitator you're going to need an extension for a socket. The size is 7/16. Remove the lid right on the tip of the agitator. There may be a plastic lid you will have to pull out of the middle. Hold the lower agitator while loosening the bolt turning your driver to the left. Be careful that part has agitator dogs in it and you don't want to lose them or your agitator wont work correctly.
May 19, 2014 | Speed Queen AWS52NW Top Load Washer
Washer wont spin or drain
Yes, you can check the LID switch as it needs to activate the program to move forward. If the water fills up and there is no wash cycle, check if the motor hums, if so check the capacitor, check the friction on the spindle/drum. If the spindle does not agitate with movement the assembly must be reset.
Jan 23, 2013 | Washing Machines
I has delete file on memory's intermec cn3, How to recovery file ?
REPAIR YOUR OPERATING SYSTEM AS FOLLOWS
Download the operating system from this link: http://www.microsoft.com/downloads/en/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en
or
if you have it, install it using the procedure below:Boot From the Windows XP CD
  • You must boot from your XP . Please make sure it is the same version of Windows that is currently installed on your computer (ex. XP Home cannot repair XP Professional). Place the CD in your CDROM and start your computer. Newer versions will work as well (ie. Windows XP Pro SP2 CD will work on an older WinXP Pro SP1 installation)
    you will be asked to press any key to boot from CD, so do just that.
    Step 3: System repair steps
  • A blue screen will appear and will begin loading XP setup from the CD.
    simply let the CD load without pressing F6.
    Once completed, you will be confronted with "Windows Setup". You will be asked to setup up Windows, or repair Windows with the recovery console. Choose the FIRST option, NOT recovery console.
Choose F8 to continue.
  • Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation or install a fresh copy of Windows XP.
    If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
That should be it. Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts
  • If this solution helped Never go to drive C: again. Vote for this solution and rate it
Apr 20, 2011 | Computers & Internet
My ksuser dll for windows xp profesional
Just boot from the xp professional cd and run the recovery console.
or
Apr 19, 2011 | Microsoft Windows XP Professional
The DVD player tried to read the DVD and stopped. It said H07 and then display reads STOP
Many Panasonic DVD units use a traverse unit (spindle motor/laser assembly) - and the H07 error indicates a failure of this component block (the spindle motor is the part of the unit which fails first).
This part is not repairable, it can only be replaced by a qualified authorised Panasonic technician - then it must be aligned and the firmware updated/configured to the player. The problem with this is the costs involved; a new spindle motor/laser unit (through Panasonic directly) would cost around $200 trade plus the labour/fitting/alignment - it could be a further $200 - making it uneconomical to fix - since this would be about the price of a new player.
However, you can submit the unit to a service centre, for a quote on the likely part/labour cost(s), then make a decision afterwards - whether to go ahead with the repair or cut your losses and buy a new player.
Blu-Ray players (with DVD playback support) are becoming cheaper to buy nowadays while repairs to DVD players become more expensive. It's up to you.
Mar 28, 2011 | Panasonic Televison & Video
The screen goes blue and a message comes up closed windows to protect computer. restart with f10 or f2. neither one will fix the problem
May be you have a problem with your MFT or FAT so to correct that follow these steps :
1- Reboot your computer with a Windows Installation disk.
2- When you are prompted to choose to do installation or repair, choose to repair your computer.
3- You will be asked o configure your Keyboard layout. chosee your keayboard layout.
4- You will then be asked to select partition where your system is installed.
5- The one that start by C:\WINDOWS if you installed your system on it, otherwise choose the correct one.
6- Enter your ADMINISTRATOR password when asked.
7- when you get the command line interface C:\>, type (CHKDSK C: /P), without the brackets, and hit enter.
8- You system will check the partition for errors and correct them, the operation take about 10mn
9- When done reboot your computer.
Enjoy
Good luck
Feb 28, 2011 | eMachines ET1161-07 Desktop PC
Maytag lat9593abw does not agitate
The lid switch, which prevents the washer from agitating or spinning when the lid is open, could be malfunctioning. If that happens, a built-in failure detector will stop washer operations until the lid switch is repaired. Replace with this part. Here is a video to walk you thru the repair.
Dec 05, 2010 | Maytag Washing Machines
Washing Machines Logo
Top Washing Machines Experts
