Question about Toys
Make the globe spin seems to be locked in poition
  • 3,506 Answers
It is not clear what you are saying or asking but if the globe is locked in position find the locking mechanism and unlock it.
Posted on Nov 24, 2014
We have the lighted movable Fisher Price Globe. Problem is... it won't move... seems to be stuck. Can you tell us how to release and what to release so it is free flowing? "thanks"
I just bought one at a flea market today, and had the same issue. After a couple of searches, I came up with the solution. An Etsy seller had this to say: "You might be afraid that the globe is "stuck" and won't turn, but you just have to be firm to turn the globe. You'll hear loud clicking when you turn it; this is because the globe is made to stop at certain points so that the viewer can easily meet up with the white dots." I tried turning mine firmly, and it did finally make a loud click and turn. It does not spin freely like a normal globe, though. I also found a PDF of the original instructions: http://service.mattel.com/instruction_sheets/76609.pdf
Sep 06, 2010 | Fisher Price Toys
Our display panel is very dim, we need to turn out the kitchen light just to see it. What can we do to fix it?
there seems to be a power short to the ilumination globe it would seem its not getting enough power or the globe simply has a short try replacing the globe and if that does not work get a service tech in
Jul 04, 2010 | Whirlpool SB160PEE Gas Single Oven
Clutch fills like its working but will not engage can you tell me a little about installing a clutch mabe i doing some thing wrong
when you replaced the plates into the holder and you put the cover back onto the last clutch plate there is several poitions it can go back into if you keep spinning it around when you get to the right postion it will slip in further trus making it tighter on the clutch plates the is the right poition it should be in sorry if the desprition is a bit hard to understand any other probs just ask and ill try to clarify the best can
May 10, 2009 | Yamaha YZ 125 Motorcycles
I cant loosen the locking ring that holds the glass globe on my ceiling fan, sprayed it with wd40, still no luck. need to replace the broken globe but i cant get it off
I am having the exact same problem. The locking rings seem to be distorted like they melted from the heat of the light or something. Any suggestions?
May 04, 2009 | Dryers
Have installed new epson black ink cartridge in c1100 printer. unable to press down locking bar on this new cartridge
Try re-inserting it again, L/H side should go in slightly ahead of the R/H. Give it a push & wiggle and it should lock in. An alternative method of fitting the cartridge is to open the top cover & remove the PCU. With the front cover shut you can rotate the cartridge "carousel" until the black is in the 2 O'clock poition when looking from the R/H side of the printer. You can now insert and lock the cartridge into place.
Please take a moment to rate this solution, thanks.
Apr 11, 2009 | Epson Aculaser C1100 Printer
Seat belt
I would check the orientation of the roller assembly. This has a roller ball which must in the correct poition. sometimes they get jeked out of place.
Mar 12, 2009 | 1993 Jeep Grand Cherokee
Unlocking my n95
I would suggest confirming whether the phone is SIM locked. If it is, it will be locked to a particular network operator (Globe Telecom) and the phone therefore would not accept any other SIM card.
In this case, you would need to refer to Globe Telecom to unlock your phone. Other parties do not have the authority to unlock you phone.
Please revert to me if you were refering to a different type of lock system.....
Oct 28, 2008 | Nokia N95 Cellular Phone
Replacement of Light globe in Ice Dispenser
USE LESS THAN 5W GLOBE IF AVAILABLE
OR
7 W IS A STANDARD GLOBE BEING NORMALLY USED, WILL & SHOULD NOT AFFECT THE POWER CIRCUIT AS PER MY EXPERIENCE
BEST WISHES
Dec 12, 2007 | Refrigerators
Olympia OL 3000 Info Globe
Dit it stop all the led messages?
Mine started to show weird messages or nothing at all.
I removed the blue top and the spinning device inside has small screws that you can remove.
I cleaned the electric contacts with alcohol and now, the globe is working again.
Nov 02, 2007 | Electronics - Others
Toys Logo
46 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
