Question about NetGear Neo TV 550 Ultimate HD Media (AAC4001NTV550100NAS)
It powers up and then after I go through the steps to set it up it says check network connection.
  • 3,506 Answers
You need to check and ensure that you have a good network connection
Posted on Nov 24, 2014
How do I activate Wi Fi on Kindle Fire?
Step 1
Power on the Kindle, and then press the "Home" key to open the home screen.
Step 2
Press the "Menu" button, and then tap "Settings" to open the Settings menu.
Step 3
Tap "Wi-Fi Networks" to open a list of available wireless networks.
Step 4
Tap a network to connect. If security is configured on the network, a password dialog box opens.
Step 5
Type the network password, and then tap "Connect" to connect.
Jul 01, 2014 | Computers & Internet
I cannot get the TV to connect to the internet any more. One day it was working and the next it was not. I have rebooted the entire system to factory settings, taken out the power cord, rebooted the...
Error 1106 is an indication that the Domain Name System (DNS) was unable to resolve. Follow the steps to check the Internet connection: 1. Check the Network Connection. 1. Using the supplied remote, press the Home or Menu button. 2. Select Network Setup . 3. Select View Network Status . 4. Select Check Connection . If any of the connection settings fail, verify that the TV is properly connected to an active Internet connection. Follow these steps, if the error continues to appear: 2. Unplug the TV and wait 60 seconds. 3. Power on and off all of the networking equipment, including the modem and router. 4. Allow the Networking equipment to reset after powering them of and on. Test that the connection is active by using a computer. 5. If the issue continues, wait and try viewing the content later.
Sep 18, 2011 | Televison & Video
No puedo conectar mi ps3
WIRELESS (WIFI):
Step 1: Turn on the PS3
Step 2: Once on main menu go to settings and under settings select "Network Settings"
Step 3: Select "Internet connection settings" if prompted that you will be disconnected from the internet select "Yes".
Step4: Select "Easy" on types of installation.
Step 5: Select "Wireless" to choose what kind of internet connection you want.
Step 6: Select "Scan" to search for internet access points.
Step 7: Select your home connection when the screen comes up with all the found access points. If your home Internet access point requires a password enter the password when prompted and saveyour settings.
Step 8: Test the connection to check if you configured your settings right if successful you are good to go. If not go back and check your connection settings for your home internet access point. You are now connected to the internet!
HARDLINE (Wired): Must connect ethernet cable to PS3 before turning it on!
Goes like this: Arrows are the cable (===>)
Internet Line ===>Router ===>PS3
Step 3: Go to "Internet Connection" and select it to Enable it.
Step 4: Select "Internet Connection Settings"
Step 5: Select "Internet connection settings" if prompted that you will be disconnected from the internet select "Yes".
Step 6: Select "Easy" on types of installation.
Step 7: PS3 will automatically check your connection network setup and set the settings for you.
Step 8: The settings will appear and press x to save the settings.
Step 9: Test your connection if it was successful you will see succeeded nest to "Obtain IPAddress" and "Internet Connection" you are now connected to the internet!
Feb 19, 2011 | D-Link DIR-300 Wireless Router
In need to upgrade my wgr614v6 so i can run my windows 7 laptop
no need for you to upgrade your router to run win7. Just follow this steps below. This might help;
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Mozilla Firefox.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a username and password. By default, the username is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it is 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista & Windows 7 please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Apr 21, 2010 | NetGear WGR614 Wireless Router
Download won't initialize
5. Power cycle.
If you are using Windows Vista, please follow the steps below:
Apr 21, 2010 | NetGear WNR2000 Wireless Router
Trouble installing wnr2000
a. Please open any web browser like Internet Explorer or Netscape Navigator.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
Sep 08, 2009 | NetGear WNR2000 Wireless Router
Where do i finde ny router settings so i can type them in?
5. Power cycle.
Aug 09, 2009 | NetGear WGT624 Wireless Router
Can not get the wireless router to connect
5. Power cycle.
Apr 09, 2009 | NetGear WGR614 Wireless Router
I'm able to connect to the internet without my netgear router. However, when I plug my connection into the router I'm unable to connect. I've recycled the router, tried different ports on it, and have...
Hope this step by step router installation will help...
5. Power cycle.
Mar 16, 2009 | NetGear WGT624 Wireless Router
Will it work
hello!
yes, the router will work with your pc and xbox 360.
You have to set the internet connection first between you modem, router and pc before you configure the xbox 360. try this and see if it will work with your network
you may try this and see if this help solve your problem
to set up your modem and router:
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
to set up your xbox 360:
Step 1: Power down the Xbox and connect a regular straight thru Ethernet cable from one of the numbered ports on the router and plug the other end of the cable into the Xbox™’s Ethernet port.
Step 2: Power on the Xbox without a CD in the tray and the Xbox Dashboard should appear.
Step 3: Select Settings and press A on the controller.
Step 4: When the Xbox screen appears, select Network Settings and press A on the controller.
Step 5: When the Network Settings screen appears, select IP Addresses and press A.
Step 6: Under Configuration, select Automatic and press A on the controller. Take note that the IP Address being shown will be the Xbox’s IP Address. Press B to return to the previous screen.
Step 7: When the Network Settings screen appears, select DNS Servers and press A.
Step 8: Under Configuration, select Automatic and press A on the controller to save the changes. Press B to return to the previous screen.
Step 9: When the Network Settings screen appears, select PPPoE Settings and press A.
Step 10: Under Configuration, select Off and press A on the controller to save the changes. Press B to return to the previous screen.
Step 11: Once the Network Settings appears, select Connect and press A to test the connection.
Apr 26, 2008 | D-Link DI 514 Wireless Router (DI-514)
NetGear Neo TV 550 Ultimate HD Media (AAC4001NTV550100NAS) Logo
55 people viewed this question
Top NetGear Televison & Video Experts
David Payne
David Payne
ray gallant
Dave
Dave
Level 1 Expert
Are you a NetGear Televison and Video Expert? Answer questions, earn points and help others
