Question about Garden
How do I get my Tecumesh Model H35-45430M lawn mower motor running. Have cleaned, soaked it in solvent that would take the hair off a mouse as well as trying with the choke full on which does not wet
Everything but take out the welch plugs and still won't go
  • 3,506 Answers
You can over soak it and if you soak it in any strong solvent that does not affect gasoline solvent you have wasted your time. You should never need to remove welch plugs. With more information someone might be able to better advise you. Pull the plug and with an oil can or the like squirt a small amount of fuel into the cylinder and then screw the plug back in and see if it will start and run.
Posted on Nov 24, 2014
jj505
  • 195 Answers
SOURCE: Have a Briggs & Stratton lawn mower engine, 4.5
Is Blade new or causeing vibration .Chge blade,
Please rate Thank you jj505
Posted on Mar 30, 2009
  • 59 Answers
SOURCE: lawn mower ony runs at idle and dies after seconds
try holding the throttle open
Posted on Jun 26, 2009
  • 154 Answers
SOURCE: my riding lawn mower starts up fine but stops running after 1 min
poss the float sticks and floods out,spray carb clean in it,
Posted on Aug 05, 2009
SOURCE: my lawn mower starts, but won't stay running.
After you check airflow (i.e. cleaning up the air filter), check fuel flow.
I'm assuming the gas is clean and fresh.
Is the gas flowing from the tank?
Is the gas getting into the carb?
If yes, then the next step is to remove the carb.
Check the diaphram between the carb and the tank, this acts as your fuel pump. Is this diaphram in good condition? If not replace it.
While the carb is removed, clean all the little ports (jets) into the carb with WD-40 or carb spray-on carb/choke cleaner (automotive section of your local auto store). Blow it dry with compressed air (canned or from a air compressor). Replace any gasket so the carb doesn't have seepage when reinstalled.
It may sound a bit daunting, but its an easy job and may stores carry the necessary parts. Try WalMart, or auto stores, if they don't then a good hardware store should. Or, a lawn mower shop should have it.
Good luck, I'm rebuilding doing the same thing to one of my mowers this week. Piece of cake.
Posted on Sep 26, 2009
rycgl
  • 1545 Answers
SOURCE: HI there, I got
There could well be a build up of sediment and debris in the main jet to the carburetor. It is easy to get to and clean. It is the brass bolt that holds the lower float bowl onto the main body of the carburetor. To clean it, drain your gas. Remove the bolt and external washer UNDER the carburetor bowl. Clean out the bowl of any sediment and/or water. To clean the brass bolt, use no metal objects. Carb/Choke aerosol spray cleaner will do the job. Pay close attention to the hole in the bottom of the bolt and the very small holes about 2/3 of the way up the bolt. Clean till shiny with holes cleared and reinstall. Your fuel flow problem and shut off condition may be solved.
Posted on Jun 05, 2011
When I give the engine No, all things come back negative but engine is a Tecumesh H35-45430M Ser., 7320B
If you go to a small equipment dealer & give them
the info, you will have your answer & be at the bagel
shop, in a matter of 10 minutes
Your approach is wrong
Go where the info is
There will be a replacement or used carb
if you go to a lawn mower shop, etc
Why not just clean yours & look for a repair kit?
Try Norfolk Power Equipment site
I was on that & others last week, for a 21 year old
RedMax Blower I have
Nov 25, 2014 | Garden
After been in storage for two years I've tried using my Poulan, I clean the floater area making sure not old fuel is there, but still is not running unless I put gas directly into the carb and it does it...
The carbs on small engines have numerous jets which clog very easily. If you are able, remove the carb and soak it in a carburetor cleaning solvent......make sure to remove the gaskets or purchase a gasket kit before you soak. Remove the carb from the cleaner and let it dry. Reinstall.
You may want to check the fuel lines and primer bulb while you are at it. Good luck and I hope this helps.
May 16, 2014 | Poulan Pro 22inch 625 Series Briggs ...
My mtd lawn mower runs on even act like it don't power up
Sometimes this problem is governor related..but most times there is a problem with the carburetor. The idle circuit in the carb may be partially clogged or the linkage on the carb is worn and weak. A carburetor/spray choke cleaner could help if you spray it directly into the engine while it is running and even right before starting it up. Best way to clean the ENTIRE carb though is to remove it from the mower...take the lower float bowl off and soak it in some type of solvent/cleaner with the rubber tipped gas inlet needle removed and the float also if it is plastic. For a thorough cleaning, these parts need to be removed anyway....No rubber or plastic carb parts should be soaked with the carbs main body Pahy close attention to the brass bolt that holds the bowl on as it is the main jet and has very small holes in its middle and bottom that must be clear.
Jul 10, 2010 | Mtd 22" Yard Machine Push Mower
Can't seem to get my mower to keep running
the problem is probably the carb---take it apart and soak the parts in some solvent. make sure the float valve moves very freely.
May 06, 2010 | Craftsman Push Rear Bag Lawn Mower w High...
Lawm mower engine will only run on choke
the carb is gummed up with laquer. take it of the motor and soak it in some solvent for an hour. but first take off the float cover before emersion.
Nov 12, 2009 | Briggs & Stratton Briggs Stratton Intek V...
I have a Yard Machine Lawn Motor with a 4.5hp Briggs and Straton engine.It starts really good but runs really rough.Can you give me some advice on how to fix this problem ?
Pull apart and clean the carb. You can dismantle and soak the carb in solvent or equivelant for a couple hours. A dirty carb and poor spark are the major reasons that the motor won't run well.
Sep 21, 2009 | Mtd 22" Yard Machine Push Mower
Briggs and stratton engine surges and slows, repeatedly
There is still either water or debree contaminating the fuel system. Surging is usually debree, empty and flush the tank with gas or Iso alcohol, disassemble carb soak in solvent for 30 minutes blow out the carb passages, reassemble and if the problem persists run engine at top rpm with air cleaner off and block off carb intake with hand, this will stall the motor restart and repeat 4 - 5 times this wiil draw out any debree or other blockage in the carb.
Jul 25, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Craftsman garden tractor engine stalls after running for about 20 minutes or climbing a grade
it maybe over heating check fins on sides of motor and clean if needs, another cuase is dirt fuel filter, open gas tank and look to see if there are things or dark spots on bottom of tank, is yes drain clean and flush fuel lines with wd40 change fuel filter if equiped, sediment will settle and inclines or running will move sediment and block fuel flow. when stopped they settle and will run again for time
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn mower
check out murray & tecumesh website
May 01, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
