Question about Car Audio & Video
I have a 1000 watt MA Audio amplifier, the protection light is a throbbing green, going from bright to dim, I have checked both the power and ground wire, they are both connected correctly, I have tried new clips and can't think of anything else. Could it be an issue with the amp or is it probably something else?
  • 3,506 Answers
Yes it is likely an issue with the amp if you have installed it correctly.
Posted on Nov 24, 2014
5 Suggested Answers
  • 883 Answers
SOURCE: Problems with Infinity Amp 611A
are you running a large ground wire directly to the battery negative terminal?
Posted on Jun 03, 2007
hawkwatcher
  • 67 Answers
SOURCE: Rockford Amp - When grounded, both power and thermal lights go off
Well This is a interesting problem. In this amp chassis ground and Power supply ground should be the same. With no power applied measure resistance between amp's chassis and Ground terminal of amp. Should be Continuity (low resistance 1-2 ohms or less ) if not you have a burnt ground trace in the amp most likely because amp had poor ground to Ground terminal and was Drawing its current thru chassis or thru Rca Ground which I have seen happed on this amp in the past. F.Y.I I have repaired lots and lots of Rockford amps usually shorted mehsa bar (output / power supply rails) or burnt traces otherwise pretty tough amps. Questions kstahl65@att.net
Posted on Jan 11, 2008
SOURCE: power protector light on sony xplode 1000 watt amp
a green light is the power indicator, a red light is when the protector is in affect
Posted on Jun 01, 2008
  • 631 Answers
SOURCE: Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Posted on Nov 02, 2008
I have a Lanzar 4000 watt amplifier hooked up to 2 12inch MA Audio subs. When I crank my car the green power light on the amplifier comes on, but after a second or two it changes to protection mode. I have...
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Time to get an old school Opti Drive. .A thumbs up would be greatly appreciated if this answer is helpful to you. lanzar-4000-watt-amplifier-hooked-up-2-shonxoarcym4awy4zl1imx4o-2-0.jpg Lanzar
Jan 29, 2011 | Lanzar VIBE286 Car Audio Amplifier
Amp burned out but fuses still good?
this is caused by inproper wiring from the speakers/subs to the amplifier.. an amp will still put out power to subs and speakers when it's wired improperly but it won't last for very long doing it... 6 months is longer than usual....
Dec 05, 2009 | MA Audio M1900XE Car Amp
Protection Light Comes on
your amp isnt getting enough power to it you may need to install a compacitor unit
Mar 23, 2009 | Sony NTX-2136 DHD 2Channel Car Amplifier...
Coustic 601se power on but bad sound
This is generally caused when there are blown output transistors but that generally causes the fuse to blow or causes the amp to go into protect mode.
If you connect a 15 amp fuse in series with the main power wire and it blows when remote voltage is applied, the amp is drawing excessive current. The problem could be either in the power supply or audio circuits.
Do NOT apply power without having the transistors clamped TIGHTLY to the heatsink. They can fail in seconds when there is a problem. The heatsink helps protect them.
The following page may be helpful when troubleshooting.
Amplifier Repair Primer
Aug 23, 2008 | Coustic Car Audio 601SE Car Audio...
Power protector light on sony xplode 1000 watt amp
May 30, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Red light
something is shorted in the circuit, or your subs. unhook the subs first and try it again, if it is still in protect then it is most likely the output transistors.
Feb 22, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
California 3600 mosfet discrete 3 ch amplifier 600 watts does not work
It sounds like it's going into protect. To be sure it's not the wiring, disconnect all speaker wires from it. If the light still goes out, check the DC voltage on the B+ and remote terminals. Place the black meter lead on the ground terminal of the amplifier. If the voltage remains above 11 volts as the amp tries to power up, the output transistors are almost certainly shorted causing the amp to go into protect.
Nov 25, 2007 | Profile 600MSX Car Audio Amplifier
Car Audio & Video Logo
52 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
