Question about Garden
Please help!!! my model H35-45430M Tecumesh motor will start and run for a few seconds then stops. I have cleaned, soaked in solvent but it still will not suck up petrol not even to wet the plug why.
I have had the carb as far as I can get cleaned over and over but can not get the welch plugs out that are there but no go. Spray in some ether and it will run a few seconds then stop. I can not even get the spark plug with the choke fully closed so what is happening. Trevor NZ.
  • 3,506 Answers
The spark plug should never get wet. Ether is dangerous and you would be better to squirt a little gas in the spark plug hole.
Posted on Nov 24, 2014
  • 211 Answers
SOURCE: My lawn mower doesn't start
Hi Every 2 stoke engine needs three things to run:Fuel+oil/air mixture in correct proportions,compression and ignition.Remove the sparkplug and see if the spark appears when the piston in the cilinder is at top death point(almoust),if not check the flyweel key(not to be sheared).Check engine"s sealing(crankcase gasket,cilinder gasket,seals-crankshaft,carb gasket).Also the mufller(not to be clogged),disassembly the carb (check and clean it),fuel lines and fuel filter (check and clean them),gas cap tank vent(not to be clogged),the air filter.Please let me know. best regards savumihai71
Posted on Dec 22, 2008
cadman000
  • 607 Answers
SOURCE: Honda Izy will not start.
try fresh fuel
Posted on Apr 05, 2009
  • 246 Answers
SOURCE: yard man gas push mower starts but wont stay running
Hello jusapup68:
>>Did you Soak the Carburetor when you Cleaned it?
>>If No, then the Carburetor can Still be the Problem.
>>Does the Engine Start and Quit if you Pour a Small Amount (1/4 oz of Gas into the Carburetor and Try to Start the Engine?
>>If Yes, then Soak the Carburetor Overnight.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve.
Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace is the Needle Valve.
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
You can View a Breakdown/IPL of the Mower at this Site Addy, http://www.smallenginepartswarehouse.com/parts.asp and Select Shop Online Parts and Accessories. Now Select the Model Tab. Select the OEM (MTD) and Enter the Model Numbers. Now Double Click on the Model in the Results Area.
>>Have you Checked the Spark at the Plug?
>>Here is a Basic Instruction File I am in the Process of Making. It will Might Say Mower, but a Snow Thrower/Blower is Powered by the Same Type of Engine, so the Diagnostics are Basically the Same. >>***Here are some Diagnostic Instructions to Do on the Engine to Locate the Cause/Cure for a Hard/Not Starting Engine. This Does Not Include a Problem with the Valves. If I Suspected the Valves are Involved, then a Separate File for the Valves will be in this E-mail. This is a File in the Making, so Any Input is Appreciated.
>>1- Check the Spark. If Not Firing, then Replace the Plug.
>>2- If the Plug is Firing, then First, Pour a Small Amount of Gas (1oz) Into the Carburetor Throat with the Throttle at Full. With the Throttle Still at Full, Try to Start the Engine. If the Engine Starts and Quits, then Make Sure the Gas is Free Flowing to the Carburetor. If the Gas is Free Flowing, then Remove, Disassemble and Soak the Carburetor Overnight in Carburetor Cleaner (I Use Gunk). I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning. You Only have to Remove the Bowl, Float Pin, Float and Needle Valve and Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed. Then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts. Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air. Install New Parts if Required.
>>3- If No Fire at the Plug, then Remove the Coil Shut Off Wire from the Kill Switch at the Engine Stop/Brake Bracket (where the End of the Stop/Brake Cable Attaches at the Engine). Check for Fire. If No Fire, then Remove the Blower Housing and Remove the Ground Wire from the Coil. Check for Fire. If Still No Fire, then the Coil is Bad. *On Some JD Model Mower the Engines Use an Igniter. Remove the Igniter and Coil and have your Local JD Dealer Test them for you.
>>* **On Models with Point Set, the Condenser is Bad and the Point Set and Condenser should be Replaced as a Unit. Make Sure the Point Set Plunger is Fully Extended when Setting the Point Set Gap to .020in.
>>** If there was No Response from the Engine When the Gas was Poured Into the Carburetor Throat and the Plug was Firing, then Check the Compression. If the Compression is Good, the Carburetor has Been Soaked and Cleaned and the Plug is Firing, then Check the Flywheel Key. If the Key is Damaged, then the Plug Firing is Incorrect to the Position of the Piston During the Compression (Power Stroke).
>>*** On the OHV and Some L-Head (Flat Head) Engines there is a Compression Release. The Exhaust Valve Clearance has to be Opened to .020in for the Compression Release Not to Operate; in Order to get a Correct Compression Reading.***
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
redbeard00
  • 957 Answers
SOURCE: my cub cadet tank stops running 5-20 minuts after
Yes you may need a carb kit. It is not good practice to by-pass the fuel filter. The orifice in the jet is very small.
But anyways, There Could still be a blockage inside the carb, a small leak at the manifold, or the jet is worn out.
Let me know how it goes.
Posted on Apr 28, 2010
  • 173 Answers
SOURCE: four stoke mower. Mower starts and runs ok but
Your ignition coil is failing when it gets hot.make sure the cooling fins on the flywheel are not plugged up.you will probably have to replace the coil.
Posted on Dec 28, 2010
Starts up, and then motor stops with in seconds.
Near the flywheel is a sensor. That sensor is a speed sensor. Make sure it is within 1/8" of the flywheel, If that does not work then the sensor need to be replace. For more help please post the model and model number of the treadmill and I will help you out.
Jan 04, 2015 | Exercise & Fitness
Tip
The melting point of most cartridges is less than 100 degrees centigrade, we...
Is your cartridge clogged,,,
Then in the maintenance settings in PRINTERS AND FAXES,, do a deep ink cleaning,,
If that fails then blot the cartridge on a piece of tissue damped with alcohol.. or let the cartridge sit in some rubbing alcohol for a cpl or minutes and then blot it..
As a last resort if the above fails,,, WARNING NOT A CONVENTIONAL METHOD
try boiling the cartridge for a few minutes,, MAKE SURE THE WATER IS BOILING BEFORE U PUT THE CARTRIDGE in.. so to to remove most of the air from the water to prevent corrosion
on Dec 23, 2008 | Canon PIXMA MP150 All-In-One InkJet...
How do I get my Tecumesh Model H35-45430M lawn mower motor running. Have cleaned, soaked it in solvent that would take the hair off a mouse as well as trying with the choke full on which does not wet
You can over soak it and if you soak it in any strong solvent that does not affect gasoline solvent you have wasted your time. You should never need to remove welch plugs. With more information someone might be able to better advise you. Pull the plug and with an oil can or the like squirt a small amount of fuel into the cylinder and then screw the plug back in and see if it will start and run.
Nov 24, 2014 | Garden
BRIGGS ENGINE STOPS AFTER A FEW MINUTES OF RUN TIME
Sounds like blocked air or fuel filters. Check and clean air filter, soak it in petrol or other solvent to remove accumulated oil and dirt mixed grit. Check the main fuel line filter and more specifically check the carburetor internal fuel filter for possible blockage.
Jun 08, 2014 | Garden
Sprayer valve is clogged
I've had some success by removeing the entire trigger mechanism and soaking it in solvent for a few hours.
Mar 23, 2010 | Rl Flomaster Acid-Resistant Sprayer...
Hey, I have a Whirlpool Hotpoint electric dryer that is broken. The drum will not spin. I can hear the motor engage like its trying to spin. It will do this about three times (start/stop cycle) then...
remove belt from motor so there is no drag on motor or pulley,then spin motor shaft and pulley by hand,it should spin freely and coast to a stop,if it is hard to spin,the bearings are dried out and normally its new motor time,you can try removing motor and soaking bearings in a solvent and re-oiling,but that usually doesn't do it
Jan 16, 2010 | Washing Machines
I have a Yard Machine Lawn Motor with a 4.5hp Briggs and Straton engine.It starts really good but runs really rough.Can you give me some advice on how to fix this problem ?
Pull apart and clean the carb. You can dismantle and soak the carb in solvent or equivelant for a couple hours. A dirty carb and poor spark are the major reasons that the motor won't run well.
Sep 21, 2009 | Mtd 22" Yard Machine Push Mower
My 6 HP Craftsman tiller will not run without starting fluid
Carberator is gummed up and will need to be removed and dismantled and soaked in solvent for an hour or two.
Aug 16, 2009 | Craftsman 8.50 Torque Rating Dual...
Craftsman garden tractor engine stalls after running for about 20 minutes or climbing a grade
it maybe over heating check fins on sides of motor and clean if needs, another cuase is dirt fuel filter, open gas tank and look to see if there are things or dark spots on bottom of tank, is yes drain clean and flush fuel lines with wd40 change fuel filter if equiped, sediment will settle and inclines or running will move sediment and block fuel flow. when stopped they settle and will run again for time
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Pony only runs with chocke 98% closed
Most likely the carburetor jet is still clogged after sitting for years with fuel in it. Putting injector/carb cleaner in the fuel tank may help, but if not, the jet needs to be soaked some more -- or replaced.
Follow mixing proportions on the label for injector cleaner.
May 27, 2009 | Troy-Bilt Pony Garden Tiller
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
