Question about Hardware & Accessories
How do I change/replace battery in a Casio worldtime countdown timer AQ-160 (3319)
Removed back and can't figure release for battery.
  • Ron Spoerl
    Ron Spoerl Nov 24, 2014
    Plus, what exactly needs to be done about with the AC to (-).
SOURCE: Casio SPF 40 beeper not working after battery change
There is this little spring which fits in one of the small holes in the watch. When I tested my watch without the spring, there was no beep. With the spring in place the sound worked nice again. So (IMO) apparently the little spring is used as contact between the watch en the "speaker" placed at the back of the watch.
regards,
Pieter
Posted on Dec 21, 2008
SOURCE: I am trying to change
I have a similar model.  The electronics sometimes needs to be reset after the battery is changes.  Get a magnifying glass and look closely at the stainless frame around the battery.  There is a small AC mark and a triangle which points toward a small gold contact down in an adjacent hole.  This contact must be shorted momentarily to the + side of the battery to reset the display.  You can bend a metal paper clip to make the connection.  You may have to try several times before it resets. It should reset to 12:00 and start running.
Posted on May 20, 2009
escapement
  • 2334 Answers
SOURCE: I have a Casio AQ-47 watch. I removed the battery
This little spring is called coil spring and must be inserted in to the hole in movement. Usually there should be writing on movement with an arrow pointing to that hole. If you can not find the writing, then try to put coil spring in different holes one after another, till you hear the watch beeping again.
Rate me, plz.
Posted on Jan 11, 2010
  • 2501 Answers
SOURCE: Casio watch no longer beeps.
Try getting instructions from Casio.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Click on "search" and the download your instructions.
If you can't find anything useful, try their technical support.
Posted on Mar 13, 2010
SOURCE: Casio module 2273 battery change
did u ever figure out how to get the retaining clip?
Casio AQ-164W battery replacement
  • Remove back
  • Find battery and note how it is installed
  • Identify type
  • Obtain replacement
  • Install battery
  • Check operation
  • Reinstall back
  • Set time, etc.
OR,
Pay a jeweler a few bucks to replace it
OR
Oct 25, 2016 | Casio Watches
Change day of the week in casio worldtime watch 3198.
On most digital watches, if you properly set the date and year, the day of the week is preset.
Jan 03, 2013 | Casio G-Shock GW300CA-1V Wrist Watch
How do I reset the intermatic EI400 light timer
Copy following link to identify Ei400 series programmable countdown timer and download possible manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#Ei200
Hold down ON/OFF button and fully press-and-release small round reset button using paper clip.
Keep holding ON/OFF button until display changes
This timer uses CR2 battery installed in tray below the buttons.
Reset timer after installing new battery.
If functionality is not restored after new battery install and reset, then timer has gone bad.
This timer has 1 year limited warranty through Intermatic for defects in workmanship.
Ei400 can be wired for single-pole or 3-way.
Timer requires no neutral wire since battery operates the timer and relay circuit
Nov 13, 2012 | Day-Timer Intermatic Ei600c Digital 7 Day...
How i can change analog time
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
watches;
Accept terms
Oct 31, 2010 | Casio Fishing Timer Strap Watch, AMW702B...
How do i change the analogue time for my Casio Aq-180W-1Bvef Mens
If you haven't got instructions on how to do this, you can get instructions from the Casio web site.
watches;
Accept terms
Apr 11, 2010 | Watches
Accept terms
Mar 10, 2010 | Casio DB360G-9A 30 Pages Telememo Watch
Rate me, plz.
Jan 11, 2010 | Casio Classic AQ47-1E Wrist Watch
Cascio Twincept alarm and hourly signal issue
Follow this link:
http://world.casio.com/wat/download/en/manual/
Rate me, please.
Mar 27, 2009 | Casio Twincept Databank ABX238BV Wrist...
regards,
Pieter
Oct 04, 2008 | Casio PRG-40T-7 Pathfinder
Hardware & Accessories Logo
46 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
