Question about HP Color LaserJet 2840 All-in-One - Multifunction fax / copier / printer / scanner - color - laser - copying up to: 19 ppm mono / 4 ppm color - printing up to: 19 ppm mono / 4 ppm color - 375 sheets - 33.6 Kbps - Speed USB, 10/100 Base-
<!-- from fixya rte -->How we clean the double image of our print? - HP Color LaserJet 2840 All-in-One - Multifunction fax / copier / printer / scanner - color - laser - copying up to: 19 ppm mono / 4 ppm color - printing up to: 19 ppm mono / 4 ppm color - 375 sheets - 33.6 Kbps - Speed USB, 10/100 Base-
  • 41 Answers
Need to do a reinstall. Most important is that a page is printed that needs to be scanned into printer as part of setup. Should fixd problem.
Posted on Nov 24, 2014
How do I fix my Canon IR c5185 printing double image
Check the fusing unit if the heat roller engaged? The unfixed image at the roller causing Double image too in Canon IRc5185.
Nov 27, 2014 | Canon irc5185i
Sharp mx-2310u printing double vesion of an image, the copy and the lighter to the right. how can i fix this?
Double print usually happens when Drum completed its life and Cleaning Blade unable to clean the drum surface properly, Replacing of Drum and Cleaning blade will gave you good copy quality, Don't forget to clean Charger unit
Aug 27, 2014 | Sharp MX-2310U Color Printer : 2310U
My epson px660 is photocopying and printing double images
Try to print with disabling high speed option. Check the linear encoder. Clean it if dirty.
Jan 20, 2013 | Epson Stylus Photo Px660
Quilt y of print !, it gives double printing on page one is print of original doc.& second as its image what should i do to improve its print quilt y. i will be thank full to you
Dots, Lines, shadows and smudges on the printouts are due to dirty/ deteriorating cartridge and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines.
Also, make sure that the visible inside of the printer is clean and ther is no spilled toner inside, which sometimes results in dots. Double printing is also due to the deteriorating cartridge. The drum is not getting clean after its each rotation and hence the remaining toner/ image is transferred to the paper resulting in double printing. So, it is recommended that clean the drum etc (this would help temporarily). Also, make sure that the toner cartridge is in good working condition. If not you may replace the cartridge.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Jan 14, 2011 | Canon Image Runner 1630 Copier Copier
My printer is printing double images and leaving dark ink marks on the paper
double printing or ghost images are usually cause by a fuser that is operating below normal temperature. the temperature is regulated by the thermistor replace it or replace the fuser
Nov 26, 2009 | HP LaserJet 1020 Printer
My printer is printing double lines
Select an image to print.Click 'Printing Preferences'. Click the end tab 'Services'. Click 'Service this device'. Then you can click to align the cartridges and clean them too.The device will do it for you and you can check at each stage as a test sheet will be printed :0)
Oct 11, 2008 | Office Equipment & Supplies
Double printing in my samsung 3160 fn
Double printing, such as second "ghost" image has nothing to do with cleaning, but with the drum unit. Print out the System Data Report (Press [MENU] until "System Configuration", then right arrow until "Reports", press [ENTER] and then right arrow until "System Data". Press [ENTER] twice to confirm.
With the report on hand, check the total color prints. If they are near 12,000 pages, change the drum. Be advised, the Image Unit (drum) is an expensive consumable. Part number is CLP-300A.
Be blessed.
Oct 01, 2008 | Samsung CLX 3160fn All-In-One Printer
Double ptinting
try to clean the upper roller on heating section the final stage of the machines if the image is seen to be of the first objected copy this solution is only if you observed that the image of the previus object (source paper) is printed on the next copy or it repeats printing the lines.
and if it so replace or fix the new oil roler in heater unit.good luck vote me pls
Aug 27, 2008 | Canon NP 7130 Black and White Copier
Brother DCP-110C multi-function, printed image has shadow/double image. scanner seems to work ok. not really use copier. i need to correct printer to print regular text/image. thank you.
Press Ink.
Press up or down arrow buttons to select Cleaning.
Press Set.
Press up or down arrow buttons to select Black, Color or All.
Press Set.
The DCP will clean the print head. When cleaning is finished,
the DCP will go back to standby mode automatically.
If you clean the print head at least five times and the print has
not improved, call Brother Customer Service
Aug 21, 2008 | Office Equipment & Supplies
HP 1220c double image
plz do a nozzel chek and head cleaning (go to control pannel > printer and faxes > right click on your printer >click on properties>click on maintenance and performed the above test)
May 17, 2008 | HP DeskJet 1220c InkJet Printer
HP Color LaserJet 2840 All-in-One - Multifunction fax / copier / printer / scanner - color - laser - copying up to: 19 ppm mono / 4 ppm color - printing up to: 19 ppm mono / 4 ppm color - 375 sheets - 33.6 Kbps - Speed USB, 10/100 Base- Logo
60 people viewed this question
Seeker5211
Seeker5211
