Question about Irulu 10.1"tft Wifi 3g Android 2.2 Tablet Pc Touchscreen 0.3mp Camera 2gb 512mb Ddr2
Where do I locate a replacement ac/dc adapter for the irulu 10" tablet, model AL106?
Adapter is broken. Please help.
    Scholar:
    New Friend:
  • 69 Answers
Try Ebay
Posted on Nov 27, 2014
SOURCE: loose ac power port
A very common laptop problem, but not always easy to rectify. Usually, the smallish receiver portion is fastened onto the mobo which means a total or near-total disassembly of the laptop. The part is rather inexpensive, but the labor to change it is not.
Posted on Apr 03, 2008
  • 256 Answers
SOURCE: HP 2710P will not power on!
Try power draining your computer first. remove battery and ac adapter, then press and hold power button for 15-20 sec. Expect no response since there is no power source. After that, try if pc will now turn on. If it still wont, possibly it will be needing a motherboard replacement.
Posted on Apr 26, 2010
alicantecoli
  • 22326 Answers
SOURCE: i have to buy an ac power adapter for the arnova 10, but i do not have the voltage
look on the back and it should tell you ,if not got for 6 volts as this is what most of them are ,you will not blow anything up with this voltage but a 12v charger might just do that ands destroy it
Posted on Dec 25, 2011
  • 12 Answers
SOURCE: Hi when plug in my ac adapter into lenovo x61 the
the problem should come from DC Power Jack of Lenovo ThinkPad X60 X61, I advise you to order the dc jack with cable for your Lenovo X61, simple plug in and works, see this page: http://www.lapdiy.com/ibm-lenovo-thinkpad-x60-x61-wire-harness-power-jack-dc-in-cable-p-28297.html
Posted on May 02, 2012
TechyDrood
  • 2072 Answers
SOURCE: how do i use my 3g network on my irulu 10.1 tablet
  • Go to your mobile provider, I.E. Verizon, att, sprint and make sure you are paying for the 3G access.
  • I believe they also provide you with a sim card, this identifies your tablet to your paid account
  • Then go into settings and mobile networks and enable 3G
Posted on Dec 08, 2012
The charge dock on tablet broke so we can not charge tablet can it be fixed? We just got it this October.
Juello. Did some research on your tablet at Amazon, (http://amzn.to/1xWx6S5) and see that they also have an AC charger (AC charger adapter with a 3.5mm power jack and delivering 5VDC 2A). Available for $5: iRulu Black AC Home Wall Adapter Cable Charger for Tablet PC 5V 2000mAh or a there's a nice replacement KB and cover: iRulu New Portable 10 1 10 5 Android Tablet USB Keyboard Case Black . I would guess the connector snapped off inside the tablet, so you will have to remove it with some tweezers. If the pin for the AC adapter broke off inside the tablet, that's a problem, but most everything can be charged from the USB port too see this website:
How To Charge Samsung Galaxy Tab 2 Via USB Port On Computer Laptop PCNEXUS (Samsung used as an example). GL
Jan 08, 2015 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
I have an irulu 7" tablet that I got for Christmas. So far the tablet is working, however the keyboard case does not work when plugged into the USB port at the top of the tablet. It is my understanding...
Not sure on you particular model but most tablets have 2 mini USB ports one has a power supply and the other is just an I.O port .
Try your keyboard in the other port if you have one and it should work. If not it may be faulty.
HTH
Jan 01, 2015 | Irulu 7" 4gb Mid Google Android 2.3...
My irulu v1 won't connect to my mobile data how do I connect it
If your Irulu model has 3G capability, you need to buy a 3G USB adapter/dongle and then connect to your tablet using the USB or OTG cable that came with the tablet. If your model is not 3G-enabled, you can get on the Internet only via WiFi.
Dec 17, 2014 | Tablets & eReaders
Setting on charger for a Polaroid tablet, 6V, 12V, Help
Not sure of the model number of your polaroid tablet you have. Generally the adapter should be an AC adapter for 220V or 110V depending on country. It is unlikely you will have to select 6v or 12v. If you are unsure charge the tablet through the USB cable connected to a computer. It might take a bit longer to charge and make sure the computer is connected to mains charger to avoid drain on computer (laptop, etc) battery.
If you have a 7" tablet then I am assuming it is a PMID705. See manual on this link.
http://www.southerntelecom.com/upload/polaroid/pmid705/PMID705_User_Manual_20121210.pdf
The manual says it is a 5v DC output connector for the adapter. Not sure why you are asking the question. If in doubt send email to polaroid support on the address at end of the attached manual.
Sep 19, 2014 | Polaroid 7-in. Internet Tablet - Other
Tablet wont charge
The DC - In Jack where you connect the AC Adapter to charge is either cracked, broken or loosened in the inside of the tablet. Investigate further on the company's website: enter the make of your tablet, model and serial number. It will show you the part and how much it will cost. It gives you an idea on what to expect to pay.
Parts cost less then the labor.
Jan 17, 2014 | Tablets & eReaders
Ac adapter broke
Buy a RIM Blackberry Rapid Charger. It uses another connection:the one with the three magnetic contacts.
It was about $10 on amazon today. And it charges fast.
Feb 24, 2013 | RIM Blackberry Ac Adapter 5 V Dc 1.80 A...
The power light is off The charger is OK with 19Volt The connector is OK and somehow there is a problem with in the power
remove the battery, connect the ac adapter and turn on the laptop. If it turns on then it's your battery. If it doesn't turn on then it is either your ac adapter, your dc jack, or your system board.
If it doesn't turn on then try a different ac adapter from your local pc shop or electronics store. If it still doesn't work then try moving the ac adapter connector and see if it attempts to turn on. If it does then it's your dc jack. If it is your dc jack then you will have to replace it. The problem with that is that it can be pretty expensive to replace it.
The way I have solved this is by ordering a dc jack on ebay or any other online parts supplier and replacing it myself. If you can take your computer apart and put it back together then it's just a matter of desoldering and soldering the new one. If you want you can have a pc or tv shop do the soldering for you.
Have fun and let me know if you have anymore questions.
Dec 14, 2010 | IBM ThinkPad X60 Tablet PC
Irulu 10.1"tft Wifi 3g Android 2.2 Tablet Pc Touchscreen 0.3mp Camera 2gb 512mb Ddr2 Logo
102 people viewed this question
Top Irulu Tablets & eReaders Experts
john smith
gbob59
David Harrelson
David Harrelson
Are you an Irulu Tablet and eReader Expert? Answer questions, earn points and help others
