Question about Panasonic Televison & Video
I have a Panasonic TH-42PX25 that was running fine. Turned it off the other night, next day I powered on but no picture. It seems like there is a very faint glow to the screen, but no picture. Just a
I have a Panasonic TH-42PX25 that was running fine. Turned it off the other night, next day I powered on but no picture. It seems like there is a very faint glow to the screen, but no picture. Just a solid red light on the front. I left it unplugged for a couple of days, but still the same. Any ideas?
    Top Expert:
  • Panasonic Master
  • 75,304 Answers
Sounds like main power supply regulator board is faulty. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Nov 24, 2014
dduncan774
  • 760 Answers
SOURCE: LG 32LH30 screen won't power up. Red light at bottom glows hi to low, but no picture. Unplugged and waited overnight, plugged in again, still no picture.
There is a way to tell if you have a bad board, or a bad panel.
1. Make the room dark and turn on the TV. Can you see it light up? If so, does it stay lit or turn right back off?
2. If the panel lights, but you have no picture, I would suspect the T-con. Some units now have the T-con incorporated with the main board, so you will need to check.
3. If you never get any light at all, then I would suspect the power supply.
4. If you only get light for a second or two, then you have a bad panel.
Posted on Apr 10, 2012
  • 4 Answers
SOURCE: samsung lcd tv ltm1755b won't turn on (power light stays red)
Problem: Samsung LTM1755B with only a blinking yellow LED when you try to turn it on.
Solution: I just had one of these come in. I opened it up, and found the U501 capacitor a little suspicious looking, in that it had a deformed top. It was a 470uF 16V electrolytic 105degC 10mm x 12mm. I replaced it with a very good quality 1000uF 16V electrolytic 105degC 10mm x 16mm Nichicon UHN1C102MPD. After that repair, when I tried to turn it on, the LED was yellow for a second, then green, then I got a picture, and it appeared to work great. I then asked the owner a week later how it was working, and they said it was working just like new!
Posted on Jan 19, 2010
vinnyq
  • 157 Answers
SOURCE: TV worked fine one night, next day screen is white.
The LCD Panel failed. There is no easy fix but try to get the T-Con board to fix the issue. However, this part is usually only available with the whole LCD Panel. This is usually the most expensive part in the TV and the whole TV needs to be taken apart to replace the panel.
Might be economically viable if you can find a place that carrys the T-con but Dynex parts are usually hard to find. The LCD Panel part alone will exceed the cost of the TV.
Posted on Oct 07, 2009
  • 4 Answers
SOURCE: power light blinks red - tv will not come on
I bought one of these tv's at a thrift store and it had the same problem, orange light blinking and static sound coming out of the speakers, no video at all.
The problem was the power supply board, this power supply has multiple outputs that feed the circuitry, 12V, 24v, 5V.
There was nine electrolitic capacitors I had to replace to fix it, all of them were bulged they are easy to spot, I measure one of them that was supposed to measure 1000uF but measured only 65uF. you can buy these from digikey for about 50 cents each, they need to be rated at 105 deg c and the profile has to be below the heat sink otherwise they will hit the top of the heat sink, the spacing between the leads has to be 5mm so they fit in the pcb. I replaced 3 1000uF/25v, 3 470uF/16v and 3 1000uF/16v and that fixed the problem, I bought this tv broken for 100 bucks fixed it with 6 bucks.
Good luck, don't perform repair if you are not familiar with dangerous AC voltage inside the TV.
Posted on Jul 24, 2008
  • 2336 Answers
SOURCE: No picture, no sound, does light the insignia sign. Why?
In about 90% of the time the power supply is defective if the TV fails to power ON.
I repair these power supplies, if you need further assistance write to jah2mil@homtail.com
Posted on Jun 29, 2009
I need some feed back on questions I posted a a couple of days ago, about Panasonic TH-42PX25, not turning on.
This could be a problem with the power board. Please have a qualified technician check or if non is available just change the power board all together. Please if you get stuck let me know.
Nov 17, 2016 | Panasonic Televison & Video
Red hues all over the images on screen
The TV is a plasma screen. There are several circuit boards that will go bad over time that affects the picture quality. TV Parts Universal TV Stands DLP Chips ShopJimmy You can get the parts here and replace those boards yourself.
Apr 10, 2017 | Panasonic TH-42PZ700U 42 in. Plasma...
Th-42px25 red picture, no blue or green
If using component cables check connections at TV or from source. If all rae ok the try source on another tv before getting video input circuit board replaced on tv
Dec 14, 2009 | Panasonic TH-42PX25U/P 42 in. Plasma HDTV
TH-42PX25 TV won't turn on
most cases the power supply board goes. plasma displays run hot, so that causes the supply to go
Nov 09, 2008 | Televison & Video
Picture and Sound flash from 'on' to a black screen
Hi, The problem lies within the unit. You have a hardware failure within the board. The power supply board needs to be repaired or replaced. If you are a handy person, you can easily swap the power supply board.. If not, bring it you to local reapir shop, they will find the parts and replace it for you. I wish I had a better solution like an easy fix for you. Sorry, but on hardware failure, there is no easy fix. Thanks, Mike
Nov 02, 2008 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Help with Panasonic plasma TV's display shift
you have an issue with the digital or main control board, and if the unit is still under warranty the manufacturer will help locate someone nearby. (actually even if out of warranty it's still a good idea to use that service co. for the simple fact they have more exeperience with the tv's
Mar 31, 2008 | Televison & Video
SONY KP51WS500 bought Feb. 2003 from Circut City
possible clod solder connection in the scan b+ voltages,contact sony and get them to check their dealer store locations in your area and have them send a message to the dealer describing your fault to them also.
Aug 06, 2007 | Toshiba 43H70 43" Rear Projection...
Televison & Video Logo
104 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
