Question about Toys
What sounds should it make? Ours only honks, no sirens
Nothing
Alarm went off and now car won't start.
You are most likely correct, it probably has an alarm. Unfortunately, most alarm systems are connected to the remote that is broken. You should have to have your dealership get you a new remote for the vehicle.
Mar 07, 2015 | Hyundai Motor 2004 Sonata
Siren sounds on the computer
how much beep?
a siren could be:
- overheat
- RAM dead
- CPU dead
- PSU dead
- motherboard dead
a siren and nothing else is a critical error
Nov 22, 2012 | ASUS P5LD2-VM Motherboard
Performance Teknique Icbm-7071 Everything on my alarm system is working, but now the only thing that will not work is the alarm sounding off. My receiver still beeps when my alarm goes off, but the car...
Sound like the siren. check the connections at the siren. If the connections are good and the system is sending a signal then, you may need to replace it.
Jul 27, 2012 | Car Audio & Video
2005 dodge dakota horn honks while arming vehicle with Viper alarm instralled
You need to look under the dash for the model number then contact viper support
Feb 17, 2012 | Vehicle Parts & Accessories
I have a Ge Simon Xt Alarm and i want to hook up a external siren(part 13-950)I received a 4.7 resister with the siren and 50 ft of wire.How do you attach the resister between the red and black wire?Do...
Wire nuts are ok if the siren is indoors. Gel filled connectors are better if you are mounting the siren outside because they keep the connection from corroding. The resistor needs to go between the two wires you are hooking up. The color of the wires you will are are generally red and black. If your siren has a yellow wire, you can use it instead of the red to get constant siren instead of the "whoop, whoop, whoop" sound that sirens usually make. Putting the resistor at the siren will make sure that it is supervised. That means that if someone cuts the wire going to the siren, it will alert you at the panel. If you put the resistor at the panel, nothing will happen if the wire is cut.
May 19, 2011 | GE Security Simon 3 Wireless Home Security...
Just baught a truck with a viper alarm, worked great then today i unlocked the truck with the viper remote and when i open the door the horn goes crazy for for about 1 min not the accual alarm! but at the...
Can be somewhat complicated to explain, particularly without knowing the make, model & year of the truck and which bypass was used to integrate into the factory systems. But here's one thing it might be. The Viper system is aftermarket obviously, when the alarm is triggered the siren with start to sound, and sometimes the horn will honk as well (depending on the vehicle and the bypass). If the siren isn't blaring that means the Viper system was disarmed when you unlocked the doors but not your factory security....or another way to word it is if only the horn is honking and no siren then you're factory alarm system isn't being controlled by the viper remote the way it should be. The factory disarm wire needs to be connected. It's a light green wire with a black stripe in a red connector in the Viper alarm brain. For anything more specific I'd need some more info on the vehicle. You can email me at jared@underground-audio.net if you'd like.
Nov 17, 2010 | 7752V Replacement Transmitter Supercode...
Had to change the battery in my Python Keyless Start/Remote and now it wont work. How do I reprogram it
To program remote:
turn ignition on
press and release programming switch once ( the siren/horn will honk once)
press and hold programming switch
while holding programming switch, press lock button on remote ( the unit will chirp/honk to confirm programming)
turn ignition off
test remote
Oct 07, 2010 | DEI Python 1400XP Remote Start/Keyless...
Alarm blaring when i try to start my 2005 dodge 1500
is it a factory alarm or aftermaket... horn honk or siren?
Feb 05, 2010 | 2005 Dodge Ram 1500
After charging my car, how do I turn off the alarm system?
there should be a valet switch under the dash, turn the ignition switch on then press the valet switch plug the siren with a shirt
Sep 21, 2009 | Vehicle Parts & Accessories
Can't start up computer
The siren sound is a alert sound that your processor is overheated. please check the processor heat sync and fan installed properly?
Apr 18, 2009 | Abit KN9 Motherboard
Toys Logo
704 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
