Question about Craftsman Garden
Craftsman ltx 1000 18hp tractor will no longer go forward but runs normal in reverse
  • Craftsman Master
  • 1,169 Answers
First replace the drive belt. (1/2 x 82-1/4) and the V-idler pulley if plastic, Reverse doesn't load the belt as much as forward drive. The reason I suggest replacing the V-idler too is that the plastic wears heavy and the drive belt bottoms out causing slippage.
Then if it doesn't drive forward then you most likely have a bad transmission.
Posted on Nov 24, 2014
  • 79 Answers
SOURCE: Craftsman DGS 6500 garden tractor won't engage
Hi
There is a pin in the back by the hitch - make sure it is pushed in. If it is pushed in then check to see if there are any oil leaks under it.
Posted on Apr 10, 2009
  • 6 Answers
SOURCE: Craftsman Transmission problem
Some of these tractors have a friction wheel that is driven off of a flat wheel on the bottom of the engine drive shaft. The rubber ring on this friction wheel could be worn out, or it could be out of adjustment.
Posted on Apr 22, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman LT 1000 won't go into reverse or forward
the hydrostat rearend or the belts to loose
Posted on Jun 07, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman LT1000 tractor not moving
hello otto i would check the belt that runs to the rearend but the brakes could be also froze up i would try to jack it up & see if it will move then go from there
Posted on Jun 08, 2009
SOURCE: Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
Posted on Nov 30, 2009
Stalls when I push the pedal in reverse, going forward no issues
Hi Dan:
Some of these tractors have a safety interlock on the ignition/start switch that prevents you going in reverse when the mower is engaged.
Check the switch to see if there is a position one click to the left.
If there is, give it a try.
Jun 17, 2015 | Cub Cadet LTX 1050 KW 50" 23HP Kawasaki...
My Craftsman lawn tractor with 19 horse B & S Twin with hydrostatic transmission loses speed and power in forward and reverse as it warms up. Within 20 minutes reverse will be gone and forward mo
more than likely your low on transmission fluid. I heard alot of this pertaining to hydrostatic transmissions on yards with inclines. I would check your fluid level .
May 14, 2014 | Craftsman Garden
Mower slips in and out of forward gear but rides perfect in reverse;What do I need to adjust?
Reverse is a different gear set than forward gears. Sounds like forward gear set has a broken tooth. Not an easy fix.
Jul 18, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 21 hp lawntractor model 917.289240 will no go in reverse.
If this is a hydro unit and it runs ok forward there should be no other reason other than linkage adjustment for it not to run in reverse, for safety reasons they are normally adjusted to run slower in reverse
Aug 09, 2012 | Craftsman Garden
Cub cadet 42" ltx 1040
http://www.ehow.com/how_6808091_change-cub-cadet_s-drive-belt.html
May 04, 2011 | Garden
Both forward and reverse speed are decreasing
Hi, check the main drive belt, the belt is stretched out. you need too replace the main drive belt.
If this doesn’t work for you, please write back. Thanks,
Nov 23, 2008 | Craftsman Garden
Garden Logo
125 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
