Question about Coffee Makers & Espresso Machines
Can the miele cva4070 be plumbed directly to a water source?
  • 2,509 Answers
No it can't.
Posted on Nov 24, 2014
5 Suggested Answers
  • 128 Answers
SOURCE: i have two types of
The large ones are your descaling tablets. they go in your water container when the machine tells you to put them in there. Your small tablets are brew unit cleaning tablets. they go in to the flap door under the ground coffee storage container in the top left of the machine. One cleaning tablet at a time when it tells to to start cleaning. Two descaling tablets at a time during descaling.
Posted on Nov 21, 2010
  • 128 Answers
SOURCE: I have a Miele CVA4070
there is a main power swich on the wall of the machine right over the ground coffee storage bin in the upper left corner of the machine. you have to open the stainless door, and look way up in the back left corner. tiny little rocker switch. try that, and then the touch panel should be on.
Posted on May 26, 2011
SOURCE: miele cva4070 coffee system
The above solution will not work when the machine is stuck on the cleaning cycle. You can plug and unplug it all you like but it will still come back and be stuck on "Cleaning" when you turn it on. I called Miele service and was guided through the steps to access program mode in order to cancel the mode. This is how you do it:
First turn it off using the switch inside the machine (top left with door open)
Note, the four following steps have to be completed within 10 seconds:1 Press the Clear button and hold2 Then press the On/Off button3 Release both buttons at the same time4 Press the clear button 5 times in a row
This gets you into Programming Mode (may take a second or two to pop up if you complete the above in less than 10 seconds
Keep pressing the "More" button (bottom right) until you get to the last page where it will give you the option of reseting the three cleaning modes. Just push the right one ("Cleaning" for e.g.)
That will do it but if you have an underlying fault that interferes with Cleaning then the same problem will happen again when the unit needs cleaning. You should get a service call to address this.
Posted on Dec 15, 2011
  • 38 Answers
SOURCE: why does my water container fill up even though my machine is plumbed in?
This looks like a fault. The plastic tank has two reed switches that measure 'tank empty' and 'tank half full'. When the tank is empty the inlet solenoids (there are 2 for safety) open and water enters the tank but not so much to fill the tank to the half way level. In normal operation the level water in the tank will drop and then more water is allowed in. In your case it appears the 'half full' reed switch is being activated because the solenoids are not closing off properly and water is leaking in and filling the tank. If you do not empty it then eventually it will fill and leak into the leak. The problem can be caused by either low water pressure (below 145 psi) or sticky solenoid. If is the solenoid then the Miele solution will be to replace both solenoids. Alternately you may be able to remove, take apart and clean. Also check that you have a mesh filter at connection to tap. Also you can temporarily fix the problem by turning off the water at the tap and re-programming machine to 'turn off' the plumed water line. regards
Posted on Sep 06, 2014
Can you buy an extra bean container?
You can purchase a new bean tray directly from miele. Its freakin 200 bucks.
May 17, 2014 | Miele CVA4070 Coffee Maker
Cva 4070 drip tray issue
Miele CVA 4066 -Empty drip tray warning would not go off even after draining the drip tray, cleaning contacts, and resetting power. Water was coming out from under the empty tray.
I pulled unit out and removed sheet metal in rear around water inlet. when I attached water line and power cord & turned on power, I could see water dripping out of one of the 2 solonoids on the water inlet valve. $168.00 from Miele and no expensive service call.
May 27, 2012 | Miele CVA4070 Coffee Maker
I have two types of descalling tablets in my package, 2 large and 10 small, where do I add them to my Miele coffee system CVA4070, and how many
Nov 20, 2010 | Miele CVA4070 Coffee Maker
Miele coffee machine shows"watersystem fault"
Hello Wiesiek1,
The water system fault means that there is too much water on the bottom drip pan and it has tripped the sensor at the bottom of the machine. Usually removing the bottom grate where the cups sit and taking some paper towels and soaking up the water/spillage will fix this problem
Aug 29, 2009 | Miele CVA4070 Coffee Maker
I need directions to clean my miele CVA 4070
The cleaning instructions are on page 34-45 of the owners manual =>
http://www.miele.com/manuals_pdf/Residential/Coffee_System/CVA4070_us.pdf
Please leave feedback. Thank you.
Dec 11, 2008 | Miele CVA4070 Coffee Maker
Miele CVA4085 coffee machine
no water in tank or water valve close thanks for using fixya pierre
Feb 23, 2008 | Miele CVA4070 Coffee Maker
Miele CVA4075 problem
There is a software bug in the electronik in the back of the coffee maschine. change the electronic th the new version and the Problem is sort.
Mr. Cool
Jan 27, 2008 | Miele CVA4070 Coffee Maker
Coffee Makers & Espresso Machines Logo
50 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
