Question about Mitsubishi Televison & Video
Mitsubishi 65 HDTV i got 2 green blinks then two more? Can you tell me what this code means please
Pushed both buttons and code was two blinks then two more what should I do now?
  • 3,506 Answers
Google the question
Posted on Nov 24, 2014
SirHanz
  • 145 Answers
SOURCE: Error code 1 2
I found this list of codes
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Posted on Feb 12, 2008
abhishek33
  • 1239 Answers
SOURCE: MITSUBISHI 65 INCH HDTV, GREEN LIGHT BLINKING, WILL NOT POWER UP
There are four (4) caps on the 'DM' board that need to replaced. Parts: 680ufd 16 volts, orig are rated at 1,000 ufd.
Posted on Jan 07, 2009
SD Tech
  • 14553 Answers
SOURCE: Flashing green light when i hit power botton.
2 blinks and 2 blinks is the error code for short protection---usually in this set the most common cause is a bad convergence chip that has shorted; it takes out one or two pico fuses in the set's power supply---the set detects no voltage to the convergence chips and shuts down.
Almost any good tech can do this repair in your home in about a hour or less--shops charge 300-400 for this kind of repair--look in your area and find someone who has done this brand before--I do lots of them here for 200-250 depending on model---This is the slow time of year for TV repair shops so look around--if someone says it "has to go to the shop" keep looking.
I have detailed start to finish instructions (verify the model number to me) for doing this repair; If you have the skill to do it yourself--you can buy the chip on Ebay A WS-55809 model uses a single STK-393-110 chip---about 14 dollars on Ebay plus shipping----let me know if you want the instructions and if you have questions reply to this post here.
etower.766@netzero.net
I do this here for free so if it helps you take a moment and give me a vote here.
SD TECH
Posted on Sep 03, 2009
ladywinn
  • 5138 Answers
SOURCE: my 65 in mitsubishi medallion hdtv 1080 wont turn
Fisrt try resoldering your Boards then Ck pico fuses they are green or yellow look like resistors but are fuses 5amps or 6amps also you may need to replace Both of your STK ICs they are Big Black ICs will have Part number on them example STK392-570 Call Mats For these 1-800-628-1118 Go by number on your STKs
Posted on Nov 18, 2009
Testimonial: "excellent knowledge and communication! "
ArnelM
  • 153 Answers
SOURCE: Green light comes on then goes right back off.
The TV indicates an error code 22 (short circuit protection). Check 2 STK392-570 convergence IC for shorts and 5amps pico fuse for open. I usually replace both STK's.
Posted on Dec 26, 2009
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
My 65 in mitsubishi medallion hdtv 1080 wont turn
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Jun 07, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Tv automatically powers off by itself within seconds.
This model has a self check: with the set plugged in turn it on--green power light comes on and a few seconds later goes off.
On front of set press and hold BOTH the menu and input buttons at the same time for at least 5 seconds and release both buttons.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Apr 11, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I have a mitsubishi ws-65315. When I go to turn the tv on the green power light comes on and you can hear the tv click on, but seconds later shuts off.
this model has a self check, when green light comes on and then goes off. Push and hold both the Menu and Input buttons on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks 2 blinks, a pause and then repeat it several times.
SD TECH
Feb 22, 2011 | Mitsubishi WS-65315 65" Rear Projection...
I have a 2002 65" Mitsubissi projection TV and it
When it shuts off and the green light goes out do this:
On front of set press and hold both the menu and Input buttons (device) both at the same time and hold for at least five seconds and then release both.
This is the self check the set has.
The power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
let me know what error code you get and I will tell you what it means.
I am in California and online now.
SD TECH
Feb 11, 2011 | Mitsubishi WS-65613 65" Rear Projection...
I have a mitsubishi ws-73711. I get a rapid flashing green light after unplugging and plugging back in. TV won't power up. I replaced the seven DM capacitors and the exact same thing is occuring. I am...
12 means no error. The device and menu buttons have to be pushed after unplugging and re-plugging for the error code operational check to work. If you have done that and if its still the same, then please tell me which LED is blinking so that I can help you. I remember your tv has 3 LEDs at the front.
Jan 08, 2011 | Mitsubishi Diamond WD-65831 65" Projection...
I turn the tv. on , the green light comes on then
When you turn it on and it shuts off---ON THE FRONT OF THE SET PRESS AND HOLD BOTH THE MENU AND INPUT(DEVICE) BUTTONS TOGETHER FOR AT LEAST 5 SECONDS AND RELEASE BOTH BUTTONS.
Power light should blink a two digit error code---for example: 2 blinks, a pause and 2 blinks--This is the most common error code.
Let me know what error code you get and I will tell you what it means and if 2-2 what the problem is.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 12, 2009 | Mitsubishi WS-65807 65" Rear Projection...
When I power up the TV, I hear a click and the green light turns on, but seconds later, it clicks off.
try self check==when it shuts off press and hold both menu and input buttons on the front of the set for 5 seconds and release both====power light should blink a two digit code===most common is 2 blinks and then 2 blinks, let me know error code and I will tell you what it means====it should repeat the code 10 times
SD TECH
Oct 17, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Error code 1 2
if it does it again i would check for bad caps
Blinking Problem
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
Feb 12, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
