Question about Faema Coffee Makers & Espresso Machines
Faema E92 error codes E51 and 58 What to check?
Temperature valve and boiler filling check
  • 3,506 Answers
Google this question and then post your answer as a comment to update others as well.
Posted on Nov 24, 2014
EsWorld
  • 1618 Answers
SOURCE: Faema S-87 Spouts copious amounts of water from the top
There could be one of 2 things happening :
1. Problem with auto level.
2. Most likely the inlet valve has a small leak.
Posted on Feb 26, 2009
EsWorld
  • 1618 Answers
SOURCE: Older Faema double head. Power light on, but
It is on the right side of the machine behind the grouphead if you remove the top panel you will see te box with the red switch sticking out. MAKE SURE THERE IS WATER IN THE MACHINE FIRST!!!!!! Do not trust the sight glass, if the level probe is in there, turn machine to 1 then disconnect the electrical connector on the side of the sight glass, the pump should kick in and water will flow in the boiler, if the level does not increase in the glass, then the machine turned itself off because the element got too hot from lack of water. The hole for the sight glass is blocked.
Posted on Jul 31, 2009
SOURCE: Espresso machine problems
I had bought coffee machine FrancisFrancis! X2 Espresso & Coffee Maker.When I turn on two group not heating up,I try wait about 15 minute but it reached temperature not yet,i checked every thing,however evrything is ok but gren light didn't come on.Please help me,show me how i can fix it.Thank's alot
Posted on Aug 20, 2009
EsWorld
  • 1618 Answers
SOURCE: I own a Faema E92/A Elite and it is leaking water
Remove the top panel, there might be 8 screws holding it on to the machine, then loosen the screws holding the plastic front panels from bottom and remove the clip in the back, you might have to bend the side panels out to remove front panels.
Posted on Aug 28, 2009
SOURCE: we have a faema e92 but our mains water is off,
We have an older type compact Faema and need to shift it to another location. How do we empty it of water
Posted on Feb 20, 2010
We have a Faema E92 Elite, 3 head. The display keeps giving an error code: Boiler overpressure E1. Already replaced the heating element (the gasket as well). How do we get rid off the error message?
You have one of two things going on here, the boiler is really over a safe pressure (very dangerous condition if error is for real) or the pressure sensor is malfunctioning. For safety sake I would have a professional look into this, a boiler explosion is a very dangerous.
Nov 29, 2016 | Washing Machines
Alpha cd28c boiler loosing water and pressure through pr valve when heating is on,and when then switched off needs repressuring to use heating again.no obvious leaks.new pr valve been fitted.pressure
I assume losing pressure through the PR means Pressure Relief Valve (PRV) or temperature pressure (TPR). Open in TPR may mean boiler is overheating/overpressurized. Open in PRV means the Pressure Reducer/Fill Valve in the fill line of the boiler is broken.
House Water Pressure in a home is 30/40 PSI min to 60-80+PSI max.
Boiler PRV/TPR are set at 30 PSI open (SYSTEM PRESSURE) so too high a house water pressure will open the PRV/TPR. Replace the reduction regulator on/in the fill valve assembly
Oct 20, 2014 | Water Heaters
Error code list
ALARMS THAT STOP THE DISHWASHER
A1 Want of water
Is the water cock open?
Does the water load solenoid valve work?
Is the water feed flow a min. of 5 l/min?
Is the water inlet filter clean?
Is the load solenoid valve filter clean?
Is the overflow inserted?
Do the tank/boiler pressure switches work properly?
C9 Automatic hood out of order
Alarm codes for automatic hood type dishwasher (see paragraph 9.2.1 Alarm codes for automatic
hood type dishwashers)
C12 Tank level sensor out of order
Are the connectors correctly connected?
Are connector contacts cleaned?
Does the air trap of the tank work correctly?
Is the level sensor broken (replace it with a new one)?
Alarm codes for automatic hood type dishwashers
When the alarm C9 appears, to facilitate fault-finding a parameter providing a more detailed indication has
been introduced.
The parameter is C9 and is found in the ron family.
The possible cause of the anomaly can be found (see next table) according to the value of the parameter C9.
E.g.: With an automatic hood type the alarm C9 appears.
Access the parameter C9 in the ron family.
Assuming the value displayed is:
20 ? During lifting, the current absorbed by the lifting motor has exceeded the threshold. This can happen if
a rack or other heavy material was placed on the hood.
ALARMS THAT DON'T STOP THE DISHWASHER (SHOWN ON THE USER INTERFACE AT REGULAR INTERVALS)
b1 Drain not efficient
Has the overflow been removed?
Is the water drain blocked?
Is the drain pump blocked?
Are the air trap and tank pressure switch clean?
Is there a constriction in the drain tube?
Is the pump breather pipe returning to the tank clogged or constricted?
Does the tank pressure switch work properly?
Is there a hole in the drain tube (only for versions with drain pump)?
b2 Overflow alarm
Is the load solenoid valve blocked? (see electrical wiring diagram - YV1 Filling solenoid valve)
Is the load solenoid valve relay stuck? (see electrical wiring diagram - RL5 relay of AP2 board)
C1 Boiler temperature rise too fast
Does the boiler level sensor work properly? The boiler could be empty.
Are no-original power resistances installed?
C2 Boiler temperature too high
Has the boiler temperature been changed (btC - increased above 90°C)?
Has the software alarm value been modified (bH,)?
Boiler relay/relays sticked (see electrical wiring diagram - RL1/ RL2/ RL3 relays of AP2 board)?
C3 Tank temperature too high
Is the feed water above 60°C?
Has the software alarm value been modified (tHi)?
Is the rinse water temperature too high?
Is the tank relay stuck (see electrical wiring diagram - RL4 relay of AP2 board)?
C4 Tank temperature sensor out of order
Is the temperature sensor broken or disconnected (see electrical wiring diagram - ST1 Tank
probe)?
Is the temperature sensor connector correctly inserted?
C5 Tank temperature sensor out of order
Is the temperature sensor short-circuited (see electrical wiring diagram - ST1 Tank probe)?
C6 Boiler temperature sensor out of order
Is the temperature sensor broken or disconnected (see electrical wiring diagram - ST2 Boiler
probe)?
C7 Boiler temperature sensor out of order
Is the temperature sensor short-circuited (see electrical wiring diagram - ST2 boiler probe)?
C10 Rinse temperature sensor out of order (only on machines with temperature sensor on the rinse circuit)
Is the temperature sensor broken or disconnected?
C11 Rinse temperature sensor out of order (only on machines with temperature sensor on the rinse circuit)
Is the temperature sensor short-circuited?
C13 Rinse pump out of order (the water level of the boiler does not decrease)
Does the rinse pump work correctly?
Is there any bottleneck in the hose, that connect the air trap and the board sensor?
WARNING:
Alarms C2, C6 and C7 lock the boiler temperature control.
Alarms C3, C4 and C5 lock the tank temperature control.
In the case of alarms C6 and C7, the boiler waiting phase is not executed (the rinse may be performed
with cold water) and, during the initial warm-up and subsequent rinses ( btF > 0 ), the boiler heating
phase is not executed.
In the case of an open probe error ( C4, C6 e C10 ), the displayed temperature is 10°C
In the case of a shorted probe error ( C5,C7 e C11 ) , the displayed temperature is 99°C.
E1 Communication error
Is the connection between main board and control panel correct? Are the connectors correctly
connected?
Are connector contacts clean?
E2 Tank temperature low
Does the tank heating element work properly?
Are the dishwasher feed voltage and current correct?
Is the relay RL4 (see electrical wiring diagram - RL4 relay of AP2 board) on the board disconnected
or faulty?
E3 Boiler temperature low
Does/do the boiler heating element/s work properly?
Does the possible remote control switch connected to the heating element work correctly?
Is there power at the remote control switch input terminals?
Do boiler relays (see electrical wiring diagram - RL1/ RL2/ RL3 relays of AP2 board) work properly?
CAUTION: IF THERE IS A MALFUNCTION ON RELAY RL1 AND THE BOILER HEATING ELEMENTS
ARE FED BY MEANS OF A REMOTE CONTROL SWITCH, THE BOARD DOES NOT
HAVE TO BE REPLACED; JUST MOVE THE BOILER HEATING ELEMENT CONNECTOR TO
ONE OF THE TWO FREE POSITIONS ON THE BOARD.
CAUTION: WHEN ONE BRANCH OF THE HEATING ELEMENT DOES NOT WORK AND THE
OTHER TWO CONTINUE TO FUNCTION, ON REACHING THE SET TEMPERATURE VALUE,
ALARM 3 DISAPPEARS AND REAPPEARS IN THE SUBSEQUENT RINSE PHASE. THIS
ALSO OCCURS WHEN A PHASE IS MISSING.
Dado
Sep 01, 2014 | Zanussi Dishwashers
Faema e92
There is an economizer valve on the machine that needs to be adjusted. I will assume it was pumping hot water, this is not a new installed machine, then the machine has scale buildup that is preventing the hot water from leaving the boiler through the tubes to the solenoid, only the mixed cold water is being dispensed. If this is a new installed machine, adjust the economizer on the boiler, remove the left panel for access. Big nut on the boiler you will see where it connects to the solenoid.
Dec 16, 2013 | Faema Coffee Makers & Espresso Machines
Trip switches of the boilers trip constantly on my faema machine. how can I fix it?
The element trip switches will go if the machine does not get water fast enough if they are not immersed in water, so to protect the element form overheating it will trip. Is there a sight glass to see the water level, I do not know what model Faema you have but most of the Due's have a sight glass on the left side front panel. Do you have a water filter and or softener, is that restricting the flow and need to be replaced, did the new ones if recently replaced get flushed before install, or maybe the water inlet tube where it connects to the boiler is blocked, has the technician checked and or cleaned that fitting? Can you use the manual fill to see haw fast water is getting into the boiler?
Mar 20, 2013 | Faema Coffee Makers & Espresso Machines
A2 just trying to get water in the boiler at this time water is filling the boiler but itis not shutting off and gets filling water will not stopunning what do we do???
Either the level probe does is not functioning properly, or the solenoid for the autofill valve is not working or the Cpu board relay is not telling the auto fill solenoid to turn off or the valve seats in the inlet valve are damaged.
Apr 25, 2011 | Faema FA60081
Bolier not working?
remove the top panel or front panel. Make sure there is water in the machine, and it is in the 0 position. Press the red reset switch, the turn the machine to 1, wait until boiler fills then turn to 2. If after machine fills at position 1 and you turn it to 2 and 1m minutes later there is no heat then your elements could be damaged.
Jul 05, 2010 | Faema FA60081
We have a faema e92 but our mains water is off, can we manually fill the tank without mains water?
The machine can sack the water directly from a water tank since the water inlet hose is conected first to presure pump. Just insert the water inlet hose in a water tank, however please take care that if you leave the pump work without ay water for more than 2 minutes the pump might be destroed.
Feb 13, 2010 | Faema FA60081
Jan 26, 2009 | Faema FA60081
You may want to have a close look at the seats. There may have been irregular wear on one or more causing the leak. Try and make sure each one is back in its original location.
http://www.faema.com/eng/contatti_rete.asp
Found a manual for you (closest match) It's only for a Faema Family. Well, what the heck, it's free!
http://picasaweb.google.com/Grendelpics/FaemaFamily
Hope you come right, cheers.
Mar 02, 2008 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
445 people viewed this question
Top Faema Coffee Makers & Espresso Machines Experts
pawnpower
richie46
Are you a Faema Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
