How do i get to the bottom of a failure to spin clothes i a whirlpool washing machine model awm320 which is an 800 spin model
Putting it to programme b the spin mode
  • 2,509 Answers
Is the machine draining properly?
Have you checked the filter on the pump? What happens when it gets to the spin part of the cycle?
Is it knocking?
Does it go through wash cycle properly?
W
Posted on Nov 24, 2014
  • 221 Answers
SOURCE: 10yr whirlpool toploader wash machine no spin/agitat. but works?
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on Jan 08, 2009
  • 236 Answers
SOURCE: My washing machine won't spin!
as with basic spin faults -a number of reasons usually 1 motor brushes, 2 motor 3 motor control pcb or the obvious one - the belt has come off.
Posted on Mar 13, 2009
SOURCE: old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Posted on May 07, 2009
SOURCE: Whirlpool washing machine AWO/D 4305 does not spin
its probably an inbalanced load or its to light.it MUST have a good full mixed load to spin
Posted on Jan 28, 2010
  • 552 Answers
SOURCE: Hello my washing machine works fine but when it
The drain motor may be bad click on the link below
Posted on Mar 08, 2011
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
I have a Whirlpool LHA 5700 old school washer. It works great. It wash clothes with no problems. It just stop spinning the water out tub and clothes. The water drains as far as it can but that's it. W
Don't know the model but with the old basics with electric motor drive as a 1st step always check for broken wires to the motor as they flop around a fair bit and eventually break them or corrode them from water and washing detergents.
Apr 19, 2014 | Whirlpool Washing Machines
Why is my maytag Neptune Model no# MAH5500AWW spinning very slow and not draining water out?
Complete drain must occur before spin. A no drain situation would be an actual full pool of water seen in the bottom of the machine if all the cloths were removed, sounds like you are experiencing a spin enable switch failure, which mainly prevents final high speed spin leaving the cloths dripping wet. The spin enable switch contacts become tarnished/corroded over time resulting in poor connection. If the door lock light comes on than your door lock wax motor is working. The spin enable switch is the last switch to the right in the door lock unit where the light bulb is. Part# is 22002162. If there is an actual pool of water in the bottom of the machine as if you simply removed the cloths from the unit but left the wash water, than you should look first look to your drain pump for failure, or obstruction of foreign objects, or excess lint in the pump. Pleazer Appliance...
74bd738b-53cb-465a-99c1-ba55e2189ba2.jpg 5e1e4646-e2e3-4e7c-afc7-7a0e188e6cf0.jpg
Apr 15, 2014 | Washing Machines
Fills with water correctly, will not go to next cycle
Hi ,, ok lets try some fault finding,,, try putting the washing machine on a no or low temp programme like wool,, or even the fill empty spin , see if it moves then,, if the programmer moves through then spins, i would assume the thermostat is broken,, if it moves through but does not spin , it may be the heating element,, if it does not move at all in any programme i would assume the programmer has a problem
Nov 14, 2013 | Whirlpool Washing Machines
My washing machine model is Whirlpool - White Magic - FPAN651. Problem is every time after washing the clothes in the machine the clothes are not completely clean. additional dusts and stains are sticking...
you need to send the full model number,all i can think of is the water level is to low or the dogs are bad and not aggitating the clothes,grab the top of the agitator,spin it to the right and left,if the top moves without locking into the bottom of the agitator you need to replace the dogs,let me know what you find and send the full model number that's on the machine,look at the opening where you put the clothes in,follow the lid all the way down,put your finger on the bottom of the lid and you will be pointing at the model number on the back panel around the opening
Oct 30, 2010 | Washing Machines
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Whilpool washers drains but when done spinning puts water bk out
If you have a selection for extra rinces deselect it and try. If not almost certainly your timer is faulty.
Jan 24, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
check that the machine ramps up to spin speed reasonably and distributes the clothes- ie doesn't spring straight up to spin speed. if this is ok then the fault may well be the shock absorbers located at the bottom of the machine and going from base to tub. check also that the counterweights are intact
May 09, 2007 | Whirlpool LSN2000LW Washer
Washing time & quality
Look for wash cycles in your users'manual. It is best the read the manual well before operation.
Apr 05, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Washing Machines Logo
Top Washing Machines Experts
