<!-- from fixya rte -->How to connect my TP wireless as a bridge - Computers & Internet
    Scholar:
  • 60 Answers
Here's a very concise walk-through:
http://blog.jeffcosta.com/2011/09/29/create-a-wireless-n-bridge-with-2-inexpensive-tp-link-routers/
If you follow it, step-by-step, you ought to be fine. I've done a bridge using a Linksys E1500.
The only difference is I chose to use different firmware- which I got from the DD-WRT site. That's another option, if your TP-Link is on their approved list of routers.
HTH
Posted on Nov 26, 2014
2 Suggested Answers
upbeatjunk
  • 231 Answers
SOURCE: how to bridge trendnet wireless
Most retail routers do not come stock with bridging capability. In order to accomplish this you would need to flash the firmware on the router with another like Tomato or DD-WRT. While this WILL give you the bridging capability it will also void your router warranty. However, flashing with an this alternate firmware is usually very beneficial because it will give you complete control of your router's capabilities. If you need help setting up the bridging, or managing any other features of the firmware you can find support forums right on the site that you download the firmware from that will assist you in doing this. Since you are using a TRENDnet router, DD-WRT is probably the best way to go. You will need to search for your router here:
http://www.dd-wrt.com/wiki/index.php/Supported_Devices#TRENDnet
and download the appropriate firmware to flash.
Posted on Jun 27, 2011
Not connecting to all devices wirelessly
You need to open the Router Page and Remove the restrictions set for devices to be connected.
Jun 08, 2013 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
Disable Nat TP-LINK TL-WR1043ND
yeap it should be the firewall, here is the manual http://www.tp-link.com/resources/software/201161017075118.pdf
think this should help you.
But if you want my expertise, make the tp-link as a router and vdsl just the internet line. connect it to router wan and buy a switch for all your devices.That should be the safest and smartest way.
Mar 06, 2012 | TP-LINK TL-WR1043ND Router
I bought a TP-link TL-WN821N wireless network USB adapter. I installed the driver on my desktop and I cant connect to our network nor the internet. I connected it to my laptop and deactivated the...
Dear Joeri_troch This is Howard from TP-LINK Support Force. Could you please check if your desktop has recognized the wireless adapter? And can you see Wireless Network Connection icon?
TP-LINK Support Force http://www.tp-link.com/en/support/ http://www.facebook.com/TPLINK
Sep 17, 2011 | TP-LINK TL-WN821N (TPLINKWN821N) 802.11b...
I'm using TP-LINK TD-W8101G ADSL Modem Router to connect internet, I'm trying to connect it with Linksys WRT120N Router Wirelessly. I want to use WRT120N as access point to extend TP-LINK...
Unfortunately, you can't use two routers together in that manner. You must have a device in between them such as a switch or bridge or you'll have to disable the DHCP server settings in the second router. The second router then pretty much becomes a switch you may then use all the ports on the second router with the exception of the WAN port it must remain unoccupied. However, if you need wireless connectivity in another location far away from your main router then your only solution would be to indeed purchase an actual access point/bridge device
Sep 06, 2011 | Linksys WRT120N Router
Unable to wireless connect TP-Link TL-WR841ND to Motorola SBG900
DO any of these error conditions show up on the front panel display?
Front-Panel Lights and Error Conditions
Light Turns Off During Startup If:
RECEIVE The downstream receive channel cannot be acquired
SEND The upstream send channel cannot be acquired
ONLINE IP registration is unsuccessful
POWER The SBG900 is not properly plugged into the
power outlet
OR
Light Turns Off During Normal Operation If:
RECEIVE The downstream channel is lost
SEND The upstream channel is lost
ONLINE IP registration is lost
POWER The SBG900 is unplugged
If you rent or lease your SBG900 Contact your cable service provider.
If you own your SBG900 Call 1-877-466-8646 for technical and warranty support. Support is available
24 hours a day, seven days a week.
Feb 28, 2017 | Arris SURFboard SBG900 (49402201900) Modem
Use Netgear WGR614 as an access point
Right, it won't work. The 614 doesn't have the software to make it into a BRIDGE or AP CLIENT. It can only be made into an Access Point, meaning it needs a wired connection INTO it.
A TP-Link http://www.tp-link.com/products/product_spe.asp?id=36 WA501G costs under $40 and gives you the ability to go from wireless to wired. It takes about 15 minutes to set up, and will plug into your DVR's ethernet port to extend your wireless network. It's programmed by setting the mode, AP, CLIENT, BRIDGE, etc. We use them in areas where we want to extend a wireless signal for distances like across parking lots, but it also will work across a room or two.
There are also wired ethernet extenders that use house wiring like the Netgear XE-102, about $80, that look like two wall transformers with ethernet jacks. You plug one into the router/switch and the other into the DVR.
Carl
Apr 21, 2009 | NetGear WGR614 Wireless Router
CAT 5E DISTANCE
Considering what you started with, it should be slow :-)
If this were my installation I would run HUGESNET>Router>BRIDGE>BRIDGE>ROUTER/AP>PC
The first router is the 150N. The Bridges are two Wireless Access points in bridge mode designed for distance. A nice unit for this application is a TP-Link WA-601G with antennas (ANT2408) found here:
http://www.tplink.com/products/wlan.asp
It will cost you an extra $100-150 depending on antenna, but it should get you good results, considering the SAT is probably 300 down and 128 up :-)
Carl
Apr 05, 2009 | Computers & Internet
Using the DI-624 as a bridge
I don't think it can. An inexpensive wireless access point will work as a bridge. I use the TP Link brand with detachable antenna.
http://www.tplink.com/products/product_des.asp?id=116
Using the terms using the dlink router as bridge you get results of people who claim it can't be done because of firmware. The same question on the D-Link help site mentions DL to DL bridges, but not with the 624.
Carl
Jan 04, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Wireless ethernet from a wired router?
You can buy a wireless access point to plug into your router. The thing is, you can buy a new router with wireless built in for about the same price. It's up to you to shop and compare.
In either case, you will need to configure the wireless, and create a WEP key to share with the wireless in the computer(s). The new wireless will come with instructions.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 28, 2008 | Dynex DX-E401 Router
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
