Question about Xerox Office Equipment & Supplies
My cannonIR2318 xerox machine showS CODE EROOR *E000007
  • 3,506 Answers
Google this code and then post a comment with the answer so others can also know.
Posted on Nov 24, 2014
5 Suggested Answers
StevenC82
  • 160 Answers
SOURCE: I have a Xerox Phaser
This error indicates in issue with the ink or ink loader. Open the top cover and inspect that the ink inside is not broken, also make sure you are using genuine xerox ink sticks. If this is true you can clear the error
On the Control Panel, press the Down Arrow button to select Troubleshooting, press OK. Now press the Down Arrow button to select Service Tools, press OK. While pressing and holding down the Up Arrow button, press the Down Arrow button to display the Hidden Service Menu. Enter Diagnostics, Go to Function Menu and Clear ISC Fault.
If the error re-occurs after doing all this you should replace the ink loader (part# 133K27771). Here is a video that shows you how to do that. Good luck, and thanks for using Fixya!
Posted on Sep 07, 2011
lahen01
  • 63 Answers
SOURCE: canon xerox machine error code
This is a fuser temperature issue, it can be cleared in service mode but if the problem persists after being cleared then the fuser may need to be rebuilt or replaced. To clear press:
additional functions
2+8
copier
function
clear
err
ok
shut down and turn on with switch on the side of copier
Posted on Sep 27, 2011
  • 7 Answers
SOURCE: Error code E000007 - 0000 always appear on my Canon ImageRunner 3235 during copying and printing
The fuser film is not rotating properly.Replace it .
Posted on Jan 11, 2013
  • 12 Answers
SOURCE: CAnon xerox Machine IR 2318 ERROR CODE E000007-0000 SOLUTION
open fixing unit & replace fuser film.......................................
Posted on Feb 03, 2013
Solution to erro e000007 on ir 2420 copier
What is remedy error code E000007-0000 for canon ... - Fixya
www.fixya.com/.../t14373194-remedy_error_code_e000007_0000_can...
Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
Imagerunner 2200 error E000007-0000 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Mar 15, 2007 - 4 posts - ‎4 authors canon ir 2200. hi, this machine do not have fixing roller. machine have fixing film assembly. this code is for damaged fixing film, on the end you ... Error Code Canon 3025 E000007-0000
Jan 30, 2013
Error Code The dreaded e000007-0001 error code!
Sep 5, 2011
Error Code Color ImageRUNNER 4060i has code ...
Jun 30, 2011
More results from www.copytechnet.com
Nov 05, 2015 | Office Equipment & Supplies
How to fix xerox error code 7335 003-344
There is a communication failure at power on between the controller and the IIT. Fixing it can prove to be expensive and time consuming. allow a trained rep to repair for you
Sep 02, 2014 | Xerox Office Equipment & Supplies
Feb 03, 2013 | Office Equipment & Supplies
In my canon xerox imagerunner 2420L displays error massege
i have canon image runner 2420l copier and it show the error message restart the machine if problem persists, call service rep. **E000007-0000 how can i solve the problem/ and fix the machine
Nov 04, 2012 | Office Equipment & Supplies
Error E000007 Canon xerox machine ir2200-ir3300
Error of E000007 -0000 IR3300 Machine What we can do ?
May 17, 2011 | Garden
CAnon xerox Machine IR 2318 L Error code : E 000007-0000
My canon ir 2318L shows error**E000007-0000 how can i solve this problem
Feb 28, 2011 | Office Equipment & Supplies
CANON 4050 XEROX MACHINE
my xerox machine canon 4050 shown an eroor(E020)...we cant able to take copier
Oct 16, 2008 | Canon NP 6050 Copier
E000007-0000
Hello Evank,
I will gladly help you understand what's going on, but I am afraid nothing short of service call will actually resolve your problem. First off, the error code you are getting will cause the copier to just suddenly STOP...... which indeed will cause you to wind up with a paper stoppage but not a true paper jam. I apologize for what is like a distinction without a difference,but i just wanted to give the benefit of as much information as possible.The error code you are getting refers a subsystem of the copier called the fuser, which is a high temperature high pressure area that is common to all copiers. Because of the potential danger of high temp and pressure, all copier manufacturers design their products to be VERY sensitive to monitoring all aspects of the fuser as they do not wish to burn your building down. (bad 4 marketing) The E000007 error code refers to the fusing system. The code basically means that the on board computer of the copier did not get the signal it requires telling it that the fuser was working properly. That in fact it was not turning at the same time /speed as the copier. There is a sensor on this "fusing unit" that detects this speed. Either the sensor is bad, the fusing unit is indeed not turning at the correct speed and therefore is defective, or the dc controller ( a circuit board on the machine that processes most inputs) is defective. Most likely its the fuser/fusing unit which indeed is a "unit" and if it needs to be replaced will include the sensor previously described. The fuser (Canon also refers to it as a fixing unit) is good for @150000 copies more or less according to Canon and that is one of those things that I would call "according to the manufacturer" promises.In short, after this long winded description, unless you are a well trained copier tech, you will need one. But at least I have given you enuff info that you won't get screwed by the "copier dude" . :-) Of course I "IS" one. LOL . Good luck and I hope this helps you at least a little. ...........SPINAL........
Apr 23, 2008 | Canon (6981A002AA) for imagerunner 2200,...
27 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
